2,092 -
Everything posted by Timothy Miller
I have owned about 20 I can never remember one with wrought iron jaws or soft steel jaws. I did a quick inventory around the shop. I did a visual inspection and a file test on all of my vices 7" Fisher chain vise cast iron body with cast in steel jaws Two unknown American style forged wrought iron 6" leg vices both vices weld lines visible at the jaw and file test as hard. 4" Peter Wright forged wrought iron vise seem visible on underside of jaw jaw file tests as hard. 5" Peter Wright forged wrought iron vise seem visible on underside of jaw jaw file tests as hard. 4" 18th century style with tenon mounting plate forged wrought iron vise seem visible on underside of jaw jaw file tests as hard. 3 forged clamp on table vices 3" Hiller and sons? 2.5 H.R. Boker and unmarked 2" all file test as hard and show a line at the jaw were steel was welded to the wrought iron body 5" Foster English forged wrought iron body with steel jaws. This vice has one of steel jaws come off when I was straightening out the the jaw I re-welded it to the vice body and rehardned the steel jaw after cutting in new teeth into the jaw. 4-1/2" Colombian drop forged file tests as hard steel has clear weld line at underside of the jaw. Not one of my vices has soft jaws I could spark test them and post a video on line if you don't believe me.
I disagree with frosty. Most Leg vices have hardened steel jaws. Though the jaws often get softened by exposure to hot iron over the years. I have built up jaws with weld before without any problems. As manufactured most Leg vice jaws are supposed crisp square with serrations on the faces of the jaws. It would not have been out of the skill set of your run of the mill blacksmith to reshape and reharden the jaws of a vice to get it back into good working order. I my self have done it on an old worn wrought iron vice. I use copper vice jaw caps to protect fine work for getting messed up by the vice jaws.
A boulder as an anvil would be considered primitive, chunks of discarded surplus steel I would consider post industrial blacksmithing.
I think further experimentation is required.
Steel fire pot, any market?
Timothy Miller replied to der schmied's topic in The Business Side of Blacksmithing
How many hours? Do you ever forge larger stock say bigger than 1-1/4"? Forge weld often? -
This is what I did but the welds gave loose when I went back to clean up the shape. The stake is basically a piece of 1" square mild jump welded to a piece of W1 for the top. I have done laminated tops before in wrought iron with a tenon. I wanted to keep it simple to see if it would be a good alternative to TIG welding.
So I have been told that jump welding mild steel is near impossible by people who really know their stuff. I made it even harder on myself by tiring to jump weld a mild steel shank on a W1 stake top. I have done this in wrought iron in the past and it works just fine. I got the weld to take and twice it let go wile I did some reshaping at a lower of the heat. I used borax with wrought iron chips as flux. Let me reiterate I got it to weld twice on the first try but the weld had no strength. It just let go after when went to forge the rest of the tool. I don't have to do the job this way I just really want to.
Used Lucifer Furnace
Timothy Miller replied to Mark Emig's topic in Heat Treating, general discussion
Did you tell him it was your birthday? -
Make mine mild steel, keep the wrought
Timothy Miller replied to Momatt's topic in Blacksmithing, General Discussion
I don't know about that. The main thin to keep in mind is work it hot often times gas forges fall short in the heat department. If it starts to crack stop and go back into the fire and weld the crack back together at the beginning of your heat. Also wide flat bars don't like to be forged on edge heavily they can cup and split. Once you get the feel for it you will really like wrought iron. I love the way wrought iron looks it has a more organic texture and responds better to hand forging. -
Steel fire pots do not last as long as cast iron fire pots in my experience. Though they do work, the thicker the better. Cast iron handles the heat better by not oxidizing as quickly as steel. -
I guess what I mean is forge welding and splitting is kind of a casual thing with wrought iron. Much the way we just weld on things with ease with a mig welder one can do the same with wrought iron. But yes they had no other options. But plenty of modern metal workers work like they have no other options as well. -
Wrought iron can vary from bar to bar or even in the same bar. It can be a frustrating material but also very rewarding. I often look at old work and wonder how they did that, often the case is that they were able to do that way because they had wrought iron to work with. -
If I remember correctly mine were integral to the handle. I would assume that the balls were upset forged in some sort of press. If you have the machine with the dies this is the fastest way.
Building our first anvil, progress,
Timothy Miller replied to Archerdan's topic in Anvils, Swage Blocks, and Mandrels
1045 was not around when they forge welded faces on anvils. If memory serves they used mostly blister steel and later cast steel with the carbon content being higher than .40% Blister steel in my experience when properly hardened is very hard stuff. The numbering system for steel is a 20th century invention. Forge welded faces on anvils died out in the early 1900's for the most part. Nice build by the way :) -
Feedback or information on this anvil
Timothy Miller replied to Solano's topic in Anvils, Swage Blocks, and Mandrels
That really looks like an oil field anvil for sharping drills. Bridge anvils are different form oil field anvils. -
Got my 118# PW off the stump today.
I have used logs my whole life I also have a tripod steel stand. I prefer logs they just feel better to me. -
I would love to see some progression photos of the forging.
They are traditionally called double arch anvils.
Hornless anvils are not necessarily colonial they were available from Hay Buddden new in the 1920's. A I own a couple of anvils that could be classified as colonial biased on shape and materials used. To really use that term the anvil would have to be made from wrought iron and have a blister steel face. Its not just a shape its the materials used to make it. There is a difference in how a block of modern alloy tool steel feels verse a steel faced wrought iron anvil under the hammer.
Is blacksmithing spiritual?
Timothy Miller replied to aparofan's topic in Blacksmithing, General Discussion
Knives by their nature are very necessary yet can be dangerous things, most people understand this and use them safely accidental stabbings are few and far between. I am bound by building code elements may not be sharper than a certain radii spiked railings, gates and grills are not allowed in most cases even in historic situations. Trust me I have tried. -
If I make a gate with sharp points on it and someone gets hurt on it I will be liable. This is a fact it is the law. People have choices about what they want to put out into the world. I got offered a large military contract once, one of the reasons I did not take it was I did not want make things that could end a life. -
I don't go much for the supernatural but I have found many hours of contentment at the forge. -
I mean that forge welding the claw together on a carpenters hammer will seem like a silly thing to do once you have the skill to forge proper a hammer from scratch.
- 10 replies
- Hammer
- Cross Peen
(and 8 more)
