New Acquisitions
A while back I mentioned to a good friend of mine that I was looking for some blacksmithing equipment. He is a veterinarian so I figured he would know all the farmers and may know of someone wanting to part with some unused items. I told him what I was looking for and when I described a leg vise he mentioned that he has one he bought a couple years ago for $15 and I can have it for the same $15 investment. We wandered over to his barn and he rummages around in a pile of stuff and pulls out exactly what I was looking for. The jaws open and close but it turns a little hard. I am hoping that a good cleaning accompanied by a dose of WD-40 will have the screw turning more easily. The jaws seem to be in pretty good alignment but if anyone has any suggestions on how to fine tune them I would appreciate it.
post-9099-075342300 1282582021_thumb.jpgpost-9099-080942700 1282582022_thumb.jpgpost-9099-088851200 1282582023_thumb.jpgpost-9099-092909700 1282582024_thumb.jpg
I also mentioned my hunt for equipment to my father-in-law who is a retired farmer. He said he thought there was an old forge back in his tree belt. A few weeks later he called, a bit excited, to tell my wife that he had got the forge out of the trees and he thought there might be an anvil there too….at least it was a “square metal thing” sticking out of the ground. Last weekend we went up to the farm and he showed me the forge. The mosquitoes were bad so other than taking a few pictures I didn’t give it a thorough inspection; that will have to wait until I get it home and into the shop where I can work on it. It will need a lot of work. Three of the legs need some serious attention, the pipe on the original legs is seamed but I am thinking of just using black pipe to extend the legs for now and work on getting back to “original” condition later. The fire pot is showing some rust…not sure how extensive…and the tuyere looks to be missing as well. The drive wheel for the blower doesn’t turn by hand, hoping that I can get that disassembled and freed up, and I am not sure about the blower itself….looks good from the outside but need to get it apart and cleaned up as well. This definitely will be a bit of a longer term project I am thinking. Is anyone familiar with this type of forge or the manufacture? I would be interested in more information.
post-9099-049038800 1282582078_thumb.jpgpost-9099-092776000 1282582079_thumb.jpgpost-9099-082978500 1282582080_thumb.jpgpost-9099-050622700 1282582076_thumb.jpg
The square metal thing he was talking about was only loosely in the ground so I got a shovel and dug it out. It isn’t a traditional anvil but he tells me they used to slide it over a fence post and use it to bend/straighten stuff. It is heavy but hollow. I am not exactly sure what it is but the open end isn’t squared off so I am thinking it is broken off of some heavy duty machinery. Any guesses, educated or otherwise, are welcome.
post-9099-073676500 1282582113_thumb.jpgpost-9099-071291700 1282582114_thumb.jpgpost-9099-073829600 1282582115_thumb.jpgpost-9099-061921000 1282582112_thumb.jpg
Finally the most important addition around the house; my new daughter. Elyse was born July 29, 2010. Her big brother Isaac (15) and big sister Adele (2 ½) are happy to have her. Adele really loves her little sister and is very helpful, sometimes tries to be too helpful. Isaac has been a big help around the house as well. My wife is a photographer and the day we got back from the hospital had to get Elyse into the studio we built in the basement to get some shots taken.
post-9099-073555100 1282582155_thumb.jpgpost-9099-008678400 1282582154_thumb.jpgpost-9099-093711800 1282582154_thumb.jpg
Sorry for the book, just excited to share my new additions with the IFI family.
You might want to soak that vise in ordinary household vinegar for about 2 days. That and a little wire-brushing will remove nearly all the rust and then a bit of grease and some wd-40 and you'll likely be clamping smoothly. Clean up the edges a bit with a flap wheel and see how the jaw fit is... if you want to tighten it a little I think I'd just grind the high spots back a little bit on the faces. The fit is not very critical, most of what you'll clamp in it is hefty chunks that do not challenge the perfection of the jaw faces.
At some point it may become cost effective to get a plastic trash can and fill with water and a couple of gallons of muriatic acid sold as brick cleaner at hardware stores---you can dilute it way down and have a slow de-ruster but cheaper than 20 gallons of vinegar.
As always RINSE THOROUGHLY afterwards and oil *immediately*
