If the only store that sells insulating wool not have ceramic wool but they have fiberglass wool, would that be cool or would that be a terrible idea? Any alternatives. Also just for fun, any fun or cool/wacky forge ideas that works surprisingly.
glass has a low melting point and would melt long before you got the forge hot enough to use
which part of the world are you in, maybe someone local can help you
I am from south africa. I am going to a store that might have ceramic wool and ask if they have. If not i will keep looking.
Majidii,  welcome to the forum first of all.  Secondly, fiberglass is not a suitable substitute for ceramic wool.  If you're planning on building a forge then the materials in the chamber must be able to withstand the heat of forging.  You should be looking for materials that can withstand a minimum of 2300 degrees F (1260 degrees Celsius).  Thirdly, without knowing your location it will be difficult for us to suggest where to get materials.  If you could update your profile to give us a general idea of where you are in the world we might be able to offer better suggestions.
It would also be worth your time to look at the Forges 101 topic to get a good idea of how to build a good gas forge:
https://www.iforgeiron.com/topic/47439-forges-101/
We have a few members from South Africa.  Hopefully one will log in soon and may be able to point you in the right direction.
Whoops my bad. Will update my profile.
Will ask him. Thanks.
I don't believe you can, Wayne. The high shipping costs to SA are only matched by the low probability of the package actually being delivered.
You surly have HVAC shops that sevice boilers, I also know that you have large iron works so suit me material is avalable. One of our SA members will certainly chime in soon.
:DCharles, this is Africa and boilers aren't nearly as common here as you might think.
I can supply the op with whatever he needs I have pméd him  so when he tells me what he needs I can send it to him.
