Loneforge Posted August 1, 2012 Share Posted August 1, 2012 1095,15N20 twist patern with Nickel Silver guard. Brass and black Micarta spacers. Handle material I was told is Ironwood? Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted August 1, 2012 Share Posted August 1, 2012 REally nicely done.. Quote Link to comment Share on other sites More sharing options...
TheoRockNazz Posted August 1, 2012 Share Posted August 1, 2012 Nice utility knife, did you forge the damascus yourself? Quote Link to comment Share on other sites More sharing options...
Rhettbarnhart Posted August 1, 2012 Share Posted August 1, 2012 WOW..... Quote Link to comment Share on other sites More sharing options...
quint Posted August 1, 2012 Share Posted August 1, 2012 Thats real nice and smooth. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted August 1, 2012 Share Posted August 1, 2012 Simply Elegant!!! - your on a one way trip into the dark side. :D Quote Link to comment Share on other sites More sharing options...
Loneforge Posted August 2, 2012 Author Share Posted August 2, 2012 Thanks for the compliments. Yeah Theo those are my welds. Quote Link to comment Share on other sites More sharing options...
iron woodrow Posted August 2, 2012 Share Posted August 2, 2012 how is the tang done? did you forge it into a point and force it into the wood? or is the handle two halves seamlessly glued? Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted August 2, 2012 Share Posted August 2, 2012 Looks like a hidden tang to me. Nice damascus and very nice knife overall. How many layers? Quote Link to comment Share on other sites More sharing options...
Loneforge Posted August 2, 2012 Author Share Posted August 2, 2012 56 layer twist with a hidden tang. I notch the tang so the the epoxy grabs. I leave the tang fairly staight at the end woody. I drill with small bits then go larger till the holes join up. Put a slice of sand paper over the end of a file and clean up till it slides on easy then epoxy it all together and clamp. Thanks for the compliments guys it truly inspires! :) Quote Link to comment Share on other sites More sharing options...
ianinsa Posted August 2, 2012 Share Posted August 2, 2012 A great looking blade! Quote Link to comment Share on other sites More sharing options...
Robert Yates Posted August 2, 2012 Share Posted August 2, 2012 Awesome blade ,fit and finish Quote Link to comment Share on other sites More sharing options...
Dick L. Posted August 3, 2012 Share Posted August 3, 2012 Great job on the entire piece ! Fit ,finish and design are all top notch. Did you hammer the welds or use hydraulic press? I've only done cable with a hammer so far with decent results but I have seen billets forged with hydraulic press in person and it just looks so easy. Back to the point of the post Great Job !! Thanks for sharing, Dick Quote Link to comment Share on other sites More sharing options...
Loneforge Posted August 3, 2012 Author Share Posted August 3, 2012 Thanks Dick, they are hammer welds. I know no other way. :) Quote Link to comment Share on other sites More sharing options...
Loneforge Posted August 7, 2012 Author Share Posted August 7, 2012 And here's the sheath Quote Link to comment Share on other sites More sharing options...
mperez76er Posted August 8, 2012 Share Posted August 8, 2012 sure is pretty Quote Link to comment Share on other sites More sharing options...
Robakyo Posted August 13, 2012 Share Posted August 13, 2012 Outstanding work! Your pattern is classy and tight. The profile is really nice too. The lines just flow smoothly. Robert Quote Link to comment Share on other sites More sharing options...
iron woodrow Posted August 13, 2012 Share Posted August 13, 2012 powerful great work. Quote Link to comment Share on other sites More sharing options...
