November 1, 20196 yr like to find out what I have here 100lbs anvil can anyone identify the symbol on the side
November 1, 20196 yr It's very interesting. Do you know what it weighs or what it's made of? You should add your location in your profile. It may help narrow your search down if we know where you're located in the world. Perhaps that particular anvil mostly resides in a certain region and only a few may know what it is
November 1, 20196 yr Author I’m new to going on a site really don’t know what I doing I’m in the USA I’ll try to fix my settings thank you for your help It is a 100 lbs no don’t no what it’s made off
November 1, 20196 yr No problem. The location really helps. There may be another member right down the block from you. Is that broken foot hollow inside? Maybe it just looks like that and it's just broken off. Looks maybe cast iron with a steel top plate. I'm not an expert. I had one that had a cast iron body and if you tap the body or under the horn, it will sound like a dead thunk. But if it has an actual ring, it's something else.
November 1, 20196 yr Author It is a 100 lbs no don’t no what it’s made off . It’s looks like some one took a torch and blow a hole in it.maybe a inch deep
November 1, 20196 yr Author If you would like I’ll send you more pictures tomorrow. The top plate looks like it has been grounded down haft way across the top and replaced with a steel plate maybe because the corners are round off that’s what the back of the anvil looks like It may be cast I don’t know cast not worth much? Back were the hardy hole is its not been cut down and the comers are round off
November 1, 20196 yr Good idea to post more pictures. The more knowledgable folks here might be able to tell what you've got or at least what it's made of
November 1, 20196 yr Author I’ll send you more pictures in the morning if that’s ok with you. I’m going out now thanks for your help
November 1, 20196 yr From that single solitary photo, all I can venture is that, a) it had the face plate replaced, b) it must have had some sort of unusual fastening on that blown up leg, and c) perhaps it had something else welded to the side and then removed. (mostly guess) As long as the faceplate is firmly attached and it does not sound hollow when you tap on it with the hammer, that is all it counts. Use it as it is and don't try to change it. Perhaps the only exception is that busted foot. You could fit a piece of steel in the wound and weld it all shut and grind it into shape with a flap disc. Purely cosmetic and welding there will not harm the top. If when you hit the top it goes cloppety clop, meaning the plate is loose ... well ... it is possible to fix it but most likely not worth the effort. You could try some anvil repair workshop I hear you have from time to time. Will need to figure out where and when. Hope you don't need it.
November 1, 20196 yr Side note----appears your tool in the hardy is a straight taper----may not be wise----might only take a few whacks to lose your heel.
November 1, 20196 yr Its Cast! If it's cast iron then it's pretty much what we'd call an ASO that someone has tried to put a face on. If it's cast steel, then it may be a good anvil depending on alloy and heat treat; but again someone has messed with the face. That thing on the side looks like someone pressed a brick into the side of the mold, for ???????? Definitely it does not look like a commercially made anvil; but may be an "end of the day clean out the ladle" casting. I've seen a number of those, including a bunch from Mexico where they use a good old anvil to make the mold and then cast whatever they have left at the end of the day. No heat treating, minimal fettling and sometimes the two sides are offset leaving a large line across the face. Seen Auctioneers selling them as "antique anvils" even though they are probably only a year or two old. I once talked to a wife, a smith's widow, who told me that after WWII when the local steel casting company was melting a lot of surplus scrap they had a run of anvils cast for them out of the armour plate from naval warships. I would have liked to see how well that worked, I would have guessed it was a Ni Steel but not too high C. Unfortunately they were all long gone by the time I talked to her in the 1990's.
November 1, 20196 yr Author Thanks the spike is just sitting in the hardy hole, I’ll take some more pictures and post them shortly thanks
November 1, 20196 yr Author Here are some more pictures it looks like some letters on the side were the square is and the other three feet looks like they have been fixed it could be were some one had it mounded and they didn’t fix the one,and what do you think of how the bottom has the arch It says I edited it i think because I picked medium size for the picture
November 1, 20196 yr I'd show those pictures to Richard Postman, author of "Anvils in America" and ask his opinion.
November 1, 20196 yr Author Ok I don’t know how to go about that maybe google his name I’ll try that thanks for your help
November 1, 20196 yr Well I used to go talk with him at Quad-State over the years; how I learned that my POWE was a Powell, my Fisher had belonged to a Blacker powerhammer and that the missing top to the base I had would probably have said Peter Wright...
November 1, 20196 yr BGD, that made me giggle... but you're right. It does look like that. What a blast from the past
November 1, 20196 yr Well that looks much better than the first picture. It is old, has the waist weld ... it had extensive damage and part of the plate was replaced. How well is hard to say. Can you drop a hammer on the surface and tell if the plate is sound?
