This Old Anvil
This anvil has been in the family for about 50 years and stories about its previous ownership go back another 20-30 years.  I know nothing about it other than it was used as a general shop/farm anvil to hammer implements, weld, etc.  It's been pretty well used and abused judging from all the marks.  I tried to get a decent photo of the markings using a light but there's little to go on.  I figured someone here might recognize bits and pieces so any help is much appreciated.  The bottom arced words could be "Brooklyn NY" but that's a wild guess.
The approximate dimensions as I see them:
overall length - 32"
height - 12"
width - 4.75"
base:  11"w x 12"L.
Don't have a clue on the weight but my brother-in-law and me picked it up and we guesstimated about ~250-300lbs.  I will definitely do some research on this site.  I'd like to know more about  ring characteristics.
Agreed about it being a Hay Budden.  I'd say that it is in pretty good shape and any smith would be happy to put it to work.  I'd go over it with a wire wheel to remove the rust and then put a coat of boiled linseed oil on it to keep it from re-rusting.  In a humid climate like SC things will rust easily if not protected.
Looks pretty good actually. Not abused much other than the few small spots.
The sides were not the important part to the user back in th he day and many times were used to "test" hardness of a chisel or punch.
Yep Hay Budden for sure. The weight stamp below Brooklyn looks like 240 pounds. That anvil is in excellent shape from the picture. If there is a good rebound & ring I would say like new. Hope you have read about not doing any grinding, milling or welding on the hardened face. When Hay Budden anvils are not tied down and dampened, they ring like a bell over the face and rebound is in the 70-80 % range when a steel ball bearing is dropped from ten inches.
Agree its a Hay Budden, look at the foot under the horn and see if you have any numbers.
Thanks all.  I’ve learned more about anvils in the last few hours than I’ve ever known.  For sure a Hay Budden and the dimensions match the 250# model from their catalog.  The rebound is definitely in the 75% range and boy will she ring.  I have it setting unconstrained on a poplar stump in my garage,  Not really where or how it should be I guess.  Suggestions welcomed.
Unfortunately, it does have a few weld beads on the face from obvious equipment repairs while on the farm. I will give it a good wire brushing, and coat it with some oil. The tip of the horn had some cracked, “mushroomed” metal from blunt ended abuse that I gently removed with a file. I’m sure thats probably not proper but I didn’t want it chipping off in use.
Here’s a few photos of the number.  I tried to cast shadows with a light.  The first number might be a “7” which puts it in the 1902 +/- range.  Anyone see something different?
About the 3rd time you've accidently run your leg into a sharp horn on an anvil you will start to understand why so many of them have blunted horns...
Wreckster,
time to try out your new hobby and use that anvil.
make a fire, put a piece of rusty, scrap metal in it, wait until it's red, pick it up with some pliers, hit it with a hammer on your terrific looking anvil.  Don't try to make anything, just hit that metal.  You will know after a minute or two it you are bitten by the blacksmithing bug or not.
Wear some ear and eye protection and have some fun.
cheers.
Looks to me like it is welded at the waist, so guessing it might be one of the later ones with a solid steel top. I don't have a copy of AIA to confirm. Real nice looking anvil.
Steve
This is one instance where I would say to go ahead and grind them down. Be very careful not to dig into the face and go slow.
It's usually fairly easy to remove weld and not the face if you take care.
I used a file to get weld spatter off the face. The file cuts through the spatter and skates on the face :-)
HB Serial # 104906 puts the anvil birth in 1905, according to "Anvils in America" by Richard Postman.
Many thanks for the trained eyes njanvilman.
