1. Square stock to square taper, varied lengths, go for a smooth taper.
2. Square stock to round taper, again smooth even taper. Then do round stock to round tapers.
3. Fishtail ends on various stocks, flatten, then start to bend over the edge of the anvil, flip it over and back hammer roll it toward you. Experiment with different hammers.
4. 90 Degree bends, use a vice. Then go on to a "90 Degree inside AND outside bend".
5. Smooth Roll Bends over the horn, Rings if you have the patience, or work up to them.
6. Twists, square stock, then round with a flat spot hammered in it. Experiment with the edges, so you get different results. Use a 1" section, and note how different number of revolutions result in different looking twists.
7. Forge welding after you learn hammer/fire control.
Use small diameter stocks to start, they heat quick, but they also burn up in the fire quick, forcing you to learn fire control, but not costing alot if you make mistakes.
I don't have time this week, but if you would like sample pics of each, I will see what I can whip up on Saturday? :)
