June 27, 201412 yr Anybody have a idea what to use this plate for? Its 1"thick and Stainless Steel but I'm not sure what grade.
June 28, 201412 yr Is it flat? Use some spray on glue to attach a bit of sand paper and use if to sand things flat. ;)
June 28, 201412 yr If it's straight, use it for a lay-out table and setting 4 legs true. If it's not straight, you can use it for anything, some mentioned above.
June 28, 201412 yr Griddle, unless it is a free machining alloy with lead added. Tortilla press for big tortillas, counterweight, non rusting boat anchor, sculpture, target, gong,
