L0RDR4G3
Thought Introductions were in Order
17 minutes ago, JHCC said:
The standard test for rebound is to drop a ball bearing from a known height and measure how far back up it bounces. To quote @Frosty, "Use a ruler if you're not good at eyeball guesstimating that sort of thing. The higher the % rebound the better, below 65% is pretty poor. 90% and up is outstanding. In between is decent to good."
ahh okay. so i need a ball bearing. does the size of the bearing have any effect on the result? and 65% original drop height?
Share this post
Link to post
No.
Yes, that's right. The easiest way to do this is to hold the ball bearing at the 10" mark, spot the measurement of its bounce, and multiply by ten. So, a 5" bounce = 50% rebound, a 7" bounce = 70% rebound, an 8½" bounce = 85% rebound, etc.
Share this post
Link to post
65% is poor
1/2" to 1" would be a good size
try over different parts of the table
cast iron is bad
cast steel CAN be good if it has a tool steel top or is made from a very good grade of steel.
a decent new one can cost you over a grand but there are a million bad ones for each good one.
who is the maker or is it a no name chinese import that you can get for 50 quid at the wholesaler.
Share this post
Link to post
11 minutes ago, JHCC said:
No.
Okay kool will test this once i find a ball bearing. I think my son may still have some laying around his room somewhere from his old Magtastix  sets .  (the magnetic stick and ball building set things, i think thats what it was called)
And i believe the stamp on it says Stilsen? can be certain at the moment as its locked in the shed
Share this post
Link to post
If the ball bearing is magnetic, it's not going to bounce very high! ;)
Share this post
Link to post
lol yeah didnt think of that. need to check first. lol
anyways signing off for now need to sleep for work
Share this post
Link to post
Large ball bearings have less trouble with pitted anvil faces; but on a clean flat face size has no effect.
Share this post
Link to post
 Good point.
 Another advantage of a larger bearing is that if it leaves a dent, the face of the anvil is probably too soft.
Some image searching online shows me an identical anvil made by "Neilsen", but I haven't found anything to reliably indicate its material or quality.
Share this post
Link to post
On 26/07/2017 at 6:11 PM, JHCC said:
 Good point.
I believe it is the Nielsen one, I bought it under the recommendation of Paul MacDonald of the Macdonald Armouries in Edinburgh
been a busy week so haven't been on the computer much (or home for that matter)
been lookin for a good sized ball bearing for a while to make a large monkey knuckle. biggest I have laying around are 20mm
Share this post
Link to post
dont drop a ball bearing on that anvil any bigger than 20mm, hope you did not pay much for it, yes I know who the wholesalers and importers are of that,
a bit of rail or fork lift fork would be far better, they are £69.99 but worth about £6.99 as a boat anchor or door stop.
model number is CT2736 from cannon tools who import from india and china and sell tools to market traders and car booters
Share this post
Link to post
if you bought it on a certain auction site and it was described as steel start a dispute for SNAD
item significantly not as described
you will get your money back and the seller will have to pay to get it sent back to them
Share this post
Link to post
Any offshore oil drilling scrap around?  They can have very large bearings in things like cranes and drilling rigs...
Share this post
Link to post
does it matter how long ago it was purchased?
and how would you go about proving it isnt steel.
most descriptions i can find for these do state steel or cast steel.
also when hammering on it i havent had any issues with it. no denting or anything. so whats wrong with it?
Share this post
Link to post
yes it has to be recent
drill a tiny hole in the underside of it, cast iron bbonsswarf will be powder of small flakes, steel will be longer ribbons.
cannon recently got done for wrongly labeling stuff, fined £25,000 for selling things with a ce mark they should not have and I think stock was destroyed too.
hit a corner or the face with the hammer at an angle
our main shop anvil is in good condition but dates from 1730 ish and it gets regular heavy use and abuse, that thing would not last us a week but it is your money to spend as you like ( and I know how the scots like to spend it
Share this post
Link to post
touching a grinder to the base and looking at the sparks generated will also work as I can guarantee that they would NOT be using any of the high alloy (read as EXPENSIVE!) steels that produce sparks similar to cast iron!
Share this post
Link to post
welp im screwed either way then lol.
bought it way back when i started gettin stuff together to set up. so we're talkin maybe as far back as november last year.
its a pain in the ass and just need to be chalked up to experience.
also kills me that my neighbour 2 doors down has a great big bugger just sitting in his garden as an ornament lol.
Share this post
Link to post
Swap it out one dark night and tell him it shrunk in the rain?  Offer to trade him a hand forged sundial for it? Or a garden bench?
Share this post
Link to post
lol tried everything to get it from him.
he got it for nothin in a house clearance but hes still not willing to give it up.
theres also a full length or railway track about 5 minutes walk from me between the fence for the railway and the fence for the park. its length they took off and replaced and just left layin there.
tried talkin my buddy into beingin his mobile crane from london and helpin me get it lol
Share this post
Link to post
keep looking and you will find one, use what you have got for now, look out for a large chunk of steel, even a big sledge hammer head.
there is a vid of smiths in nepal making blades for kukris using a sledge hammer head between their feet as they sit on the floor
Share this post
Link to post
Score the rail with a cold set, prop it up and give it a good wack so it breaks (old school) or use a porta band to salvage pieces of that rail. Any large fabricators? A drop from a 4" plate that has had 2' circles cut out or 4' circles mane fast double horns. Even a 2" multi ball class 3 draw bar works. Your predecessors would have been thrilled with a 10# sledge or the back of a splitting maul. Lots of options.
As to the forge, build a smaller unit for general work and reserve the monster for latter. A single 3/4"-1" tuyere will give you a 6" zone at forging heat, unless you have a power hammer you will run out of heat befor you can forge that much to shape.
Just google Viking era forge and Viking era anvil to see what swords were forged on in your area 500 years ago. Yes Andricite will burn in a side blast forge with a steady air supply.
Share this post
Link to post
yeah. its not the tool that makes the blade but wielder of the hammer.
even in a pinch the concrete pillar i made to stand the anvil on is solid and steady.
evrethings on the back burner again anyway as i have added more to my workload lol
Share this post
Link to post
