Everything posted by JNewman
Paving Breaker forging & heat treating 101
I went to 4 rental shops looking for sharpening work. 1 gave me 25 points and chisels to sharpen, and they will send me more next time they need about 50 sharpened. Using Grant's information above I sharpened them in about 2 hours. I need to get a little faster and find some more shops that will send me more points. Unfortunately there is a shop in Toronto that is sharpening them for $3.75. I can't see doing them for less than $5 ea unless they have several hundred to do.
Name of this Tool.
I think the tool you are asking about is a rope swage. You do need a power hammer or striker to use one effectively though. 3/8 is small enough that you could probably get away with a treadle hammer or possibly a flypress.
Hossfeld Bender Videos
Looks like Hossfeld is starting to get off there marketing laurels. They have posted a series of videos on using the hossfeld bender. Here is one YouTube - HOSSFELD™ No. 2 Bender - Overview, Part 1 if you click on more from the same user you will find the rest. Much of the stuff is pretty basic but I learned a little on each of the videos. Hopefully they post some more. Looks like they are finally doing some direct sales as well. I needed a pipe bending die a few years ago and my local distributor carries NO Hossfeld product in stock. After taking 3 days to get me a price that was almost 3 times what I payed for an American Bender die they also quoted me 3 a week delivery. I would rather deal with a local distributor but when they keep NO inventory its better to deal direct. I should get around to ordering a manual from them I hear they are only about $5, not the $25 people are charging on ebay. There is also an old promotional movie (1950s?) for hossfeld that someone has posted in two parts that I also picked up a few things from. YouTube - hossfeld universal bender #2 (part 1 )
Kewl VIDEO
I use loose blocks under my hammer all the time. You do have to be carefull and to think about what could cause blocks to go flying. The one loose bottom tool that he used was a bottlom swage which had the stock holding it in place especially with the set hammer on top of the stock. The other was the snapper that he used cutting off the stock which I would think the bigger danger would be of the offcut flying if he had the side set a little too far over the snapper, however there was no one standing over there, as well he seemed be pretty skilled in that task. The sleeves looked no looser than many long sleeve shirts I wear in the winter. The only things I saw that I felt were a little unsafe were using a hand hammer on the bottom hie on a running hammer and the lack of hearing protection.
Pottery kiln for heat treating
Used pottery kilns seem to be fairly cheap are set up for tempurature control and even for ramping up and down in temperature. Does anyone here use them for heat treating? How well do they work for lower tempreratures for tempering ? I have found a used kiln in fairly good shape for $200. I just got a PO for job where I have to forge quench and temper about 180Lb of 4340 and I also have a job that is supposed to be coming up soon where I have to forge quench and temper 250Lb of 4140 and 100lb of W1. The heat treating cost on the job I already have the order for, will more than pay for the kiln. I am also thinking with a few simple modifications it could be used for a salt pot
Ceramic blanket vs refractory
I question how much more efficient blanket is than castable if you are going to use the forge for a few hours or more, especially if you use a layer of ceramic blanket on the outside of the castable. Once the hard refractory is hot it acts as a heat sink so when you put in cold stock it does not cool the forge as much. Any insulation you put outside the hard refractory does not have to be rated for as high temperatures so is much cheaper.
Fly Press Tooling
I would be more inclined to use a power hammer for the texturing especially on pipe. The flypress is too slow and pipe is not going to hold heat very long. When I have done bark texturing I had the best luck with a lot of fast relativly light blows. If you have a hard time getting the light blows with your hammer put a stop block between the dies so that you cannot crush the pipe. My bark dies are a spring tool with a bunch of random depth hot cuts into the dies. I have seen them made with a bunch of hardface beads welded on the dies, and there are also ones for sale at blacksmith depot.
Kewl VIDEO
How is what he is wearing any mor dangerous than a Cotton apron? Did you look at the rest of the videos by the same poster. They were really moving making a tool that is not that simple a tool to make while that pretty simple tooling.
spinner ring
I think we need a little more information, dimensions, how true the rings have to be, clearance and how wide the flange has to be. Some options off the top of my head are bend a piece of channel in a ring spring it over the iner ring then elctric weld the channel. Make your ring and use metal spinning to close the flanges. Machine the outer ring and bolt or weld on the flange. Lots of other options based on requirements, volume and budget.
3-D CAD Anyone using Sketchup Pro?
I thought the pay per use on the export was a good feature but much of what I import goes nowhere. I am going to check it out when I have some time to see if I like it. I may use it for jobs that I have to get CNC cut, and then use the Rhino for quoting. I was quoted about $4000 for Solidworks and it seems to be the standard for most of my customers customers, was it that much better than solidworks?
I had a quick look, will have to take a better look later. The big downside I see right away for short term use/learning is you have to pay to import other file types. Right now mostly what I am using Rhino for is opening files from customers. Paying $100 for each quote I do gets old very quickly. In the future I do want to be able to modify customer models adding coreprints and draft as well as splitting on a parting line, so that I can sub out CNC work and eventually do my own CNC work. So a stronger Cad program would be good. How much to buy the full version? I didn't see that on the web site.
Fire Irons set
There are lots of Ontario smiths who teach courses. Lloyd Johnston http://www.ontarioblacksmiths.ca/sales/Johnston-Courses.pdf Darrell Markewitz the Wareham Forge, Artisan Blacksmith Darrell Markewitz of Ontario Canada, Hand forged custom designs for garden, architecture, knives plus courses and DVD David Robertson Ontario Artist Blacksmith David Robertson Rob Martin Thak the Blacksmith &Armourer- Ontario, Canada Sandra Dunn TWO SMITHS These are all accomplished full time blacksmiths. Ask around at an OABA meeting, someone may demo heat treating for you. Stop by my shop I will show you how to how to harden a drift, chisel or punch. 180 Princess St. call first to make sure I have a fire going 905 544 5691.
Home made blower
One of the OABA members took a trip through asia and visited a lot of blacksmith shops. A few years ago he did a slideshow of his trip at an OABA meeting. The shops ranged from a place in Japan that looked nicer than my livingroom to a square of sidewalk in India with a hole in it which was the smiths firepot. Many if not most of the blowers in use were built from bicycles or bicycle parts. Many of the anvils were a piece of round bar or even a large sledgehammer buried in the ground. These were all blacksmiths making their living out of these shops.
Help w/4340 usage
Sorry 3"x3" forgot to hit the shift buttton.
My Bicks (Shouldn't we have a "Tools" subforum?)
That makes sense, I hadn't thought about the collar. I guess you must have hydraulics on your hossfeld as well.
Help w/4340 usage
Thats a good price. I just finished a job that I used 12 pieces of 3" round 4340 3' long. I paid about $15ea that's over $2/lb.
I am curious Grant why do you bend these with the with the Hossfeld rather than with power on the press?
A No-Mar, Low Stretch Bending Fixture
I forgot to attach the picture
Things have been a little slow here so I made one of these bending jigs. I used a 6" long piece of 4.5" dia. stock for the rounds. I have a job that I have been told is coming for the last few weeks that I will be using it for. I have to prebend 200 3/4" round bars before I bend one end into a hook. This will eliminate the marking from my old bending jig. If some things I have been thinking about work out I can see myself using this jig quite a bit. I was thinking about what effect if any the saw kerf and cleaning up the face of the half round would have. In thinking about this I reallized that if I bolted half round swages with stops on top of the half round about 1" above the center of rotation the distance between the stops gets shorter. So THEORETICALLY this will upset the corner as it is bending. It may still need cleaning up in a swage but should get more material in the corner. I am going to take a skim cut off the faces of the half rounds on the mill so that I know they are parallel and then put 2 12" dowel holes and tapped holes in the ends so that I can fasten swages and other tooling on top of the half rounds. If I countersink these holes slightly I dont think these will mark up flat stock when being bent. I am also thinking if I get a little inventive I may be able to bend my hooks on the press much colder and faster than my old way of a bending jig on the platen table
'Nuther video
Very nice control on that hammer! I looked at your other videos as well, lots of neat stuff. I like how the steam hammer holds a little after the blow when you you used the hand control so the stock didn't bounce.
Generating voids in the middle
Are you forging the bar down to the 3/8 before turning it and forging it square? If so that could be your problem.
It Stinks
I am often amazed at hammer ins by how much smoke many guys manage to put out. If you bring the coal in slowly and use the coke from your previous fire or use some wood you can keep the smoke to a minimum. If you have to add a lot of green coal you should poke a hole as someone posted above. As well you will have to find the right amount of air blast so the smoke burns, to much air and you end up with that giant was of smoke, you have to be a little patient to coke up the coal if you want to avoid the smoke. I find feathering the blower on and off rather than adjusting it works best for me while getting the fire going.
Praxair ProStar Gas Outfit
I bought a set of praxair torches about 14 years ago they are still going strong. I did have to get the cutting head rebuilt a few years ago but it was at least 10 years old.
Weld cast iron and mild steel
Weld to the studs they are steel. You can either weld a plate with holes for the studs and bolt on or just weld the studs direct.
shinler hammer dead
"nakedanvil been there done that no maint.info other than "contact us"." So why don't you contact them?
