Awrksmokey Posted May 7, 2020 Posted May 7, 2020 I'm forging my first hammer! It's been a ton of fun so far. I started with 3 inch 4140 round, cut a disc off and shaped the billet first. I punched the hole accurately (or so i thought!) and once i drifted it, I saw it wiggled a bit off center. I got some help trying to correct it by drifting to round then oval again, but it didn't really work sadly. I forged in the fullers and then forged the faces, round side into octagon and the flat side I hit the corners to octagon on the rounding side, but on the flat side i just smashed the corners in a bit. i've rough ground it and heat treated it, and this is what it looked like. The next day i heat treated it and finished grinding the faces. I made an 11 inch ash handle, charred the end a bit (for aesthetics mostly, lol) and put a walnut wedge followed by a steel wedge in. The hammer ended up around 2 pounds. I wasn't sure if this was going to turn out well at all, and even though there are a ton of annoying flaws I'll try to correct on the next one, I like it. I forged the leaf with the hammer too. Quote
Virusds Posted May 7, 2020 Posted May 7, 2020 Real nice! thanks for posting this, love to see other people's creativity. Quote
DSW HandCraft Posted May 7, 2020 Posted May 7, 2020 It's a nice looking hammer! The pleasure of using the tool that you've made from scratch outweighs those small flaws. Quote
Awrksmokey Posted May 7, 2020 Author Posted May 7, 2020 Thanks guys! I agree, it is much more fun using a hammer I've made instead of a hammer I bought. Quote
Irondragon Forge ClayWorks Posted May 7, 2020 Posted May 7, 2020 All around a great hammer, good weight too. Quote
Awrksmokey Posted May 8, 2020 Author Posted May 8, 2020 Thanks. I want to make another hammer now lol. Quote
jlpservicesinc Posted May 8, 2020 Posted May 8, 2020 Nice work and nice correction with the handle.. If you punch or shape the eye off there is no great way to correct it without a great understanding on how to shift the metal around.. It's not a simple task.. So even going from oval to round back to oval won't correct the area where the metal is bunched up.. One actually needs to shift the fat spot (which happens in 2 places) around. Well done.. Quote
Awrksmokey Posted May 9, 2020 Author Posted May 9, 2020 I'd also tried cooling the cheek that bulged out disproportionately and drifting it with one side hot, that didn't work too well either. When I make my next one, hopefully I'll just do it right the first time but the learning experience of learning to move the metal would be welcome too. We'll see. Thank you! Quote
jlpservicesinc Posted May 10, 2020 Posted May 10, 2020 Yup, good learning for sure.. How do you like swinging it? Have you ran it thru it's pace yet? Quote
Awrksmokey Posted May 10, 2020 Author Posted May 10, 2020 I did some forged the leaf in one of the pics with it, and I also did some forge welding and made a ball on the end of a rod. I also tried scarf welding, and that didn't work so well haha. More practicing to do i guess! I'd say it worked pretty well! I really like that sort of rectangular handle shape. The rounding part took some getting used to but I can really see why people like it now, Quote
jlpservicesinc Posted May 10, 2020 Posted May 10, 2020 Nice.. Nothing like the feeling of making you own gear that you can be happy using. By the way.. Nothing is perfect when hand made.. WE just strive to go there.. Each time we get a little closer.. Quote
Awrksmokey Posted May 10, 2020 Author Posted May 10, 2020 Yup, I guess perfect can't really exist. But i can try to get real close! Quote
Momatt Posted May 12, 2020 Posted May 12, 2020 Congratulations. 3 inch 4140 by hand? That is big hard metal to move with a hand hammer. Quote
Awrksmokey Posted May 20, 2020 Author Posted May 20, 2020 I went to a different shop, and they had some nicer tools then i was used to in my home setup, but it was a pretty sizeable chunk of material! Quote
