June 1, 201214 yr After a lot of work, I have completed my mechanical power hammer. This is how I wanted to construct my power hammer, very adjustable. The most unique feature is the clutch mechanism. It consists of two automotive brake rotors. One is fastened to the crankshaft and the other is driven by the motor and free to rotate on the crankshaft. Between the two brake rotors is a 3/8" thick piece of clutch friction material. The footpetal force is transfered through a clutch linkage to a Chevy small block V-8 throw-out bearing that pushes the rotors together. I credit Ray Clontz [designer of the Tire Hammer] for encouraging me to build a power hammer instead of a treadle hammer. The auto rotor clutch system is inspired by Ray's own personal power hammer. The brake rotor disk clutch works very smoothly. For those interested, I have hastily posted some photogrphs and notes on my website. I am running the machine at a maximum 2.6 impacts per second until I am more comfortable operating it at a faster speed. A power hammer radically improved my blacksmithing experience. I can't guess how many more times it moves hot metal than I can by hand. Fred
June 1, 201214 yr Amazing! Show us videos now! haha, but really that is some great work and Im sure everyone would love to see it running.
June 2, 201214 yr Fred, I really like the clutch setup on your hammer beautiful hammer almost to pretty to work on. :lol:
June 2, 201214 yr Wow with a capital W.like others i would love to see vid of the hammer working. thanks for posting,and the link.
June 2, 201214 yr Good Morning Fred, I very much enjoyed the link to your 'Rose Engine'. I believe they were created to satisfy idle hands and active minds. I love it!! Neil
June 3, 201214 yr Author Ray Clontz has used an automotive clutch on his personal power hammer since he built it in the early 2000's. Initially, he had to rework the clutch hub to fit the 1-3/8" crankshaft. I think he sprays his with WD-40 to get the performance he wants. I looked for an auto clutch plate that would fit my brake rotors until I ran across the friction material and realized I didn't need the hub of an automotive clutch. I drilled a 1-3/8" hole in the middle of the friction material with an old Forstner bit. I was planning to glue a bronze bushing in the friction material and may yet do that. I don't really like the friction material rotating directly on the crankshaft. I think auto clutch friction material has a good bit higher coefficient of friction than the piece I used. The clutch on my machine is very smooth. I cannot tell from foot pressure alone exactly at what point it fully engages, only by the frequency of hits. The disk rotors are 10.8" diameter with a little over 2" of friction surface. I am using a 7.5"x7.5"x3/8" piece of low coefficient of friction material between them. The diagonals of the square of the friction material just reach the edge of the disk rotors. I am curious what the effect would be to use a full 10.8" diameter piece between the rotors. It would more than double the friction surface area. If it halved the foot petal pressure to engage, then it would only take 10 pounds of foot pressure to engage. It would be a little more complicated to route the clutch linkage to reduce the foot petal leverage if that turned out too light. At some point, I may spring for the $70 for a piece of friction material big enough to get a full 10.8" diameter. I'll take a video in the next day or so of the hammer in action and post it.
June 3, 201214 yr You can cut the piece you have into sections and rivet or bolt them to one rotorwith countersunk head rivet/bolts. I would put it on the one with the belt on it. My Depew has the same basic clutch as the 2 rotors, friction mat. fastened to one disc once it got polished up has amazing control. The front side of the driven rotor is just begging for a brake pad. It would be so easy to install with great linkage you have already
June 3, 201214 yr Very nice. While I haven't seen a clutch like that on a home made hammer I've seen similar on mechanical winches on drill rigs, geotech drills, not oil. What is the anvil base? It sure looks like a dandy. Frosty The Lucky.
June 3, 201214 yr Author Peacock - One of the watchers of this project has been pressing me to rivit on brake pads just like you suggest. Since the clutch plate was the last operation, I decided to utilize the friction material with as little effort as possible. I think I could still cut up the piece and rivit it on. If it keeps working as nicely as it has so far, I don't think I'll mess with it. Originally, I was planning to put a brake on it but never worked the detail out. I even faced off the front side of the rotor that is fastened to the crankshaft. Even though, the brake rotor assembly is pretty heavy, the machine doesn't have enough flywheel effect to keep turning when the clutch is disengaged like a tire hammer does. When I let off the clutch it stops. This may be more of an issue if I speed the power hammer up.
June 3, 201214 yr Author Frosty - I drilled and threaded a 16"x30"x1" plate for the anvil base. It sits on a piece of rubber horse stall mat. So far it is not walking on the concrete. I'm a little surprised, since I have about 1/4" per foot slope on the concrete.
June 3, 201214 yr Nice bit of engineering, that is a very cool little hammer.....How bout a video? I rebuilt a Perfect PH years ago and the thing I liked most about it was the clutch. It's real similar to a LG line shaft type only there's no cones involved, just flat surfaces coming together that showed almost no wear as opposed the the rest of tired ol thing. Metal to metal and just a spot of oil and no need to ever jack around with wood inserts or any of that. The travel distance needed to engage the two is microscopic compared to a LG plus run on due to clutch bearing wear was eliminated. I thought to myself hmm, brake rotor to flywheel or rotor to rotor....could work......and went on to building air hammers...... :D
June 5, 201214 yr Frosty - I drilled and threaded a 16"x30"x1" plate for the anvil base. It sits on a piece of rubber horse stall mat. So far it is not walking on the concrete. I'm a little surprised, since I have about 1/4" per foot slope on the concrete. Sorry, I meant to ask what the sowblock is. Brain fart on my part. Frosty The Lucky.
June 5, 201214 yr Author Sorry, I meant to ask what the sowblock is. Brain fart on my part. Frosty The Lucky. The die is a 1.5"x1.5"x3" piece of 4140 welded to a 4"x"4x1" piece of hot rolled steel. I heated up the die and welded it to the plate with "Missile Rod". Then I heated the die & plate to cherry red and let it cool slowly in the propane forge to stress relieve it. I have not yet hardened the die.
June 5, 201214 yr one thing you can think about is using brake blocks...the friction liner is segmented so you can use a strip of material the size(wide) and cut it into pieces and rivit/bolt it to the disc..on the rigs we used brass bolts with steel nuts, then cut and peened the brass screws over so the nuts won't back off...then when it was time to reblock we pulled the brake bands and used a hammer to break the studs off by shearing the brass bolts.didn't take long to reline if you had the brake blocks there pre drilled and enough bolts/nuts. nice lookin hammer,jimmy
June 9, 201214 yr I really like the clutch set up. what kind of supplier supplies high friction material? is it asbestos based? I have most of the bits for a home made mechanical hammer and this is quite an inspiration. I could not get myself to build a slipping tire or slipping belt clutch as they seem such a poor second to the steel on steel cone clutches I am used to in UK mechanical hammers . this seems like a great engineering alternative. I would personally want a little more rotating weight in the drive wheel. great job.
June 11, 201214 yr Author basher, The brake and clutch lining friction material I used has the lowest coefficient of friction [0.14] of the several choices at McMaster-Carr [the highest offered is 0.55]. I do not know what the material is made of. It sure does work nicely. I would not want a higher coefficient of friction and may not want any more friction material contact area. McMaster suggested the low coefficient of friction for "smooth stops" [brakes] and the high coefficient of friction sheets "provide immediate engagement". I think a little more rotating mass would be desirable. But, if you have much more rotating mass then stopping the hammer becomes an issue and some sort of brake would be desirable. Fred
June 11, 201214 yr Author I'm planning to upload a video when I figure out the whole process. It doesn't seem like this site allows uploading of video files. This 1000 pound total weight mechanical power hammer with a 660 pound anvil bolted to the 136 pound piece of steel base plate is slowly walking on the slightly sloping [1/4" per foot] concrete floor. The 660 pound anvil is 18.9 times the 35 pound hammer weight. I think at least 20 times is a good ratio. I've been updating my power hammer photos and notes at http://ornamentalroseengine.com/smith/hammer Fred
June 13, 201214 yr Author I solved the issue o my power hammer walking across the concrete. In the hast of wanting to try out my new hammer, I never installed the braces between the anvil and the post. I installed the braces yesterday and it made the machine much more solid and it appears it is not moving at all. I think I'm completely finished with the power hammer. Power hammer photos and notes, http://ornamentalros...om/smith/hammer
June 14, 201214 yr Thanks for all the detailed wonderful photos! a very nice machine. I would love to see video also I hope you can get it sorted!
