bigfootnampa
2,372 -
From the album: forged tools
these were reworked from an old pair I got on e-bay that were in need of rehab anyway. The hookjaw reminds me of a spawning sockeye. -
Well actually Thomas, I do hammer my steel as it cools when I am refining my shapes and in specific areas (like hook curves) where I desire some work hardening. However I also find that MY metal gets stiffer after being worked even when I haven't intentionally forged into the black heats. Maybe this is not theoretically predicted but it happens when I am working and I generally find it useful.
As a consideration for smithing work it seems to me that the greater yield strength of the 1018 would be overwhelmed by the work hardening and grain alterations inherent in the forging processes... not to mention any quenching effects. The extra carbon in the A36 might well be lost in the forging cycles but the 1018 might also lose some and having less to begin with end up softer rather than stronger. I would typically favor the 1018 for an axle for a small wagon/cart where I would use the steel as bought (without forging or heating/quenching cycles)... for general forged items I tend to buy the A36, which is slightly cheaper, as I feel that I would get little gain from the nicer surface or the higher yield strength where these properties will be so thoroughly impacted by my forging and heat treatments.
Only a guess but... did you have your anvil anchored with staples before and now it is standing loose in it's routed depression. Perhaps it is not connected tightly enough to the new mount.
Okay here is a picture... sorry I was a little busy before. I am also including a picture of the trowel that I was able to complete with the forge. My wife reports that the trowel is amazingly useful! Much more effective even than it would appear to be. She has ordered another narrower model (which I have completed except for the handle finish and final assembly... pics of that later). [/urlurl=http://www.iforgeiron.com/gallery/showphoto.php/photo/14945]
From the album: garden tools
This trowel is about 20 inches long overall and 3 1/4 inches wide made of 1/8 inch mild steel -
tinning flux, supplies and how too... need help
bigfootnampa replied to Fe-Wood's topic in General Metal Specific Discussion
Because the heat is pretty low when tinning the flux can be pretty soft. I have had good luck with the wax type plumbers fluxes. Plumbing solders are mostly tin as they are now mostly made lead free. Some plumbing suppliers will carry bar solder which should work fine for tinning bowls (make sure it is the lead free type though... roofers still use solders with lead in it). -
I was given a new forge as a Christmas present and ordered one from Mike Tanner. I finally got it set up and lit the first fire in it yesterday. I had been working on a little portable forge previously and had been feeling limited when trying to forge larger pieces of metal. I was very impressed with the new forge! I did some of the projects that I had set aside as too time consuming before and also some other small things. I was more pleased than I had expected by the increased ease of heating and forging. The blast control was amazingly sensitive and also added an unexpected dividend of efficiency. It was a BLAST to operate! I did allow myself to be distracted for a few moments and had some minor burning of irons but caught it just in time to save everything (this was mostly due to having started the fire with all new coal and increased heat levels as the coal converted to coke caught me off guard). This forge was a lot of fun to work with and more than fulfilled my expectations! My thanks to Mike for making a nice product and being a pleasure to do business with! I hope you sell a lot of these Mike!
Here in Missouri there has been a resurgence in branding cattle as the ear tags are easily clipped off by rustlers. The resurgence in branding has been fueled by a resurgence in rustling... they have targeted cattle in remote pastures and pens... theories circulate that they may be using airplanes as spotting vehicles. The problem seems fairly large and quite likely involves professional criminals.
filet knife (kevin's 5th knife)
bigfootnampa replied to kevin (the professor)'s topic in Knife Making
Everybody here who is making filet knives is making them too wide! When you have ground that blade down to about 1/3 of it's present width it will be about right. You cannot have the proper spring in an inch wide blade. This is currently a boning knife... not right for filetting. I don't mean to be mean but I have caught and filetted a whole lotta fishes and I would have a lotta trouble with that knife. For less experienced filetters it would be even harder to work with. My old mentor (Ted Trueblood) preferred to use a regular butchers boning knife that was many years old and ground down to the proper profile from use and many sharpenings... I like the nordic mfrs versions though (sometimes I still will thin them a bit more on the belt sander). My advice is to trace out a Rapala profile and emulate it. -
Heating Stainless Steel
bigfootnampa replied to Metalshopteacher's topic in Blacksmithing, General Discussion
All stainless is not equal though... I have heard that some alloys will separate when heated leaving pockets of regular steel. The stuff I have worked doesn't have that problem though and forms a thin, tight, brownish/grey scale that I like the looks of. There are many alloys available and they have widely varied properties. There have been some other threads here about this and it would be wise to search these out and read them for more specifics. The stainless I have worked was softer than mild steel and forged more into the dark red heat zones. I can't tell you what alloys though as I have bought it as bolts with unknown content. -
forced to woodwork
bigfootnampa replied to Rodney Skinner's topic in Blacksmithing, General Discussion
OOOhh! OOOHHhh! I know! It's a wagon wheel! -
From the album: Jewelry
this is a brooch I made for my wife this Christmas -
The picture is not good enough to be definite but my best guess is a stone axe (NOT made of stone, for chipping stone). Twybills are normally much longer (on each end) to reach into the mortises. It could also be a woodcarver's adze.
They appear to be mason's plugging chisels... used to remove bricks from a finished wall by chiseling the mortar around them out. They wear quickly and get too short to use for plugging but may still be useful for tuckpointing... most masons use grinders for that nowadays though.
You can buy asphalt cutback from pro paint stores (lotsa painters use it for staining). Really though I'd probably just mix in a little black artist's oil paint... the linseed will add significantly to the protective qualities of the mixture and the pigment will get it real black. Mortar colorant would work too, it's just powdered pigment... you should be able to get black mortar color at Lowes or HD.
I have torch welded copper and also used hard solders with it. Straight silver either fine or sterling will make a decent extra hard solder for copper. Copper oxidizes quickly so flux is essential and not after heating like you do with iron... you need flux on it when you start heating. I can't remember what flux I used but it's a commercial jewelers flux... not just borax.
I like it! To get the best from it turn a small burr upward on the cutting edge with a burnisher and then tilt it down in cutting mode (the burr corrects the cutting angle but will take a fine cut and NOT catch). I do all my standard parting tools this way, the diamond type is my favorite.
Buy the Fox unit! the Vanco is old and has solid backer all the way up... you'll want to use the unbacked areas a lot. The six inch unit is too wide for knives and such and the belts are too rigid also... you'll use the flex especially at the edges of the belts to excellent effect. You won't use the disc feature much but you'll get plenty of service from the 1" belt and the Fox unit won't seem underpowered when you use it... mostly you have to grind lightly anyway to avoid overheating the metal too quickly. You could make one but the Fox unit will be cheap for the years of fine service you'll get from it... you won't be sorry.
A Very Satisfying Christmas Gift
bigfootnampa replied to Leland's topic in Blacksmithing, General Discussion
If you will hot seat the tangs (black heat... melted in rather than burned) or set them in epoxy, you will find the bolsters are not needed anyway... save perhaps on tools meant for heavy mallet driving. I misdoubt your son will ever miss the bolster. -
Well the outcome of any such chisel-bolt encounter may well depend upon scale... I believe that I might easily snap the head from a 1/4 inch bolt whereas I might need a torch if taking on a 3/4 inch bolt. If I had no torch I might just go the other way and use some refrigerant (used to be freon) to freeze the bolt so that my chisel would crack it right off. A blacksmith would think nothing of hot cutting a bolt of ANY grade! There are many ways to skin a cat! ANY tool is just junk metal in the hands of an ignorant user. Conversely, a skilled craftsman can make some pretty humble tools to sing an impressive chorus!
Lets see some christmas gifts!!!!
bigfootnampa replied to Sabre's topic in Blacksmithing, General Discussion
Sabre; I keep a package of split rings handy and install one BEFORE bending my leaf stem closed. That way the fob is permanently attached. Keep the fit loose so that the split ring can slide around as keys are added or removed. -
What can you make out of railroad spikes?
bigfootnampa replied to sdalcher's topic in Blacksmithing, General Discussion
The best use I've made of them so far is as nail headers. Chop them off about an inch and a quarter below the head with a cut-off wheel in a grinder and then wrap a rod just below the head... heat to bright red and flip the cut end up on the anvil (kinda roll it so the rod stays in place) then pound with a big hammer to upset the shaft and trap the rod. Voila! You have a nail header ready to drill and drift. I like to weld my rod tight with the mig so that it doesn't rattle in use at this point too. The crown of the spike head makes a good surface for the top of the header but it flattens a bit from the vigorous upsetting, so I reshape it a bit with a 36 grit flap disc. PS: Once you get a header or two made you can start on the nails... and use those to make lotsa stuff. I just made a nice key rack with nails as pegs for the key rings. I like the heads kinda biggish for these so take a heat after tapering and notching so that you can get a nice big head flattened and shaped. I'd take a pic but it's already wrapped... so after christmas.
