mcostello
    258
Everything posted by mcostello
  1. Wonderful to see, but, not any safety protection at all. If that wire would jamb up somewhere someone's ankles would have been badly burned, no hearing protection either. I am not a safety nazi, those were wild times.
  2. There's only one classification------ never thick enough!
  3. Wonder if that miracle rod that solders to Aluminum would stick to Brass? If it did thin coat of braze could be assembled to steel, pressed in then finished with magic rod. Or am I in left field? Would not be first time.
  4. I worked in a steel mill for about 9 months and was on the pouring platform once when they made killed steel.. These were old timers which did not offer much in the way of explanations. They said it took out the oxygen. To see a guy walking around with an arm load of soap bar sized Aluminum ingots, and, tossing 2 or 3 into each just poured steel mold was amazing. The Aluminum would just go "poof" and be gone. Watching closely, it seemed that a thin flow of liquid was spread across the top of the steel. Not much in relevant facts, just amazing that Aluminum would disappear so quickly.
  5. Here I thought you would say," Are you smarter than a Blacksmith?":)
  6. If anyone needs to crimp their own hoses, the method that has worked for me was to pick an appropriately sized nut and split it in half. Put in vise and squeeze, could also groove each side and crimp at 90 degrees for 4 sided crimp.
  7. I have tried using cheap carbide ceramic and tile drills to cut hard steel, worked ok, only 2 or 3 holes though. Would not be pleasant if they broke off though.:)
  8. And some of us just chuck it in the wood stove with no problem. Ultimate revenge!
  9. I am using propane with a standard rose bud, and if it's wrong the steel does not seem to be cold when done!
  10. Todays Craigslist has a M+H mouse hole 186 lb. anvil and another ad for farrier tools etc. Just letting youall know, not seller, just trying to help. Ok to move if in wrong heading. Have to do your own research.
  11. Wood peckers in this neck of the woods are no match for him!
  12. Some one actually using bed rails for a............bed? How interesting! Right material for the intended use is always best
  13. If belt is slipping an old time remedy is to smear some honey on the pulleys, run for a second to distribute it evenly, then let it sit to dry.
  14. Hey Phil, the drive in at Columbus is not as good as it once was, live in Lancaster and go there every year. Last 2 years came home empty handed. Don't forget Caesars Creek as it has more, but also seems to be withering. Flea markets seem to be drying up here, hope the trend does not continue.
  15. Wife wears tongs.... or is it thongs, can't remember the difference in spelling! :)
  16. Here in Lancaster, Ohio old timers always said that people used to pay to have lawnmowed with scythes before gasoline powered mowers came along.
  17. Did the reduced part need to be 2 1/2" long? Shorter would help.
  18. What was the purpose of the vinegar? New secret mixture? Inquiring minds want to know!
  19. Lennox and Starrett are some of the best.
  20. I don't know how this would fit in the scheme of things, but a place I worked for sharpened their bits by recutting the angle with a cutting torch and dumping into oil. Cut off was small, just enough to get a point.
