MBForge Posted March 26, 2017 Share Posted March 26, 2017 Well, this transpired much quicker than I originally expected. Will definitely raise it off the ground in my next iteration (and convert to iron pipe on the ground as well). Hair dryer is my wife's. Just got a little smokey afterwards due to the "feedback" of smoke. Not sure how to remove the scent altogether, but she deserves a new one, if it comes to that, for letting me validate my first-ever [ground] forge build! Pipe is just some underground/overground conduit laying around, no more than an inch or two in diameter. Hair dryer is "attached" to the pipe with a cone made from plain old card stock paper, fitted snuggly, and packing tape to create an air tight seal. Cement "tunnel" is recycled from chain link corner posts previously set in cement. Used to "insulate" the pipe at that end, which still melted, but did not affect operation through the entire process of forging my first RR spike. Some decor blocks used in the back to concentrate the charcoal where the air comes out. Charcoal "coked" over pretty quickly. Or rather, let's just say it didn't take long at all to get that RR spike re-heated each time. Almost used up half my bucket of charcoal (still some remaining in the pit) forging this one RR spike, but this is my first time forging. RR track, or whatever that curved RR track looking thing is, needs to get mounted or replaced with a regular one because it kept tipping over. Total cost of this entire setup (forge, "anvil," RR spikes, and ball peen hammer): ~$15 Kudos to my wife for letting me borrow her hair dryer and two sons for helping with pictures and sharing the excitement of dad's new hobby More photos (and a 30s video) available at my Google Photo Album here: https://goo.gl/photos/cxvMMiBufccKDDyU8 Quote Link to comment Share on other sites More sharing options...
PapaDooks Posted March 26, 2017 Share Posted March 26, 2017 very nicely done mate. it's a jabod without the box size of them flames could probably do with a lower powered hair dryer. that should save you a bit on charcoal aswell Quote Link to comment Share on other sites More sharing options...
MBForge Posted March 26, 2017 Author Share Posted March 26, 2017 For sure. Having never done this before, I was also looking to verify the heat "capacity" of the random scraps of wood I originally created the charcoal with. Per my other post on building a Recycled Coca Cola Box Blower, I'm actually looking to repurpose a bathroom fan's blower as an attachment for a 10:1 hand crank so I can also control air flow that way while removing the need for electricity. Fun stuff! Quote Link to comment Share on other sites More sharing options...
Dave51B Posted March 26, 2017 Share Posted March 26, 2017 MB.....We all have to start somewhere. Looks like the only way you can go is up. Kudos to the wife for use of the hairdryer. Yeah you should cut back on the air. Give us a general location, and maybe you could get an invite over for a few tips. If your close by me I say come on over. Life is Good Dave Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 26, 2017 Share Posted March 26, 2017 Nicely done! One word of caution, though: PVC pipe can put out some pretty nasty fumes when it melts. Do you replace it with iron as soon as you can, but make sure that the replacement isn't galvanized. Quote Link to comment Share on other sites More sharing options...
Thats Hot... Posted March 27, 2017 Share Posted March 27, 2017 Now my back hurts just from looking at all the bending over to work this. It will heat and you can work the metal and that is all it takes.. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted May 9, 2020 Share Posted May 9, 2020 As a proof of concept, you did good. Look forward to seeing the next iteration. Quote Link to comment Share on other sites More sharing options...
Goods Posted May 10, 2020 Share Posted May 10, 2020 I know this is an old post, but for future readers, another word of caution. Keep concrete away for you forge. The heat of a forge will drive the water bonded in the concrete out in the form of superheated steam, sending concrete shards with it at high velocity. Forging is a fantastic hobby and a fun time with my boys, but I don’t want to have a session end abruptly with a trip to the ER. Quote Link to comment Share on other sites More sharing options...
