2,092 -
Everything posted by Timothy Miller
RR track is hard you as a beginner need soft steel to work with. You have enough problems like getting a good heat, holding the steel properly in a good pair of tongs, anvil that wobbles on the base or is too light. Your arm is not trained. You throw into the mix hard steel to forge with you might give up. Give your self a break and buy some hot rolled steel from your local steel supply rebar is not really a good choice for the beginner. It is used when nothing else is available.
Need some info about this anvil
Timothy Miller replied to anvilfreak's topic in Anvils, Swage Blocks, and Mandrels
I was told the side clip was used for forging clips used in coach work. The side shelf is not in line with the face like on German anvils similar design different purpose. -
Lining a pot, no natural clay. What to use?
Timothy Miller replied to KYBOY's topic in Solid Fuel Forges
Why do you need to clay your fire pot? I found the clinker can fuse to the clay and be hard to remove. I haven't used clay in years. -
What do ya make from RR Spikes?
Timothy Miller replied to windancer's topic in Blacksmithing, General Discussion
And modern industry does all of that more efficiently than you or I can using less energy. But I like your hooks -
What do you do with your worn out anvils?
Timothy Miller replied to nightmarejr's topic in Anvils, Swage Blocks, and Mandrels
The classic solution is to heat up the old anvil in a large forge. Cut off the old face with a hot chisel and a team of strikers. Make a new tool steel face and forge weld it back on to the old anvil. Then re heat the anvil to the hardening temp of the steel and quench in fast flowing water then temper to desired hardness. This involves lots of skilled hand work and expensive equipment but this is the way it was done. Today most people use hard facing welding rod and build up the anvil by arc welding then grind back to shape. -
Modern steel is made in large part from recycled steel 60% to 70% In most cases. Industry does it on a larger scale and more efficiently and using less engery than a smith burning coal can. I enjoy hand made things and things forged from repurposed materials but the RR spike has become a cliché in the blacksmith world. Now if you could forge a Knife into a RR spike I would be impressed. -
I basically feel the same way. I just wanted to present a contrary opinion to induce thought. Perhaps get some of the guys to move out of the comfort zone. I like Nuge's hooks They no linger look like spikes. -
A length of 5/8" square costs me about $17 with a spike being about 6" of material I can get 40 pieces. That's 43 cents a piece I don't know why people bother with them. I have RR tracks behind my shop its not even worth the trip out the back door. -
I think most of them are much newer than the civil war because the jaws appear to be drop forged and not made from wrought iron. Vices from the civil war period would have been wrought iron and forged by open die hammers and or mostly by hand there would have been a bunch of hand fitting and filing involved as well. That being said these vises are fairly rare and can fetch up around $200 biased on what I have seen them sell for.
The reason it cracked was because you straightened it cold. It was most likely fatigued at the bend and bending it back was just too much for it. If you had annealed the vice first it may have bent back cold without too much trouble. Also it could have been done hot with hammer and anvil. I have done the same job to 3 or 4 leg vices so far experience and reading shows that cold bending is risky especially on older things where the exact metallic composition of the vice your are working on is uncertain. Some are steel of varying carbon contents some are wrought iron and some grades of wrought iron don't weld well at all unless its a forge weld. In the long run you find the powder coat to be problematic because when you clamp hot iron the sparks and scale will ruin your finish. Not to mention you will be breathing plastic fumes.
Visit your local welding shop and ask for some cut offs. Bring beer or doughnuts and coffee for trade. You want hot rolled steel for non tool stuff. High carbon steel is a whole other ball game and requires additional skills to work correctly.
Very cool I need to get my friction screw press up and running I have been procrastinating for too long.
making a punch to drift holes
Timothy Miller replied to eco redneck's topic in Tools, general discussion
There is some very good information here '?do=embed' frameborder='0' data-embedContent>> -
So have I but if you want a smooth hole with parallel sides you need drift pin that has parallel sides with a taper on both ends so it can be driven through easily. Its classic text book technique. -
Don't be sorry I just saw it as an opportunity to explain the difference. All you need is a round pin tapered on both ends regular steel is fine for this sort of tool. -
The tool pictured is not a forging tool it is used for lining up work so it can be bolted together by rail road and structural steel workers. A blacksmiths drift is just a round or shaped pin tapered on both ends. Handled punches are thicker and have more taper to them then handled drifts because they get hit with much more force than a handled drift. Drift punches are also useful for driving out stuck bolts and pins. -
Steam Hammers
Timothy Miller replied to Dillon Sculpture's topic in Power Hammers, Treadle Hammers, Olivers
As an American I would call those pincer tongs. Great Video thanks for sharing. I use small ones under my 60 kg all the time. -
OK... What is it ?
Timothy Miller replied to mudbugone's topic in Power Hammers, Treadle Hammers, Olivers
Looks well built I bet it saved the smith a whole bunch of labor and time. -
How do you organize your drills ?
Timothy Miller replied to 12345678910's topic in Drills, Post drills, Mag drills, etc
I use the commercial drill storage boxes made by Huot they are about 150 bucks each but they save us a bunch of time. Bad link removed, maybe poster can try again ? -
So I have to flatten some hammer textured Stainless steel plate that is polished. I want to preserve the finish it is only 1/8" thick. My plan is to make some sort of soft caps for my power hammer dies to help to flatten the plate. I was thinking of different materials I could use leather wood rubber or plastic. It needs to be a tough material and something I can attach to a steel plate to bolt to my dies. Any and all ideas re welcome.
Does anyone know this anvil?
Timothy Miller replied to kobbsky's topic in Anvils, Swage Blocks, and Mandrels
It is the kind of tool that would have been in common use prior to 1850 in the United States. It is a hand made tool not a mass produced object. The form of the tool has a 18th century feel about it. But to be honest it could be anywhere from 1870's to the roman period and there would be no way of knowing with out finding a makers mark or doing some complex and expensive metallurgical analysis -
You would need a roll with a top and bottom flange to contain it to stop it from twisting on the hossfeild.
I have over and over posted information on this site that is baised on my own personal experince of 20 years of being a professional smith that I experinced with my own eyes and hands. Only to have people far less experince under their belts respond by saying black is white. I have spent many hours tring to provide good solid information to people who want it. Call me fed up not defensive it also may be a NY thing we like a good verbal sparing match many people from other places dont understand its not personal. I tested the jaws of my vices with a file they vaired from glass hard to somewhat difficult to file. Most of the wrought iron vices are faced with older types of steel like blister steel shear steel and cast steel. This stuff can be very hard but it is also prone to soft spots and chipping. Some vice jaws have been anealed by contact with hot steel though they did not start out soft. I don't think you could have cut very far with a saw or drill on a fresh out of the box wrought iron leg vise with steel jaws.
I started out with yard sale hammers in the 2$ to 5$ range put new handles on them and still use many of them. I also have forged a bunch for my self. Don't over think the hammer thing until you get serious and develop your style.
