plane_crazzy Posted January 1, 2013 Share Posted January 1, 2013 I am working on a portable fire ring. I have made a couple of them already but I need to revise my sides thickness. I used 1/8" on the last one and think I could still lighten it up some. I have looked at some sheet metal but I am iffy on how well that would hold up. The rings are about 24" Square with angle iron in the 4 corners. Anyone have some experience on what to use? Link to comment Share on other sites More sharing options...
rthibeau Posted January 1, 2013 Share Posted January 1, 2013 up around here in Michigan most use sections of that corrugated looking culvert pipe....about sheet metal thickness and the corrugation adds strength Link to comment Share on other sites More sharing options...
Frank Turley Posted January 2, 2013 Share Posted January 2, 2013 Pardon me, but what is a fire ring and if it's a ring, why is it square? Link to comment Share on other sites More sharing options...
Steve Sells Posted January 2, 2013 Share Posted January 2, 2013 Pardon me, but what is a fire ring and if it's a ring, why is it square? While many use a ring of stones, the metal ring is nicer in a permant installations, like a park or camp ground, even the back yard. Helps to keep burning things in, and childrens feet out. Link to comment Share on other sites More sharing options...
pkrankow Posted January 2, 2013 Share Posted January 2, 2013 My ring is stout sheet metal, about 1/16 inch (#16?) or maybe a little thinner, with decorations pierced into it. It has 1/2 x 1/8 bar stock welded to the top and bottom as rims, and the ends of these bars have joggles so the rim forms a nice circle from 4 pieces. The 4 pieces are fastened with 1/4-20 bolts welded on as studs. I bought it at the store, it is a rather inexpensive unit. The bolts are welded onto the back of the bars, and at least one stud has broke. I probably will have to make a repair to several places on it next time I need to move it, but it hasn't moved in a couple years since it is big enough to just clean with a shovel being about 3 ft across. At my mother in law's we use cinder blocks. The bottom row is on the sides so air goes through, the top row is upright to contain the fire better. 5 bricks per side with an overlap. The top row is running bond fashion to the lower row. Every few fires a brick crumbles, but it works well for burning debris and later roasting marshmallows, hot dogs, and brats. The fire dept has looked at it and gave their approval too. Phil Link to comment Share on other sites More sharing options...
yesteryearforge Posted January 2, 2013 Share Posted January 2, 2013 Mine is 10 gage ( approx 1/8 ) 304 stainless steel with anvil shaped cut outs around its perimeter ( approx 4 ft in dia. ) and about 8 inches deep. Link to comment Share on other sites More sharing options...
Dodge Posted January 2, 2013 Share Posted January 2, 2013 I am working on a portable fire ring. I have made a couple of them already but I need to revise my sides thickness. I used 1/8" on the last one and think I could still lighten it up some. I have looked at some sheet metal but I am iffy on how well that would hold up. The rings are about 24" Square with angle iron in the 4 corners. Anyone have some experience on what to use? Unless your building tiny camp fires, you might consider a larger ring. Nice (pronounced "safer") to have a bit of a buffer between fire and ring. Link to comment Share on other sites More sharing options...
Robert Yates Posted January 2, 2013 Share Posted January 2, 2013 I use an old tractor Hub / the rim it is perfect. Sam Link to comment Share on other sites More sharing options...
Private Entrance Posted January 2, 2013 Share Posted January 2, 2013 I'm a fan of the classic metal washing machine tub. Use bolts and/or fab a tripod stand and you are good to go. Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted January 3, 2013 Share Posted January 3, 2013 I like 1/8"" as it is a good balance between weight and durability. But then again I have a 22.5" over the road truck rim (with a 22" harrow disk in side) and an old cast-iron bathtub tasked for fire pits in my yard. I carry a 1/3 55 gallon drum in the horse trailer. Link to comment Share on other sites More sharing options...
John McPherson Posted January 3, 2013 Share Posted January 3, 2013 A local Veteran's group has one made out of the end of an old oil or water tank for doing flag retirements: portable in the fact that it is on a sled that can be pulled by a tractor. 3/16" tread plate seems to be the smallest size that holds up without additional bracing, uneven heating will cause warping no matter what you do. Link to comment Share on other sites More sharing options...
plane_crazzy Posted January 7, 2013 Author Share Posted January 7, 2013 sorry for being slow on the reply, been a busy week. I like the square design because it can easily be taken apart and it makes it easier to make a support for a stainless steel grate across the top to cook on. the 24" is a request, I prefer the 30" that I have, but I have a request for one that is smaller. Link to comment Share on other sites More sharing options...
Borntoolate Posted January 8, 2013 Share Posted January 8, 2013 Pardon me, but what is a fire ring and if it's a ring, why is it square? I think I might know what you are talking about but a pic would be nice?? Link to comment Share on other sites More sharing options...
plane_crazzy Posted January 8, 2013 Author Share Posted January 8, 2013 Sure Born, I will get ya one tomorrow Link to comment Share on other sites More sharing options...
plane_crazzy Posted January 10, 2013 Author Share Posted January 10, 2013 This is the one I made for myself, but follows the same rough idea. Link to comment Share on other sites More sharing options...
Please sign in to comment
