Oak chest project (picture heavy)
Jobtiel1
Little update, I finally finished the chest lock!
IMG_20221012_170858.thumb.jpg.7a35e254d6e8285cfc60ca371b1d37ad.jpgIMG_20221012_170907.thumb.jpg.d58c89e28958b245e66a967d38769d98.jpg
As you can see it's been in use. I know screws are not the most secure way of attaching a lock, but the lock itself can be opened with a bend nail, so it's there more for the looks.
~Jobtiel
George, I understand, I have to see how I like it, maybe I'll rivet through the wood using some nails.
Anvil, I have some pics but not from before I put it together, I followed the video from DF in the shop for a simple chest lock.
Basically it's a bolt that is moved by the key through an indentation on the bottom. There is a ring fixed to the backplate where the key falls in.
There is a spring that gives tension to a bend strip that lock in two divots on the top of the bolt, this gives it it's two positions to open and close the lock. There is no additional security so anything that can slide the bolt can open the lock. The spring is from an old recipro sawblade. You still see the lettering.
~Jobtiel
  • 3 weeks later...
Well, I tried putting in new screws. I must say I'm surprised and it indeed looks so much better! Thanks for the tip! I have retired the chest as tool chest right now, As I was gifted an antique that is a bit larger and is more suited for woodworking tools, It actually has space for chisels. I will use it now to take stuff camping and also as a sort of travelling tool chest when going to demo's and stuff.
~Jobtiel
Yes! Much batter.  I still think that domed rivets or rose (faceted) nails would be better still but this is a great improvement.  I think I prefer non-screws because I have sort of a medieval aesthetic taste and various screws do not fit in with that.
Do you mean an extra piece of wood on the top of the side panels to resist the sideways forces? The front and back panels are rabbeted for this same purpose. for strength of the lid I'm only worried about the middle panel in the lid popping out when someone sits on it, the rest is supported by the chest itself. The idea for some extra grip point for two man carrying is quite good. Seeing it's oak even empty it can be difficult to carry alone. should've made the thing from pine...
~Jobtiel
Drill two spaced holes on each end and put a loop of rope through them and tied inside the box.  Make the loops long enough that they will put the carrying hand above the wood when used to lift it.  (You can also run a pole through the loops on top of the box to carry a heavy one on several peoples' shoulders.    Easy to "pull inside the box" when not needed.  My oak one was made from a barn board I found in a flood spoil pile.  I adzed it a bit cleaner and did a modified Mastermyr chest from it; forged all the nails in the basement of my house one winter in a 1 soft firebrick forge.  Still together 20+ years later and demonstrates that ironworking is my craft!  (Wood is what you burn to start the forge!)
  • 2 months later...
How did you attach the handles? I am working on a small chest like this, and I was thinking of nailing the handles on where the ends pierce through and folding them over into a staple on the inside like you see on really old door hinges.
I assume you used screws on yours? How have they held up to being picked up and moved around? Any issues with them pulling out when the box is loaded up pretty heavy?
NGWUN, I built a couple chests for Martha with iron harware and used "clenched" nails as you suggested.  That is the traditional way to attach chest hardware going back to at least medieval times.  They have held up well for the last 30 years or so.  My only problem is that I want to replace the latch on one of them and it is going to be interesting to dismount the old one while trying to minimize the damage to the wood.
GNM
Once the nail is through the chest tap the tip over so it is 90 degrees to the shaft.  Then, hit it harder further down the shaft to bend it at the point where it comes out of the wood to drive the bent tip into the back of the wood side of the chest.  You could heat the tip with a torch if you can do it without setting the chest on fire.  When you mak your nails you may want to forge the tips out a bit thinner so that they will bend over easier.
If you do use forged nails and clench them, make sure you do some test pieces with pre drilled hols of different sizes, square shank nails can act like wedges to split the wood.
On the chest I've used 6 small (2 cm) screws. They've hold up fine so far. I haven't picked up the chest much but it loaded pretty heavily and is heavy of itself, and haven't had any problems with the handles.
~Jobtiel
