619 -
All this burner talk in the forge thread. This is the 101 material? The wife says when she starts to smell smoke, she knows I'm a million miles away going a hundred miles an hour. I have just recently started playing with burners again. I stopped tinkering for a while. The burner was working so well that it was time to take a break to spend more time swinging a hammer. The burner I have been using is the 3/8" nominal (0.675 throat) burner head on a tapered mix tube with a large step nozzle. It has been working great. The tapered mix tube made a giant leap in induction. I had to choke the burner down as it was too oxidizing to forge weld which means I get to play with orifice size some more. I am very pleased with the burner. I have started on my next adventures which are tapered mix tubes feeding multiple ports. NARBs, shower heads, simple splitters and whatever else comes up. Using the "burner" as an inspirator. A fuel air pump. I have not played with the tapered tube and the manometer enough to speak with experience but in my current mind's picture of things, the tapered mix tube's purpose is to do the opposite of what the throat is doing. The throat constricts, causing an increase in velocity and a decrease in pressure. We want the low-pressure zone to induce air. The tapered mix tube is decreasing velocity to increase pressure. Instead of relying on the velocity of the FAM, we are increasing its pressure from the low-pressure zone in the throat. In my little bit of playing with NARBs, without the tapered tube, there is a large discrepancy in stream velocities across the ports. Faster velocities nearest the edges. I think the FAM is coming into the plenum at high velocity/low pressure and anywhere that it slams into a wall and slows down, it increases in pressure (inefficiently). If my thinking is correct, using the slower higher-pressure FAM coming from a venturi will cause more even velocities across the ports. It would allow the burner head and mix tube to act as a FAM pump, an inspirator. You could also push FAM around some bends, down longer sections of pipe, etc. Sacrifice some throughput for orientation options or port configurations. Time to stop talking and start experimenting. Maybe I can prove all that wrong and update my thinking.
This line is why Thomas stated the Kalmar line line.
Flame velocity… that topic makes my head hurt.
I played with orifice channel length a bit but not enough. At one point I was over drilling 3D printer nozzles to match long tapered mig tip orifice diameters. I built a manifold to connect them both to a water supply to compare the streams. The 3D printer nozzle steam always went straight line considerably further. Less friction, higher volume, higher velocity. I imagine water and propane play a bit differently but it was mostly a food for thought experiment. In burners, I saw increased output at a given pressure. Higher fuel delivery inducing more air. Or lowering the fuel pressure to output the same. I suspect the fuel velocity/volume ratio increases. Higher fuel velocity at a given delivery volume. I am able to run the 3D printer nozzle burners to lower output levels before air induction drops off. In the commercial hvac/cooking appliance world, I have not seen any orifice length over 1/16th inch long. They are running quite low pressures so the orifice diameters are very large by comparison. On higher output burners, the diameter is sometimes larger than the channel length. These burners have much different purposes/requirements so it’s probably an apples oranges kind of thing but it’s interesting.
My experience with too small an orifice is a lean mix. Sometimes lean enough to not be in the flammable range. Even when it is in the flammable oxidizing range, an overly aggressive nozzle may be needed to slow down the high velocity fuel/air stream. The BTU energy available in propane is based its volume (and proper air ratio with good mixing). If you decrease the size of the orifice, then you need to increase the pressure to maintain the same fuel volume. This means an increase in fuel stream velocity which means a lower pressure in the throat of the burner which means more air entrainment. More air for the same fuel volume. Leaner. It is a balance thing, nothing more. The scales can be tipped based on specific user desires (lowest fuel pressure, maximum energy output, etc.). My Goldilocks orifice induces the proper ish air at the widest happy fuel pressure range.
The first photo looks like the forge interior is raw blanket. Is this the case?
For close enough work with circumference, I multiply by three and add ten percent. For the 8 inch circle, 0.8+24. If I need to be over, I add 15 percent. 1.2+24.
You are thinking too hard. We can be friends. I thought I had gathered that the pipe actual dimensions were very close between the two standards and that threads were the big difference. In which case, if wall thickness are also fairly close, you can just build per the instructions. Building another forge is just part of the blacksmith way I think. Plot to build that perfect forge and as soon as it’s done, start plotting the next with improvements.
If your intention is to work on large/long knives, long and thin is fine within reason. Just use two smaller burners. Unless the current forge is built poorly, why build another. If you want to do more generalized forging, long and thin isn’t as much fun to work in. The jet gap is a starting point for tuning. You don’t want to go crazy on over sizing the air inlets or burner performance may suffer. As Frosty stated, it’s a ratio game. As far as I understand it, nominal pipe sizes are close between the two standards. If that is the case, select the next size up from the mix tube. If you want a 20mm burner, use 25mm air inlets. If you want to build 25mm, use 32mm inlets. If you give your forge internal volume, you may get recommendations on what burner(s) will work well.
I don’t know about Canadian law so it may be different but you want to call around to hvac and appliance repair companies, not suppliers. The repair companies actually use the refrigerant and have the empties. My company sells them for scrap otherwise. Lots of them. If you do get one, make sure it has been evacuated. We evacuate them and drill a hole in the blow plug.
I started with a refrigerant cylinder because of Ron Reil’s mini forge page and I am an HVAC guy. I think the forge would be awesome for a bladesmith but for general smithing, they end up a bit small in inner diameter and way too long for my liking. They could be cut shorter or walled off but you still end up with 3.5-4 inch inner diameter which yields a very narrow floor space. I do prefer the blanket, kast o lite, plistix way of building forges but now I make my own outer shells with sheet metal as I can make whatever I want. I like a lozenge shape because of the flat wider floor while still keeping internal volume lower. I also like no longer/deeper than 8 inches. With the refrigerant cylinder, I was always heating way more of the stock than I could work.
Off the top of my head, I believe the insulated bricks are 8 ounces ish and the hard bricks are 4-8 lbs. The hard bricks are less expensive but don’t make for a good forge. They do work but you will spend more on fuel in short time then the cost of insulating bricks. I have both, I use the hard bricks as backers for torch work and other odd hot jobs like that. I can take pictures of both of you like. The insulating bricks are porous with large bubbles.
Hello Andrew. Welcome to the site. If you like to learn, it's a great place to be. My original intention was to make my experiments public. Both, so others could learn with me and so that wiser others could point out my errors or offer suggestions. At one point I did pursue a patent, but I remembered that original intent and stopped. This thread is now prior art so "my" burner belongs to the public. If clones are eventually mass produced, I would feel accomplished. Until then, I'm just a guy in his garage having fun. Hopefully the clones are decent and inexpensive.
- 863 replies
Ron Reil's main forge is massive. I have spent many hours in front of it and never needed its full potential. I believe it is 8 inch internal diameter, 24 inches long for ~1200 in³. It has four 3/4" burners. Though usually only the first one or two are used. It was designed with minimal mass so that it would heat up to high temperatures quickly so not much in terms of "storing" heat. He no longer employs the sliding back wall. If you are after fuel savings, it is not the direction I recommend. I have built many forges and quickly learned that I like the smallest forge that will do the job. My go to forge is 43 in³. It stretches the propane. I have forged a 2.5 lb hammer with it, mostly just to do it. I fought heat distribution a bit, having to turn the stock often, as the internal height and stock height were close. For most other day to day things, it does exactly what I need it to. When it doesn't, I fire up whichever forge does. I would not forge weld with poor heat distribution. Though, most things I forge weld are not very large and the little forge does great with that. The biggest things I have found with forge welding are hitting the minimum temperature and not being oxidizing. A smaller forge will hit that temperature with less fuel than a larger forge. As to forge volume and fuel consumption being linear, nope. As Frosty has pointed out, even forge dimensions can drastically change fuel requirements. More length, more friction. Even if a forge was dimensionally scaled, it would have more or less surface area for loss. My first forge was a freon cylinder forge. About 3.5" ID by 12" length for ~115 in³. It originally ran with a 3/4" modified sidearm burner. I eventually replaced the burner with a 1/2" burner which used less fuel and the forge was able to obtain a higher temperature. When the large burner was turned up beyond a certain point, the flames coming out the doors got bigger, but the forge didn't get much hotter. This forge always had a large temperature gradient from the hot spot out. Its length versus its other dimension was too different.
I presented the exact same angle (2.386°) in burners 101 quite a while back, had a triangle drawing and everything. If remembering correctly, the 1:12 taper came from Frosty, years ago, out of some burner patents or technical papers. Though, it was describing a tapered mix tube not a retention nozzle. The angle is important in that the included angle is almost 5° which I was told is the fastest you can expand without causing stream turbulence. Venturi tubes often open at 5° after the throat. It may have been expressed as 1:12 taper for the turner. At some point, I found a chart which listed different taper/lengths and their DMS equivalents for cutting on the lathe. I don't know for sure. As to the nozzle in our case, the wall thickness of the mix tube creates a step which causes turbulence before the taper comes into play. I have found the nozzle taper is not very critical if flame retention is the only desired function. Agreed. I think that is why Mikey now uses 'flame retention nozzle' instead. It's been in use a long time over many sources though. Any idea's on alternative nomenclature?
I just went and downloaded it to test the link. It downloaded successfully. If you would like, you can PM me your email address and I can send it over.
I have made a few, on the fly, for odd jobs that didn't need to waste propane. Even with the Morgan K26 bricks, they crumbled fairly quickly. I have thought about a sheet metal skin and a coating of plistex to see if they would hold up longer. Here is bad picture of a half brick forge for a ring I was working on:
I did something similar to what you are describing. The compression fitting had an insert stop ring which I had to drill out to a tight tolerance so the mig tip central alignment would not have too much slop. I also made a narrow cut in the compression ferrule to prevent it from seizing. Though I still don't tighten the fitting tight. There are some pictures of it on page 11. I have also modified a brass reducer bushing to make a rough collet. Drill out the inner threads to match the orifice tube and then cut slots through the threads. This way when tightening the reducer fitting, its tapered threads compress the fitting and clamp on down on the orifice tube. This wasn't my idea. I believe I first saw it done on the modified side arm burner sold by high temp tools.
I had thought about the parallelograms in the past. At the time I was thinking something like the hybrid burner only with diagonal cutouts. I was going to print a scaled paper cut pattern. Something like this: If anyone is interested in doing so, I can send a scaled printable pdf so long as I know the OD of the pipe you are working with, and the desired length and angle of the cutouts. I have been curious about it for a while. As to the noise level, even with full baffle walls, it is more the constant drone in the background that can get to me. The forge noise and my tinnitus play tennis together I think. I shut the forge off and something in my mind relaxes. Almost always, I am wearing hearing protection so it doesn't bother me. It's usually just when I am in the forge with someone else and not wearing the muffs. If we start using jet engine parts, I will have to get better hearing protection. Hefty, I think that will make a great hand torch. It's a healthy flame. I have a 3/8" version with a bent angle iron pistol grip. It is very handy. I have to admit, my mind took a double take on your baffle wall image. I'll leave it at that. As to the baffle wall, this post in forges 101 talks about it. Keep on tinkering. It is good fun.
- 863 replies
I sure don't mind. I think it's great. I'm excited for you. Straight off the mix tube is fun but once you put a nozzle on it and step up the velocity, it will roar. I think I once called it an angry little jet. You can't help but smile when you hear it the first few times. I am now playing with ribbon burners to quiet that roar. After several hours, the noise gets to me. Very important, try to keep everything axially aligned. In your picture, it looks like that is not the case which is why the flame is not symmetric. The orifice and mix tube alignment being the most critical. A small misalignment in them can severely compromise the potential. I saw your question in burners 101 about beveling a Mikey hoping to get more vortex. Did you try it?
- 863 replies
That is a bummer hefty. As you said though, you learned heaps. Knowing more about your burners will make future troubleshooting easier. When I made some Frosty T's with the lathe, I threaded the tee onto the mix tube and centered the mix tube. So long as the mix tube is concentric, the hole will be drilled In the tee, centered on the mix tube, no matter how far out the tee is. Plus there is no measuring to determine where mix tube center happens to land on the tee. If I am remembering correctly, Frosty suggested it to me. It almost takes the work out of it. Nice dig Tink. Interesting find. Over thinking Teflon tape... we can be friends.
Your presumption is correct. The mig tip is a stream shaper. We want that fuel to be in a fast collimated stream down the middle of the mix tube. The mig tip is also a metering device. It only allows a certain amount per pressure. Right now you have an uncontrolled amount with who knows what kind of shape, potentially causing all kinds of turbulence. Too much fuel and not enough air. Until you fix it, there is no point in attempting to tune. I have used gas tape and thread dope. Both work. I'm not sure of the reasoning that you read against tape. Perhaps because if it is installed incorrectly, pieces of it can make it into the gas way and plug the orifice. If you go the tape route, make sure not to tape beyond the last thread on the orifice inlet side. Nice job. You are getting close. Soon you will be thinking about shaping metal instead of about burners.
"You mean I should back the regulator out every time! Why?" I like valves. Bottle to regulator, to ER shutoff ball valve, to hose, to second shutoff ball valve, to idle ball valve with bypass needle valve, to individual burner needle valves, to burners. Control freak maybe?
Also, don't try to close the needle valve with extra torque, after it has seated, in an attempt to get it to stop flow. There is a reason the knobs/handles are so small. Metal needle, metal seat. Anything over just seated risks deforming the needle and/or seat. Finger tight. Same idea with the valves on your propane tanks.
0.236" is a tad under 1/4".
