11,835 -
I did a google search for bootjack styles and came up with this, lots of images here. https://www.google.com/search?client=firefox-b-1-e&sca_esv=598666418&q=bootjack+styles&tbm=isch&source=lnms&prmd=ishvnmbtz&sa=X&ved=2ahUKEwitnK-Py-CDAxXIEUQIHYKVBpYQ0pQJegQIExAB&biw=1053&bih=491&dpr=1.2 I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
That's all I've ever heard them called. I usually make them out of old horse shoes & flat plate or sometimes wood as a base. Yours look very good. I'm also happy to see I'm not the only one who has to hang on to something when using one(grin). I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
What did you do Outside the shop today?
Irondragon Forge ClayWorks replied to TWISTEDWILLOW's topic in Everything Else
I do basically the same thing using the 18 inch chainsaw bar as a gauge. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Lighting suggestions
Irondragon Forge ClayWorks replied to Lee188's topic in Building, Designing a Shop
When I replaced the 8 footers with the 4 footer florescent lamps, I wired up outlets in the rafters from the switch, to plug the lamps into. 1 outlet between 2 lamps. The 5000 lumen LED lamps that are replacing the florescent lamps plug right in the existing outlets. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Welcome from the Ozark Mountains. I don't think the pipe dope turning brown will be a problem, at least it isn't in our forge. Just to be safe when it is cold turn on the gas and check it for leaks with a little soapy water. If you do have to replace it, use some propane rated Teflon tape. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
I had the same experience in the garage. The city built a new state of the art fire department facility and converted the old fire facility into the police department facility. They gave me 4 of the old 8 foot fluorescent light fixtures and I put them in the new garage we built. For some years they worked very well but the problem of finding and transporting the 8 foot tubes was a chore. Then as you said in cold weather the lamps took a while to come on and the ballast's started burning out. By then I couldn't get to the lamps without moving a ton of stuff so I replaced the 8 footers with 2 4 foot fluorescent as they stopped working. Fast forward and the 4 footers started having the same problems, so now as they go bad instead of replacing the ballasts I'm replacing them with 4 foot LED's which I buy at HF 4 at a time when they go on sale. So far not one LED has failed so I'm happy with them. They are all controlled with a light switch but individual lights can be turned on/off if not needed. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
We have gone to the LED shop lights with pull chains. That way we can control the amount of light to fit the circumstances. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
North german identification
Irondragon Forge ClayWorks replied to estland's topic in Anvils, Swage Blocks, and Mandrels
Welcome from the Ozark Mountains. No matter who made it, I would say it's an outstanding anvil and should give good service for generations to come. If you add your general location in your profile it will help with giving better answers. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Welcome from the Ozark Mountains. When I saw your location, I thought you were from Australia, we have a lot of members from the land down under. A great group in OZ. OZ roll call - Everything Else - I Forge Iron I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
Kohlswa Sweden anvil
Irondragon Forge ClayWorks replied to Cory nichols's topic in Anvil Reviews by brand
Welcome from the Ozark Mountains. Anvil values differ wildly depending upon location. Also prices are figured on pounds they weigh. I will say for $50 U.S. you basically got a steal for a Swedish Steel Anvil no matter where in the world you are located. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Colonial Anvil and Stump, info
Irondragon Forge ClayWorks replied to ZzzDerekzzZ's topic in Anvil Reviews by brand
Welcome from the Ozark Mountains. The lack of a pritchel hole will date it to around 1840 when they first appeared or earlier. Hope you have read about not doing any grinding, milling or welding on the hardened steel face, which does more harm than good. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
forge welding mild steel
Irondragon Forge ClayWorks replied to evfreek's topic in Blacksmithing, General Discussion
Opening up old threads is not a bad thing. There probably newer members who have the same question or problem and can learn something from it. Also it keeps members who are no longer with us in our memories. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
looking for a poem name
Irondragon Forge ClayWorks replied to GhostTownForge's topic in Everything Else
I knew I had seen that somewhere but for the life of me couldn't remember where. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Along with those who have passed away, most responders haven't logged on since 2019-2020 so I doubt anyone will see this. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Welcome from the Ozark Mountains. The 2-2-2 is the weight as when it was made in English hundred weight. The first number is 112X2 second number 28X2 (can't be over 3) third number is actual in pounds. So the first 2=224 second 2=56 third 2=2 for a total of 282 pounds more or less. If you post some pictures and where in the world you are located may will help with whatever else you want to know. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
will a solid steel ribbon burner work ?
Irondragon Forge ClayWorks replied to BartW's topic in Ribbon Burners
Americano Welcome from the Ozark Mountains. I read on a blog about pizza ovens a couple of years ago that they were building them with reclaimed home furnace burners that were steel or cast iron. When we had to have our furnace replaced I saved the burner & gas regulator, planning to build a pizza oven. I still haven't gotten arountoit though. If you are close to me stop by and you can have it. If you are on the other side of the planet, check with some HVAC places that work on furnaces, most here will give you more burners that you can carry. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus -
Building my Jer Schmidt Gen 2 2x72 belt grinder
Irondragon Forge ClayWorks replied to Ohio's topic in Grinders, Sanders, etc
Don't ya love it when a plan comes together. Your welds look just fine, much better than a lot of mine and I've been welding for around 60 years. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
