September 17, 201510 yr Hey guys first post here. I'm in the process of building a brake drum forge. I'm using a brake drum off of a semi that I have notched. The hole in the middle is quite large, nine inches or so, and I need to cover it. I am about to cut the top off of a steel drum that I will use for charcoal. Will the top be thick enough to handle the heat of the forge if I were to cut out a circle to lay in the bottom? Or should I go for a heavier metal plate?It doesn't look like it in the pictures but there is still a 3 inch lip for the bowl.
September 18, 201510 yr Even small brake drums are a PITA, look at Glenn's "simple 55 forge" and "sideblast 55 forge"you can only work about 6" by hand so you need to keep the fire ball down to 6-8"I use OTR truck drums for landscape planters, make nice giant pots. Edited September 18, 201510 yr by Charles R. Stevens
September 18, 201510 yr Author Just the one slot atm, burnt through 2 discs cutting that out I have to pick up more tomorrow.
September 18, 201510 yr Unless you're planning on doing some really heavy forging a semi brake drum is just an efficient way to waste coal. Bigger is NOT necessarily better. Semi drums don't make good tool stands either.On the other hand making a couple into a potbelly stove thingy might be a treat.Honestly Semi drums are more trouble than they're worth and as forges they're not worth much at best.Frosty The Lucky.
September 18, 201510 yr Semi drums don't make good tool stands either. Frosty The Lucky.that there is something I have been trying to tell people for years
September 18, 201510 yr that there is something I have been trying to tell people for years I actually have a drum and was thinking about using it as a base for a grinder since I would need it mobile. What is the downfall as a base? seems like it would be heavy enough.
September 18, 201510 yr For a grinder or something like that by the time you get it to the desired height its a little tippy.We use one at work for our hydraulic hose cutter it works....ok, but like I said it can be tippy. I would guess pressing on a grinder would be a recipe for disaster, just from my experience.
September 18, 201510 yr Too heavy to be easily portable and not heavy enough to be rigid in use. A base that you can stand on---say a disk of 1/4" plate will make a more stable grinding platform. Or there is the 55 gallon Barrel technique: mount a top to a 55 gallon barrel with an opening for a hose and with a side bung on the barrel down near the bottom. Mount the grinder on the top. Fill barrel with water for use---over 400 pounds! Drain to move---barrels are fairly light empty. This is what I use for one of my portable postvises.
September 18, 201510 yr 24" harrow disks work well, you can stand on the disk, its light and rolles easy. But i sill think placing one on each side of the front walk, fill with planting soil, and plants. Ever checked the price on cast iron planters?!
September 18, 201510 yr Exactly. Semi drums are heavy tippy trip hazards, not what I want next to a power tool that can grab and remove body parts from me.I like a round piece of flat plate for pedestal stands. Stable and easy to move without anything you can trip over. Noe even the edge if you grind a little bevel on it or just angle the torch when you cut it. Simple, effective, portable but most important, SAFE.A friend sent me a pic of someone making wood stoves from wheel rims recently. Years ago, when I walked past the scrap bucket (old loader bucket) at the heavy duty shop and saw scrapped semi drums regularly, I considered turning a couple into a Pot Belly stove thing. Roll a piece of say 10ga. or heavier sheet into cylinder of find a piece of pipe that fit. Weld a 18"-24" or so of said pipe to the open end of a semi drum facing up and another drum on top facing down. Make and install a fire door and ash door in the pipe. A bolt on stove pipe jack on top (said pictures of wheel rim stoves showed a nice square plate with stove jack for tops) and an air grate and draft on the bottom one. Rig a stand and VIOLA coal/wood stove and something actually useful to do with scrapped semi drums!I never built one because I lived in a mobile home at the time and didn't want to burn myself out, especially if I were sleeping.Frosty The Lucky.
September 18, 201510 yr Even new harrow discs don't seem to be very expensive (import). Handy shape to have in an arsenal of parts and pieces. 20" x 5mm thick runs about 19 bucks. I remember seeing one as a forge pot once but never looked into whether that was practical. http://www.agrisupply.com/plain-disc-harrow-blades/c/4500011/
October 24, 201510 yr I too have a drake drum off of a semi truck, but I'm not quite sure how to rig up this huge thing. I doubt it's worth the trouble to make a forge out of it. Edited October 24, 201510 yr by RangerGord hit enter too soon.
October 24, 201510 yr Semi brake drums make inferior forges to regular sized ones with a simple sheet metal fence added to them. Remember you need to be able to put your work piece in horizontally in the neutral to reducing area of the fire so to do that in a semi drum you will need to cut large opposing slots in it. Much easier to take a regular sized drum and put a piece of sheet metal around the inner rim with the slots in it.
October 24, 201510 yr Semi drums aren't good for much other than semi brakes. If you really need to use one though how about a yard fire pit? They look like a great bit of salvage, I think all of us have grabbed something because it was big and BIG is better right? Not.A brake rotor from a family sedan makes a much more useful size fire pot. A washing machine door makes a good forge table and you can make a hole for the rotor with a chisel.Easy peasy ad you don't have to work to think of something for the truck drum.Frosty The Lucky.
October 25, 201510 yr They make good flower pots... Ditche the drum idea, look at the "simple 55" and buy a oil drain pan
October 25, 201510 yr Or there is the 55 gallon Barrel technique: mount a top to a 55 gallon barrel with an opening for a hose and with a side bung on the barrel down near the bottom. Mount the grinder on the top. Fill barrel with water for use---over 400 pounds! Drain to move---barrels are fairly light empty. This is what I use for one of my portable postvises.I like that idea as a portable vise stand. I hadn't thought of that one before.
October 25, 201510 yr I've seen photoes of smiths using nail kegs as anvil stands in the mexican civil war, fill keg with sand, place anvil, work, dump keg and move the fore waggon.
October 25, 201510 yr They make good flower pots...Ditche the drum idea, look at the "simple 55" and buy a oil drain panI hadn't thought of a planter, that's 2 things a semi truck drum is good for besides stopping trucks that is.Frosty The Lucky.
October 25, 201510 yr have you seen what they want for a cast iron flower pot?! On drum, one concreat flagstone and $5 worth of pansies....
