CurlyGeorge Posted September 17, 2011 Posted September 17, 2011 I have a customer wants me to make a 6 candle chandelier, that will also work setting on a table. This is what we came up with. I used 1" X 1/8" flat strap and scrolled the ends. Since it has three straps, stacked one on top of the other, I had to offset each scroll/leg so that it would set firmly on a table. This is the way it turned out. The center rod is riveted on the bottom. Tomorrow, I will make the candle spikes and the 2 1/2" copper drip pans. I also made a long S hook to use to hang it from. I think it is turning out pretty good, so far. :)Comments or suggestions? Quote
Larry H Posted September 17, 2011 Posted September 17, 2011 nice rivet job on the hook, why not put more scrolls under as feet, it might add to the esthetics of the forged piece Quote
CurlyGeorge Posted September 17, 2011 Author Posted September 17, 2011 I could have riveted a scroll under each top scroll. The reason that I didn't is..............I had a Senior moment and didn't think of that. That is a really good idea and I will definitely remember that one. Thank you for the suggestion. Quote
CurlyGeorge Posted September 17, 2011 Author Posted September 17, 2011 (Light bulb lighting up) Yes it would!! GREAT idea. Thanks. :) Quote
trying-it Posted September 17, 2011 Posted September 17, 2011 Hey bro, just consider this 1 a mockup trial and error model. Get it done real nice and puuurrrty looking ........ then ship it here for some thorough in use testing! Then make the 2nd 1 for the customer. (You and your senior moments, hope they aint contagious 'cause I doubt if I have been vaccinated for the condition) :P Quote
CurlyGeorge Posted September 17, 2011 Author Posted September 17, 2011 Stan, I think that this one has to go to the customer. I may try making another one using some small scrolls for the legs. But I'm running out of time before my next demo and have to build up a little stock. Thanks for the offer to "test" it, though. :D Quote
beth Posted September 17, 2011 Posted September 17, 2011 its great curly george! it looks forged i dont think you need no feet - you were going to hang it no?? on the s hook? i like it as it is :) Quote
CurlyGeorge Posted September 17, 2011 Author Posted September 17, 2011 Thank you, Beth. The customer wanted to be able to hang it or set it on the table. I have enjoyed this project and have also learned a few things along the way. I may take those lessons and make another one with some minor changes. :) Quote
Marksnagel Posted September 17, 2011 Posted September 17, 2011 Nice design George! I like it. Do you have a balance problem with it when it hangs? I would be afraid that uneven candles may make it tip to one side or the other while hanging since it is hanging from a central point. I had that problem before with a two candle hanger. Mark <>< Quote
CurlyGeorge Posted September 17, 2011 Author Posted September 17, 2011 That's a thought, Mark. This is the first one like this that I've made. I'll let the guy know to watch for that. I had problems with the copper cups. I was going to solder them onto the bottom of the pins. I drilled a hole in each cup, cleaned each pin down to bare metal and still couldn't get the solder to take. I think that I just don't have the right equipment to do the job correctly. So I made drip pans out of black sheet metal. Tomorrow I will weld them onto the pins. :) Quote
CurlyGeorge Posted September 18, 2011 Author Posted September 18, 2011 OK. Here's the finished project. I ended up using steel drip pans and slipped them down over the pins and welded them on. Mark, I tried to test for the balance. I laid a candle on 3 of the cup, on one side of the chandelier, and left the 3 on the other side without a candle. It didn't seem to tip very much at all. It is pretty heavy and I think that probably made the difference. Thanks for all the comments. Quote
J W Bennett Posted September 18, 2011 Posted September 18, 2011 Looks good! Anytime I am fastening Copper to steel and can't use a rivet I braze it on. But It looks good with steel pans.The customer should be very happy. Quote
Mulekick Posted September 18, 2011 Posted September 18, 2011 I think it looks good, Nice work there Curly. Quote
Frosty Posted September 18, 2011 Posted September 18, 2011 Hey bro, just consider this 1 a mockup trial and error model. Get it done real nice and puuurrrty looking ........ then ship it here for some thorough in use testing! Then make the 2nd 1 for the customer. (You and your senior moments, hope they aint contagious 'cause I doubt if I have been vaccinated for the condition) Don't worry Trying Guy senior moments are in your future. If that is you don't make a b-a-d mistake somewhere. I've been dealing with Mental Pause for a while now and the best I can say about it is, now I have an excuse. Frosty the Lucky. Quote
Frosty Posted September 18, 2011 Posted September 18, 2011 Sorry George, I got involved in joshing Trying It and forgot to tell you how handsome a piece of ironwork you've produced. I'd be proud to have it in my home. Frosty the Lucky. Quote
teenylittlemetalguy Posted September 18, 2011 Posted September 18, 2011 Looks clean and practical and very nice. For the given design restrictions you faced I think it is perfect. :) Quote
MRobb Posted September 19, 2011 Posted September 19, 2011 Very nice CurlyGeorge! I really like your design. NIce clean lines. I'd like to copy your design if you don't mind. Thanks for posting. MItch Quote
CurlyGeorge Posted September 19, 2011 Author Posted September 19, 2011 Be my guest, Mitch. Thank you. :) Quote
CurlyGeorge Posted September 27, 2011 Author Posted September 27, 2011 Well, went to the camp for the weekend, and delivered the chandelier. He was really happy with it. But the only candles that he could come up with was 3" diameter candles. The drip pan was only 4". Needless to say that he had some interesting patterns of melted candle hanging from some of the drip pans. He hung it over a fairly large table, so no one got dripped on. But he's gonna look for some smaller diameter candles. Quote
Steve McCarthy Posted September 27, 2011 Posted September 27, 2011 I liked it before, but seeing it in use I really like it. Good job Curly. Quote
