Posted
the lower half acts as a receiver on a compressor, as you pump it fills the lower section compressing the spring and meaning you can get a steady stream of air, there is no mechanical linkage between the 2 chambers
Posted
the lower half acts as a receiver on a compressor, as you pump it fills the lower section compressing the spring and meaning you can get a steady stream of air, there is no mechanical linkage between the 2 chambers, there is also a spring inside the top chamber.
have seen a few of these bellows before.
Posted
Some smaller bellows like this were used to drive tiny dentist drills. Should work fine for a small forge. Make sure to have a short air run and to avoide any tight right angles
Posted
Bought a similar bellows at BAM conference from Bob Alexander a year or 2 ago, but haven't used them.
