Yes, No, Maybe depending on information you have not provided.
For one thing; is it your belief that every bed frame made all over the world by hundreds of different manufacturers over the last 100+ years used the same alloy?  Having worked with several frames; I can say they did not work similarly. Some were definitely higher in carbon content that others.
What did the spark testing indicate when compared with say automotive spring and a file?
Share this post
Link to post
Doing basic tests and research is a better way to get useful answers to your questions.
Share this post
Link to post
I've heard of people using steel from heavy duty and older bed frames for all kinds of tools and such, but having never done it myself, I can't attest to it one way or another. Don't know that I'd fool with it, even if it were. You do you, though, haha.
Share this post
Link to post
I remember a fellow who welded up a set of shelves using bed rail. He was real surprised when they collapsed after being loaded due to HAZ cracking.  He hadn't treated it like high C when welding...
Share this post
Link to post
For awhile, a lot was made from old railroad track. Pain in the rear to work.  You could also cut a piece and make a test coupon, heat treat it and see what it does.
Share this post
Link to post
Most is still recycled RR rails. I went to some of the major manufacturer's websites and they showed the rail being split and rolled.
But yes, that is not 100% of manufacturer's. Always test a sample(s) first
Share this post
Link to post
