VainEnd84
Everything posted by VainEnd84
  1. Very interested in hearing how well it works!
  2. Frosty she is so cute!!
  3. VainEnd84 replied to Sly's topic in Solid Fuel Forges
    Applying creams and salves to a fresh burn is actually not a good idea in general, if it is small and minor (like small forge scale touching your skin) it's not likely to matter one way or the other, your body will have done most of the important work before you can apply the salve. However, for more serious burns a salve/"sealant"often does more harm than good. A minor burns kit in your shop first aid is a must for us, but in a pinch, cold clean water to remove any remaining heat first, then hydrate, then an very thin antibiotic ointment (polysporin for burns, or similar) then go see a doctor. Burns can get serious very quickly, and you really really dont want to deal with an infected burn. I almost had to have a hand amputated due to an infected 3rd degree electrical burn. I had a burn kit and the proper training to treat it.
  4. There is a pinned post that I believe answers this Also what about refractory coatings? Ceramic fibre blanket with out ridgidizer or a castable is a big no for safety, there is a pinned post about that as well.
  5. You do not put money into the forge unless you are making Mokume.  - Glenn
  6. The proper term is apparently fluted, I guess I learned something new today! Like the rifle barrels in the following google search https://www.google.ca/search?q=fluted+barrel&tbm=isch&ved=2ahUKEwjAlKfMjt_fAhUH5VQKHcssDkMQ2-cCegQIABAB&oq=flute&gs_l=mobile-gws-wiz-img.1.0.0i67l2j0l3.10594.11681..12759...0.0..1.70.411.7......0....1.......0.W-7ttW3jlwk&ei=EhQ1XMDDKIfK0wLL2biYBA&prmd=ivn&biw=412&bih=670#imgrc=7hEKvl-yZPXe6M&imgdii=cXR_TtU6KQjzCM
  7. Could you add ridges instead of fins? Similar to what they do with competition rifle barrels. Just a slight increase in surface area has a dramatic effect on heat transfer and might cause less disruption than fins
  8. That is looking really good!
  9. I think you might be paying too much, I see you live in Victoria, check your local canadian tire (20mule team is $4.50ish), I know things tend to cost more on the island but still I think you can do better than $7-$8!
  10. VainEnd84 replied to Mikey98118's topic in Gas Forges
    Yes, please do!!
  11. My inner ocd petulant child wants to poke fun and say that the plate in the bottom isn't level ... but that would just be silly. Looks good so far! I'm sure it will be said by the more experienced solid file guys but you may want to think about cutting out a section at the back incase you need the heat the middle of a long section of stock. Are you going to be fabing a clunker breaker? Also what is your air supply?
  12. One of the things I like about being here is how quickly I'm corrected when I say something wrong. - Frosty The Lucky.
  13. Does the original 6"x3/4" stock have to remain in one piece? Or can it be cut?
  14. English hundred weight is given as multiples of 1. Hundred weight (112lbs), 2. Quarter weight (28lbs), then 3. Pounds (1lb).
  15. Made this little bell for my aunts birthday
  16. VainEnd84 replied to Mikey98118's topic in Gas Forges
    I wasn't thinking of it as fuel, was just curious about what specifically it was, thanks for the info!
  17. VainEnd84 replied to Mikey98118's topic in Gas Forges
    Another Curtis: out of curiosity, is R-290 pure propane or is it LPG, like we get for running forges/bbq's etc. I know they are virtually identical but my understanding is the LPG fuel differs in some ways compared to pure propane.
  18. VainEnd84 replied to Mikey98118's topic in Gas Forges
    The engineer I spoke to didn't get into specific manufacturers just general information, that is very interesting. One of the things he talked about is the field of high temperature insulating plastics. The way he described it is like two part expanding spray insulation, but that can handle 3000F and doesn't suffer from thermal cycling. Apparently there are many high temperature plastics out there but we didnt get into them as he said they don't really apply to building forges and kilns etc.
  19. But mikey, rocket ships are fun, and since when do you not shoot for the moon?
  20. VainEnd84 replied to Mikey98118's topic in Gas Forges
    Another thought is if there are any are colleges near you that have glass blowing, you can go and talk to them and ask who builds/maintains their furnaces, that might put you onto another rout. The stock on Amazon is spotty at best, you have to look regularly
  21. VainEnd84 replied to Mikey98118's topic in Gas Forges
    Look up, industrial refractory suppliers near you, not all of them are willing to sell small volume. My biggest problem originally was finding individual bricks locally for less than $13-$15 each at pottery suppliers an the like which is terrible. Then I started looking in other places and eventually I was talking with a guy who makes pizza ovens who put me onto the company he buys fire bricks from. I can buy a case of 12 for $60 as long as I pay cash and go directly to them. Ebay and amazon are the other option.
  22. VainEnd84 replied to Mikey98118's topic in Gas Forges
    I know that the go to soft fire brick, in terms of cost, durability, and ease of access is the k26 fire brick, bit is it actually good enough and If so why? I've been doing some research into soft fire bricks and have learned some interesting things about them recently. The most important thing I have learned is that the temperature rating (k26 or 2600 degree rating for instance) is actually the max "short run" temperature load (short run varies by manufacturer but always seems to be less than an hour). So a k26 fire brick will start to thermally decay at temperatures at or above 2600 degrees F fairly quickly. Most seem to have a sustained thermal load capacity of about 200-300 degrees F less, which means that a k26 fire brick will only be sustainable long term for temperatures around 2300-2400 degrees F. This turnes out not to matter in forges as much because the fire bricks start to degrade from thermal cycling before the thermal decay has much effect. There are 4 other types of commonly available fire bricks, k23, k28, hard fire bricks, and medium duty fire bricks (in talking with some suppliers I have learned that new manufacturing techniques and materials are resulting in stronger and better insulating bricks to be available in the next few years). We can toss out the medium duty fire bricks for use in forges because they generally have a max load of 1800-2000 degrees F and are meant for things like fire places. We can likewise toss out using k23 fire bricks as a max thermal load of 2300 F and a sustained load of 2100 F they will start to thermally decay much too soon. And hard fire bricks have almost no insulating capacity so there is little point in using them either. That brings us to the k28 fire bricks. With a max thermal load of 2800 F and a sustained thermal load of 2500-2600 F they are one of the better insulators available as far as bricks are concerned . Their biggest down fall is that they are extremely fragile and are hugely susceptible to thermal cycling. So unless you plan to rarely if ever turn off your forge (not recommended outside of industrial/production line forges) they will fail much too soon. In the end we really are best off to use k26 fire bricks for the time being. Can anything be done about thermal cycling degrading fire bricks? I'm happy to say yes, there most certainly is. I had an enlightening conversation with a thermal engineer who works for a local company that deals in refractory materials. The big thing is that soft fire bricks are not actually designed to be brought up to their max temperature and cooled to room temperature more than 6 or 7 times in their life. So how can we counter act that? It's actually very simple: 1. Make them smaller, you cut the brick in half, take a 4.5"x9"x2.5" and make it in to 2 of 4.5"x4.5"x2.5" 2. Rough fit them to your final shape, in otherwise fit them to the inside of your forge shell but leave a bit of a gap between all of the bricks about 3/16" 3. Use the dreaded high temperature cement to cement the bricks together 4. Coat in a castable refractory and if you like coat with an IR reradiotor While all of this will help the longevity of the bricks they will still eventually fracture due to thermal cycling.
  23. I was told a long time ago, that if you have the option, go with wire that is lower is carbon content than the steel being forged, it will theoretically burn up slower. The other wire option is stainless wire though I doubt it's worth the added cost. Also remember that you may end up welding the wire to the billet.
  24. Another biology nerd! Excellent, and I'm glad I'm not the only one who saw that lol
