Some new materials have a "sizing" type coating that can cause a few problems. Just as a seamstress will prewash a new fabric before cutting and sewing, prewashing new denim may have to be considered too when used in Micarta batches. R&D will only determine that.
I prefab molds from light cardboard (cereal boxes, etc) to dimensions that are bigger than finished product needs. Tape all corners for strength and line with plastic wrap. As working time of resin is limited I work fast. Pour some resin in bottom of mold, add a precut piece of material and work it flat into mold bottom with a finger (gloves on of course). Excess resin floats up during building process. Add another piece of material, finger smooth, continue. Add more resin as needed between fabric sheets. Continue layering process till mold is over filled past top. Bring all excess plastic wrap up and over top of stack. Have ready 2 pieces of board cut larger than mold size; place 1 board under mold and 1 on top. Use C clamp(s) to press top board down even with mold top. That should allow for enough material compression. Excess resin is still trapped within confines of materials and plastic wrap, thus can still soak into block before hardening if it can find any voids. If by chance any resin leaks from plastic wrap it will bond with the c'board mold; it is considered expendable and easily sawed, ground, or sanded away during final processing.
Hope this helps shed a little more light on the subject. Have fun with your R&D and good luck with your knife project. Stan
