9,166 -
Everything posted by Steve Sells
over 3 years ago I dumped the dial up, and got faster connection. So my Email changed, but they still have my very one one listed... Joe said he cant even get in there to fix things anymore? What gives? First there is talk of paid memberships there, then it seems Jock has gone UA, or AWOL for the older crowd.
Fisher Saw Anvil
Steve Sells replied to Hunterbow Smithy's topic in Anvils, Swage Blocks, and Mandrels
This looks like its in good shape. I though about one for large blades, but I never saw one in person, and I am too cheap to order a new one from overseas. :rolleyes: -
even tho I used my cad fror layout, working heavy construction I am used to blue prints, and the size space it represents, most people do not so use what works, to assist my wife I used tiny white flags, and marking paint for the lay out in the location before I built the shop so she could see and have some input Even the forge and work tables. If you don't want to mark the ground, a rope works well also cardboard boxes for the forge, press or what have you. Move them around , a empty box moves easier than a press does :)
Arm & Hammer Anvil with weld
Steve Sells replied to jbl's topic in Anvils, Swage Blocks, and Mandrels
If you don't know then why are you posting that nonsense, 3 times no less. How is that really supposed to help anyone? and in answer to your query... The worse that can happen is that someone believes you, and acts on that. -
anvil horn ''left or right''
Steve Sells replied to Hofi's topic in Anvils, Swage Blocks, and Mandrels
OK good for a laugh, now lets not cover the non family oriented meanings of buggered anymore, its getting a bit.... off..... -
Welcome to I Forge Iron, Before you quit your day job, smith as a hobby, after you get to the point where you are making as much smithing, then think again about full time, there is not a lot of money to be made as a smith. Many of us do it out of passion, not paycheck.
Welcome to I Forge Iron. Most hammers will make good blades, plow disks are normally good carbon steel, many wrenches are fine, but some stink :)
NO it will not. In case you have not noticed, water is a good conductor of heat. To anneal you want to insulate the heat, to slow the cooling, NOT cool it fast.
Charlotte nailed it. Multi stage problems proving it. First I got the meteorite, tho I was told its Campo del Ceilo, One of the largest falls in the known world, and from Argentina. I do have the analysis of those, but my first issue remains that of my faith in the person I received it from. Second I say used it to make some bars to use for layers in this billet. My word is all I have, even if I filmed the process, I can not prove I didn't edit it, and use that billet elsewhere, assuming I got meteorite in the first place. Third I made the blade. Is that any good, or is my work crap? Fourth, if a person really wants to try check, they can cut a section from the blade, (most likely ruining it as a blade) and test it. Now they have the cost of my blade plus the cost of testing. They will get a measurement of the mix of Wrought iron I used to work out the meteorite, and the carbon steel I layered it with to make the knife billet. When they get a read out of elements in the sample. It would tell them, this sample contains X% of Fe, C and Mn (expected from the 1095) Si (expected from the wrought iron) and Ni, Co, Ir, Ga in amounts that is in relative proportion to a known ratio of those rarer elements found in Meteorites, but could also have been added from other sources, as there is nothing exclusive to the Campo meteorites than is not also found other places on Earth It is the idea that I can, that motivated me to make this. So even if I can prove all these things, and have tests. In the end, my reputation is all I have to sell any blade anyway.
the problem with the registry is that nothing has been updated at that web site in a while, years actually :(
thank you all, I see at least 4 distinct colors already. also it seems this blade has been spoken for by an IFI member. I wish all my stuff sold that fast, maybe I should post more here, and find out....
HUH? I thought I was the master of typo here?
ok I cleaned the Crud off a bit, also a view of other side with my touch mark
the technical term is CRUD Its gone already, it will look better after I clean them and mount, then more pic's
just came out of the acid, need to clean it still.
First Knife - blacksmith's damascus little ugly
Steve Sells replied to jeremy k's topic in Folding Knives
my wife found a T shirt, " Come to the Dark side, we have cookies" I think this sums it up well. -
I may be a little of the oil, but it is mainly from flame treating of the wood while hand sanding with 600 grit :)
Slow down and read a bit more before you do anything.. whats this about temper your anvil and drill it ? Back up, learn basics then ask about swords and other advanced topics.
Sharpening Edges <chat May 15-09>
Steve Sells replied to Steve Sells's topic in Finish and Polish for Knives
[Rich Hale] Take a knife that you know you like the way it cuts, (when the wife is out for the day) use a magnifier and looke close at the angles. [markb] always liked the way CASE knives sharpened [Finnr] Lacking a decent grinder I hand finish up to buffing. Takes too long but it will pay for the new grinder [steve sells] no one should be able to tell if its hand or machine if we do out jobs correctly, all they see is a nice finish [Rich Hale] Run a black marker on the side of the blade and blacken the edge ,,,,take a small stone or fine file and see wot angle it takes to remove the line right down the the cutting edge Does that make sense? [Finnr]Nothing gets on my sales table that isn't up to standard [markb] to determin angle [Rich Hale] Yes if you know that angle works see how to duplicate it. Then do the same thing with and ax or a hatchet [Finnr] Logical [Rich Hale] Look at the angle of the file or stone for both tests Then take a box cutter blade and do the same thing use and old one and sharpen it...keep a new one to look at. [markb] Lots to learn, but i have time latly [Rich Hale] Now sharpen everything you can find. The do some cutting tests...box cutter blades ar great sa they are cheap and you can compare noew to old to wot you have sharpened [Finnr] When I was cooking for a living a razor sharp edge was a must. No time to fool around . A dull knife is dangerous [Rich Hale] : I sharpen box cutters that I use i n the shop until they are wayy to small to use any more [markb] used to shave with straight razor and would try to sharpen- dull [Rich Hale] You still have a razor Make? give it a try after you do these things..I would strop it [Finnr] I do the same with X-acto blades [markb] Sold them all, lots of box cutters tho [Rich Hale] Folks talk about angles for this and for that..you will find that all sizes may need different angle surely a razor needs a keen edge and and axe is a wedge. Try a shop knife with a little "tooth -
[steve sells] tonight we have a request to cover Sharpening. Mark you asked, did you have something in mind or just general information? [markb] flat grind to 1/16' before heat treat then to sharpen you have grind again? [LDW] : I tell my kids every time I make a knife this one is sharper than anyone I have ever made [markb] or you have a chisel [steve sells] Yes mark leave a little metal to be sacrificial, because warpage is more likely to happen in thin areas, also the de-carb from the hardening [Finnr] I grind a bit to remove the decarb and establish the sharp edge [markb] So how would you do this without a grinder stones? [steve sells] I use the belt grinder [Finnr] Abrasive paper on a flat backing [markb] what grit [steve sells] files work,, actually hand files have one nice thing, its easy to KNOW when you remove the de-carb and get into good hard steel [Finnr] Yep! gets harder and you can feel it for sure [steve sells] 120 or 220 for after the HT then work finer till I get where I want [LDW] Hand sanding with a block of wood to the finest grit you wish to go to then hit on a buffer. Thats what I did for years [markb] ok sharpening on a grinder blade up? [steve sells] since I, and many others recommend more than one temper cycle, I temper first ASAP after hardening at 320 to 340 range, thermometer in oven is close enough for the first temper cycle this relieves stress from the thermal shock of the quench that may cause the steel to crack [Finnr] For now I finish my edges with a series of oilstones from soft to black super fine [steve sells] then I can clean up and the next temper is close to what I want for a targeted hardness, my thermometer or temper color [Rich Hale] Blade edge down for me [Finnr] me to. it's easy for me to catch the belt [markb] up? [Finnr] yep [markb] The first 320f temper will solve a problem for me [Rich Hale] If you stand to the side of me and watch me grind a blade on the belt grinder you can see teh wheel push in and deform that is dangerous if the cutting edge is facing into the grind [markb] do you slack belt on sharpening or contact wheel [steve sells] 10:15 pm: for my grinder I have 40 (replaced the 60 I used to use) and 120 Blaze, 220 and 400 Klingspor 321, and Norton x45 x 16, plus hand SC in 400, 500, 600, 1200, 1500, 2000, 2500, 3000. I do not use them all on any one blade, I use what the blade finish needs [Rich Hale] I dont right over the contact wheel I want total control on the angles [Finnr] Slack for a Moran type grind for me [steve sells] I slack for sharpening, but my slack is very tight, not loose at all. I actually run the belt looser when I use the contact wheel than when I do for slack belt grinding. [markb] I bought a grinder but not set up, start a whole new learning process [Rich Hale] It will be your best friend after you get to know it, wot kind is it? [markb] kmg vari speed, bought it in December [Finnr] : Just enough slack for a bit of give Steve? SWEET! [Rich Hale] GET some good belts and a pile of scrap steel [steve sells] : yup just a little give, on the finer belts I notice a BUMP when the splice comes over the flat platen [markb] i have lots of scap and I ordered belts, a variety [steve sells] also my Bader I slack grind with the combo platten , which is a 5 inch contact plus the short platen, so the slack area between is only about 4 inches [Finnr] LOL! I made lots of scrap learning what I have so far [markb] some ceramic and others 10" wheel and flat platen [steve sells] when I first got this (and I still do it) I ordered what I knew would do the order I had to get out the door, PLUS a 1 or 2 belts of a new type to test out. side by side, with what I knew worked well for me. [markb] I ordered 3 types in 50 120 400 [steve sells] Rich Hale here suggested the Blaze to me, and I have been buying those rather than the norton 960's and Klingspor ceramic ever since [Rich Hale] 4"x72"? [steve sells] I sill carry 120 grit in cheaper Norton 823 Zirconium for scale removal as scale ruins any new belt fast, so I use the cheaper cost belt for that only [Rich Hale] If you could test scale it is in the high rc60s [Rich Hale] I dont deal with scale [steve sells] that why I use throw away belts for scale removal @ 120 grit on one or 2 blades then throw it out, Old belt make heat, and that messes up the temper. [markb] how? [LDW] foil? Rich [Rich Hale] If I forge or weld a billet I remove scale with a carbide cutter in the mill or a hard grinding disc for heat treating I use Turco. it prevents scale in the forge, K and G sells it you dip let it dry for an hour and heat treat [markb] Good tip [steve sells] gas forge only ? or use with coal or charcoal? [Rich Hale] I have not tried it in coal [Finnr] I may give it a try over coal just to see [Rich Hale] It seems almost like a lacquer when dry, I am real careful when I put blades in and take them out [steve sells] me too they warp so easy when we squish them. I will turn this over to Rich Hale for a bit as I do ok, sharpening, but Rich knows a LOT more about the details of this topic than I do... so I bow to the more experienced man.. Rich if you please... [Rich Hale] Wot would you like to know about sharpening? [Finnr] You take your blades clear to the final edge on your grinder don't you Rich? [markb] Steps from tempered to final edge grits, or did we cover already [Rich Hale] Yes I do Finn I go up to about a 166 grit belt or so and then buff then to a finer belt and lightly touch the edge [markb] buff edge only or whole blade [Rich Hale] Ok Mark here is wot I do: I first polish the flats on the blade and then the hollow grind or now and then a flat grind. I always go to mirror polish, Then I do the edge ; I thin and sset the angles with a 120 grit belt. Then a 220. Then a 400 then a 1200 or finer then buff. I do not like to see any grinding marks anywhere on the blade. If I do I go back to whatever belt will remove them [markb] thats hard [Rich Hale] Then back to buff. then i use either a 15 micron or 9 micron belt for final edge. No that is persistence [markb] i have so many scratches with hand work grinder is scary, but i'm persistant [Rich Hale] There are really two kinds of edges. you can have a smooth edge that is really clean and nice even under a microscope. or one that has a little bit of a "tooth" to it. [markb] tooth would be what grit [Rich Hale] The grinder will take practice mark but it will get you farther in your work. 15 or 9 microns. It is not a "tooth that you can feel. let me explain that a bit [ApprenticeMan] I go 120, 220, 400 then fine scotch brite with green rouge to strop, and/or a buff on a soft wheel with green rouge [Rich Hale] You can get a small stick of white rouge from tandy that you apply to leather and use it to strop and edge after you can sharpened. I will polish the edge so it it realll smooth and sharp... like the barbers did with a leather strop for shaving with a straight razor. [Finnr] That's what I use on my strops [Rich Hale] That is a smooth clean edge. or yo can do like I do and use a fine belt after Buffing. Maybe a field exercise would help you decide wot you like [markb] ok
I used 4500 mix, rather than a normal 3500 PSI mix. 5/8 rebar on a 3 ft grid. Poured about 6 inches thick, on compacted paving gravel. I also added 8 inch pilings 5 ft down. Why? I live near a river (3 actually) so for the extra $230 I paid for all of this extra stuff ( I say extra because the Building Dept said a 4 inch mono-slab was plenty) I have peace of mind for the high water table and possible flooding. And less likely to have any trouble from having an electrician do the foundation work (thats me:D) I didn't worry about a Power Hammer as I cant have one here unless they start to make them very quiet and have NO vibrations. I can not add that extra support later for that little amount of money. I figure I am 46, and doing it this way I am good for this lifetime free of cracking and settling.
Tied up like a Gordon Knot Lovely pattern as always Jim. As for same steel, close if you forget about the Chrome and Moly in the L-6
If it was that simple, our pattern welded billets would be higher, not lower than the mean average carbon levels of the steels used. One problem with forge work is that carbon has a stronger affinity for air than for steel, so we normally lose carbon while forging. This effect is so common we plan ahead in our blades for the de-carb zones removal after final heat treat.
nothing like trying to learn a foreign language. Tried Ebonics once, but gave that up and switched to Japanese, it made much more seance.
IDK Frosty, my rents wer TL k?
