August 19, 20169 yr This chisel has been hung on the wall in the wood shop for years. First, I had Nothing! to do with getting it in this shape. It will never be sold or repurposed. Question is can it be repaired. The socket is mushroomed out and in. It's not particularly old as greenlee didn't move to Rockford IL and make hand tools until 1927 but I'd like to put a handle in it if the socket is repairable. Papy
August 19, 20169 yr That hurts to see. Some people shouldn't be allowed to handle a tool more demanding than a broom and dust pan. I'd look around with an eye for a point that fits the socket, I'd check my bull pin first but keep looking if it doesn't. I'd maybe forge a pic iron as faster and easier than hunting. Then I'd heat it up and forge it back to shape. Clean is shiny on the outside, wrap the cracks in mild steel and forge weld it. Lastly draw it down to a nice uniform shape and finish it. If you're careful you can work the socket end without running the temper out of the blade. Frosty The Lucky.
August 19, 20169 yr Some folks just don't have time to fix a tool so the ruin the tool. Chisel handles are easy to make. At least the blade is not mess up. Fix her up and don't let anyone else touch it but you.
August 20, 20169 yr I had a small chisel that looked like it and ruined it trying to fix it. Don't get distracted while its in the forge, that's what I did and I ended up burning off part of the little bit of decent socket that was left on there.
August 20, 20169 yr I'd be tempted to just forge it over a bull pin, as Frosty has suggested, and leave the split sections unwelded. A brass or bronze wire wrap around that area would look pretty classy and there would be less chance of a catastrophic heating trying for a forge weld. Of course that all depends on how good you are at forge welding. Kind of tricky there as it isn't certain whether the socket is mild of high carbon steel and, as I'm sure you know, the former welds at a higher temperature.
August 20, 20169 yr Author Thanks Gentlemen I have forge welded but not saying I'm good at it. Never even thought about a wire wrap but then that's why I posted. I don't have use for a 2" chisel very often but sure look better on the wall with a handle. I'll find a tapered pin and give it a try Thanks Papy
August 20, 20169 yr Lee Valley tools sells a wire wrapping tool called a "clamptite". It is specifically designed to, among other functions, tightly wrap thin steel wire about a broken (or partially broken), hammer handle. I have used it for temporary repairs before fashioning a new permanent handle The temporary fix works fine too. You could substitute your own choice of wire, if you so desire. For example copper wire to create a handsome fashionable color contrast for the tool. SLAG. Edited August 20, 20169 yr by SLAG added subsequent idea
August 20, 20169 yr 5 hours ago, SLAG said: Lee Valley tools sells a wire wrapping tool called a "clamptite". It is specifically designed to, among other functions, tightly wrap thin steel wire about a broken (or partially broken), hammer handle. I have used it for temporary repairs before fashioning a new permanent handle The temporary fix works fine too. You could substitute your own choice of wire, if you so desire. For example copper wire to create a handsome fashionable color contrast for the tool. SLAG. That's a cool lookin tool. I just check out the company page and they have a video showing how to use it that make me think, 'I can make one of those.' So next time I'm in the shop, if time allows, I'm gonna see if I can actually make one.
August 20, 20169 yr 7 hours ago, 51 Papy said: Thanks Gentlemen I have forge welded but not saying I'm good at it. Never even thought about a wire wrap but then that's why I posted. I don't have use for a 2" chisel very often but sure look better on the wall with a handle. I'll find a tapered pin and give it a try Thanks Papy Glad to help. Please post photo of repair when done.
August 21, 20169 yr Author That is a cool tool. Latticino I'll post a pic when it's done. Forge time is limited as my last daughter is getting married in less than a month. I take it that there are no pitfalls other than burning it up that I need to watch for? Thanks for the help Papy
August 21, 20169 yr Take care moving the rolled socket back out. Work at tool steel temperatures, just in case. Keep the blade side cool, if possible, re heat treat if not. Don't water quench, just in case is all high carbon. That's all I got, good luck.
August 21, 20169 yr I change my thoughts and vote for wire wrapping. Brazing to fix it in place would look snazzy too. Does the "Clamptite" work like a Yankee screw driver? If so I've seen them used to safety wire nuts and such especially on aircraft. Very handy tool. Frosty The Lucky.
August 28, 20169 yr On 8/19/2016 at 6:33 PM, Frosty said: That hurts to see. Some people shouldn't be allowed to handle a tool more demanding than a broom and dust pan. Frosty The Lucky. Conditions like this are why I refuse to let production folks use our tool fab shop unsupervised, even though the majority are company property. May I make a sign with your quote?
August 29, 20169 yr By all means, please do. I'm sure I'm not the first person to say that. Frosty The Lucky.
