Double-Bick Anvil Holddown
Here's some pics of my double-bick Peddinhaus anvil. I've been questing for some time to come up with a good holddown. I made several hairpin-spring pritchel holddowns, but the pritchel hole is situated too far forward to have much room left to work once the hot piece is dogged down. I made this low profile tee-shape holddown from two pieces of 1 inch square and a chunk of leafspring from a '58 Chevy haytruck. The leafspring was 2-1/4 inch wide and 3/8 inch thick. It determined the dimensions of the slots for the hardy post. I milled slots on both axis, so the holddown will grab North-South, or East-West (Mcraigl thought up that idea). I forged a Vee in one side of the top piece to hold round stock. With a quick couple taps on the key, it holds work down super tight. The low profile is easy to work around, and the tool doubles as a faux-step when needed. The pressure releases instantly with a tap on the small end of the key.
10989.attach
10990.attach
10991.attach
10992.attach
Great idea and nice work,looks like you're in a holding pattern,LOL:)
Nice work. Do you loose much heat in the workpiece when you set up the hold down?
Consider that idea stolen.
Thanks for posting it.
Don
Great idea! Thanks for sharing.
Mitch
  • 3 weeks later...
Great holddown. I also like the hammer rack and was taken by your use of cardboard for the photographs, very effective.
  • 3 years later...
Smart idea,  will copy. Thanks.
Really nice idea. Looks like it will hold nice and tight.
This thread flamed up after 4 yrs of the tool being used a lot.. It's still working, I should add, that after a few months, I took an aggresive flap wheel on the 4-1/2 side grinder, and made a flat spot on the underside of the hardy hole. That way, the triangular key seats square. It tried to bend the slots a bit untill I gave it a square place to seat. The piece is still in service, still gets used a lot.
That´s it!
thanks for sharing
Peter
  • 1 month later...
Excellent idea.
I just happen to have some short scraps of 1" square stock.....
Neet Idea,,
I'v been doing the same on several anvil tools for 15 years....  I will pass on some info....  You can use 1/4 x1  stock formed in a " U " and it's a lot easier..  Keep in mind to form all of them the same distance from the face.. ( so that you can use the same wedge an all tools...)
Glad to see others have a  thinking cap on and are willing to share...
Hammer on    Jim
  • 1 month later...
I don't have enough time to be browsing old posts so... <_<
THANK YOU, Jakob! :D
I would never have found this gem if you hadn't bumped the post.
and
thanks to mike-hr for the great idea!
James
