Mtbarn Posted April 20, 2019 Share Posted April 20, 2019 Hello all, The attached pictures show a chip in the corner of my hardy hole. I’m wondering if the sharp corner on the chip is something to be worried about? Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 20, 2019 Share Posted April 20, 2019 I don't think I'd worry about it, I'd avoid doing heavy work in it though. I try not to do very heavy work in a bottom (hardy) tool but I have a swage block for that. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 20, 2019 Share Posted April 20, 2019 Is it a steel faced WI anvil, a solid steel anvil, a cast iron anvil? It is a stress concentrator and depending on what type of anvil it is you might consider having the Gunther/Schuler anvil repair process done on it. Quote Link to comment Share on other sites More sharing options...
Chris Williams Posted April 20, 2019 Share Posted April 20, 2019 At a minimum, consider taking a small round file and rounding the sharp corner. Quote Link to comment Share on other sites More sharing options...
Mtbarn Posted April 20, 2019 Author Share Posted April 20, 2019 The anvil is steel faced with a wrought body, a Hay-Budden. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 21, 2019 Share Posted April 21, 2019 Also make sure the hardy's fit correctly without any taper that would put undue stress on the sides of the hardy hole. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted April 22, 2019 Share Posted April 22, 2019 It almost looks like a torch cut that's been filled in. But that could just be my imagination. Quote Link to comment Share on other sites More sharing options...
bluerooster Posted May 25, 2020 Share Posted May 25, 2020 I believe that the sharp "chip" would be a stress rizer in a thin portion of the anvil. I would probably dress it with a round file, and leave it be. Quote Link to comment Share on other sites More sharing options...
