Everything posted by highlander
A rose by any other name.
Copper stem with brass petals. Valentines Day gift for my mother.
hand burner
Hello, fellow Delawarean!
New Anvils...
i use a mousehole just like that except mine is a bit swaybacked. nice scores.
look what i found
I looked at that anvil when it was posted for $450. Good to see they came to their senses. glad to see you are back online again, i sent you a PM
hawk handels
vise and a drawknife
Cub Scout talk
Very cool mike!
Corn Forge
fuel consumption and efficiency varies a fair bit with different forges. i say buy a bag of it and go to town! see what happens and report back to us.
Anvil repair advice
.... are you serious?
Induction heating.
Let me google that for you
New gasser almost ready to go
20lb propane tank. 8inch openings on both sides. venturi burner. picture was taken on my cell phone whilst firing the mizzou refractory. more pictures tomorrow when i have a real camera with me.
Random Blacksmithing
- DSC00317
Old English Anvil Question
its an old old old mousehole. made 1740-1780. I have one very similar minus the chips.
my first work
do you have any coating on that ceramic blanket in the forge? if not buy itc100 and apply it ASAP. ceramic insulation(kaowool, inswool) is a respiratory hazard when hot, plus the flames will ruin it in no time flat.
Blacksmith / Forging Simulator
That's why I don't do computer work like I used to.
Brightening Things Up
Vaseline works as pulling lube as well. you DON'T want to use something that will eat at the jacket on the wire or the conduit/tubing. don't use motor oil!!! if you will be pulling a lot of wire(lots of lamps or a long windy run in a lamp) go to the store and buy wire-aide, clear glide or some other wire pulling lube specifically designed for the purpose.
hehe ive used a vacuum many many many times to fish through conduit that i cant shove a fish tape in. use a small diameter string like a fishing line and tie a light foam ball or cotton ball or whatever is the proper size for the pipe. go to the other side and turn on the vacuum! if you need heavier duty string, use the fishing line to pull your heavier string into the pipe.
first rose
the only issue is that its a harbor freight and its probably made of mild steel. It wouldn't hold its edge as well as if you were to use an old chisel or something
first rose
i appreciate all the feedback including yours, mark. the rose was a first, and i decided to go with a thicker closed petal. if you have ever had a rose bush, you know that the flowers don't all look the same all of the time. sometimes they are closed. sometimes they are open. sometimes they are partially open. i am still learning this blacksmithing thing and i will be learning every day until i can't swing the hammer anymore. first rose and first try. next one will be better. i promise.
Gas welding real wi
ive tried forge welding with an o/a rosebud and all its good for is wasting gas and oxygen. you dont get enough heat on the whole piece and by the time you put the torch down safely and pick up a hammer its already cooled.
Anvil abuse,
spray i down with wd40 every now and then to prevent rust if the air is humid where your shop is (im near a river)
first rose
Made my first rose today. I think it turned out alright.
sourcing candle 'dish'
blacksmiths depot sells them. i think they are under "accessories"
What tools are needed for blacksmithing
Don't got too full of yourself. The more you tell yourself that it is going to be easy to learn, the more disappointed you will be. Instead, motivate yourself to want to learn no matter what. No matter how many failures, keep on trying.
I had my first sale today
my first sale was a railroad spike letter opener on eBay. feels good doesn't it?
