DC712001 Posted October 7, 2008 Share Posted October 7, 2008 What brand/Type/Model Adjustable Propane Regulator is a good choice for a small gas forge furnace? Where can they be purchased (locally) without having to ship/wait (what type store, eg: Barbeque, Welding Siupply, RV/Trailer Supply,etc???)? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2008 Share Posted October 7, 2008 I usually get a redhat 0-30 psi from the local propane place. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 7, 2008 Share Posted October 7, 2008 I usually get a redhat 0-30 psi from the local propane place. That's what I use as well. Frosty Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted October 7, 2008 Share Posted October 7, 2008 Most farrier supply house have them in stock. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted October 8, 2008 Share Posted October 8, 2008 Check your local welding shop mine has a ton of propane stuff. Quote Link to comment Share on other sites More sharing options...
highlander Posted October 8, 2008 Share Posted October 8, 2008 i have a nice Goss 0-60. thats just because I already had it laying around when i started blacksmithing. 0-30 is all your really need, and the higher pressure ones are too expensive for the extra psi you wont be using. Quote Link to comment Share on other sites More sharing options...
DC712001 Posted October 8, 2008 Author Share Posted October 8, 2008 Thanks Much. Appreciate the replies/info. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted October 8, 2008 Share Posted October 8, 2008 I use a "Mr Heater" 0-60 PSI regulator, purchased at a big box store (Manard's). I crank it all the way down and use an Alcon needle valve to control the volume of the propane. Cost was about $20. The product number is F273719 (Propane High Pressure Regulator with Soft Nose P.O.L). Quote Link to comment Share on other sites More sharing options...
DC712001 Posted October 8, 2008 Author Share Posted October 8, 2008 Appreciate the replies/info. As suggested, I was checking out the "Zoeller Forge" website, and it looks like he uses/sells a "Fisher" Regulator, Model number 67CH-743 for $34. Turns out, that there is a Fisher distributor a few miles away. Does that seem a good choice (1/4-inch NPT?)Copyrighted photo removed and a link placed into the text. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted October 8, 2008 Share Posted October 8, 2008 Any product from Larry Zoeller would be a good choice.... Quote Link to comment Share on other sites More sharing options...
hammerkid Posted October 8, 2008 Share Posted October 8, 2008 i`d also consider one from darren ellis . Ellis Custom Knifeworks thats where i got mine Quote Link to comment Share on other sites More sharing options...
