Ethan the blacksmith Posted April 16, 2016 Share Posted April 16, 2016 Hello again i have been asked to forge some timber framing slicks. They are mild steel with a fire welded blade on the back. So I was wondering what temper colour or temperature I should camper the blade two, assuming it is and for oil quenching steel. And should I temper it in an oven to get the temper even throughout, since the blade will Where away, be sharpened and eventually get shorter? thoughts ethan Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 16, 2016 Share Posted April 16, 2016 You should temper it to the proper temperature that the high carbon alloy piece requires for it's use by the person who is commissioning it. As you don't mention what alloy the edge will be how could we possibly give even a guess as to what the proper temperature it should be? As we are not the person commissioning it how are we supposed to know if they like their tools softer and tougher or harder yet more brittle. Shoot you don't even tell us if it will be used on oak or pine... The mild steel body will not need tempering if it's a true mild steel so whatever method produces an even temper on the edge part will work. Quote Link to comment Share on other sites More sharing options...
Ethan the blacksmith Posted April 16, 2016 Author Share Posted April 16, 2016 Very sorry i should have put, it was a farriers rasp. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted April 16, 2016 Share Posted April 16, 2016 as he said, if we dont know what grade of steel .... good luck Quote Link to comment Share on other sites More sharing options...
Bo T Posted April 16, 2016 Share Posted April 16, 2016 Having googled timber framing slicks, it seems that they are not impact blades (ie axe), but more like scrapers. So maybe a little harder than an axe, if you have made one with a similar rasp as a bit? Also, you don't need a softer back for pounding on so a uniform temper? Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 16, 2016 Share Posted April 16, 2016 Ethan: The guys aren't being mean we can't possibly give you specifics without knowing specifically what you have and how it's going to be used. Slicks are USUALLY straight edged chisels and pushed. However I know a couple guys who build log homes professionally who strike them. So there are different forces being applied, heck I've seen guys pry with them beyond lifting chips. Do you know how to test HC steel for it's properties and suitability for what you want to use it for? First off you need to ask the customer how he intends to use the slick, "hand, (push) or struck? Then grind the teeth off the rasp and test it. Bring it to critical temp and quench it. Once quenched shine it up and begin SLOWLY heating one end and watch the temper colors as they "Run" the length of the rasp and stop it in water when you have a full range of colors, black to palest straw. Now, knowing what the customer wants you can clamp the test coupon in the vise with a temper color just exposed above the jaws. Place a rag over the coupon to catch pieces of shrapnel if it shatters. This is a "Scatter shield" and a basic safety precaution like the PPE you WILL be wearing. Now, give the coupon a rap with a hammer and note the reaction. Tempered Black should bend. If it bounces the hammer this is probably more than a simple alloy. Tempered blue should probably bounce the hammer and bend rather than break. As you test closer to the untempered end of the blank you will note a progression of hardness and can select the hardness that suits your customer's needs the best. There is NOTHING about this test that will tell you more than the very basic info. What it tells you is what I feel is the most important though, "how it will react under impact" Basically what it MIGHT be good for and how to get it as close to the desired properties. I can't tell you how to treat what you have so instead I told you how to find out yourself. How's dat for an answer? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Ethan the blacksmith Posted April 17, 2016 Author Share Posted April 17, 2016 thank you all for the feed back! I will show you a finished product! Quote Link to comment Share on other sites More sharing options...
LawnJockey Posted April 17, 2016 Share Posted April 17, 2016 Slicks are used like planes. In fact they are nothing more than a plane without a body and shaped like a big chisel. They are used in timber framing and wood boat/ship building. They are usually used to take off a lot of material quickly but there is nothing equal to them when you have to do fine work up to an edge as in a place where the body of a plane would prevent you from getting. Please post photos as you progress, particularly the shaping of the socket. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 17, 2016 Share Posted April 17, 2016 "Slicks are used like planes" so they are used to hammer brads in? I have seen this done with a plane before. I have seen slicks that never had anything more than the heel of the hand impacted on them and I have seen ones hit with a 4# singlejack. I try to be very careful of ascribing how some unknown person will use an item without talking directly to them... Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted April 22, 2016 Share Posted April 22, 2016 I have a large old slick made in England, and it has a slight bend in the center of the blade length. This is probably done, so if the non-beveled edge is against the wood, the workers fingers are further away from the workpiece. Quote Link to comment Share on other sites More sharing options...
Rashelle Posted April 22, 2016 Share Posted April 22, 2016 There is one like Frank describes pictured in one of the wood boat tool making books. Can't think of it off hand at the moment. Quote Link to comment Share on other sites More sharing options...
