NoGoodWithUsernames Posted May 4 Share Posted May 4 I have browsed through the last few pages of posts looking for info on hammer repair and came across the Hofi Repair thread but since he had someone else repair the chip I don't know that it helps me much. Anyway, I acquired a fairly decent, though unmarked, cross-peen hammer recently with some other tools. However there is a chip out of the corner of the peen side, probably 1/4" x 3/8" or so. It sounds like it's not "bad" to weld in new material and then re-finish the face and peen, but what method is best? I have access to MIG and TIG to fill the chip, I only have SS filler rod for the TIG but could probably get something else from the machine shop down the street. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted May 4 Share Posted May 4 Without seeing it, I probably would just grind the edge to eliminate the chip and make the other side match. That would depend on the size of the hammer head though. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 4 Share Posted May 4 If you weld on it you will need to preheat and do a heat treat on the entire head afterwards. You, of course, will want the rod/wire/filler to match the carbon content of the hammer head. What method you choose, stick, MIG, TIG, Forge Welding, depends on how good you are. In general I just redress a hammer head and not try to weld on one---they are easy enough to find another one in my experience. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 4 Share Posted May 4 Ditto needing a pic for a solid suggestion. However most commercial cross pein hammer peins are too sharp, grinding them to a larger radius say almost hot dog size improves them as forging hammers. With that in mind and not knowing how bad the chip is I'd grind it past the chip and radius the ends slightly to prevent divots in my work. Cross pein hammers are too common at yard, garage, etc. sales for a buck or two to take the risk of welding on one. If you get it wrong it could cause chipping in a big dangerous way. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted May 4 Share Posted May 4 That’s no joke! I had to have surgery a few years back to remove a piece of hammer shrapnel in my arm lodged between two arteries! Not fun! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 4 Share Posted May 4 Didn't the MRI get it out for you? Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted May 4 Share Posted May 4 I was breaking down a tire when it chipped after it happened I felt pain an started seeing blood, at first I thought it just nicked me, but I noticed a bump by the cut an when I felt it, it felt hard so I put two an two together and grabbed a magnet off the bench that I use to grab parts with, the hard bump was magnetic lol, so I went to the doctor an at first she thought it was just a cut until I handed her the magnet to let her see my skin pulling, she X-rayed my arm she didn’t feel comfortable cutting it out herself so she sent me to surgery and they deadend my arm an cut it out Quote Link to comment Share on other sites More sharing options...
NoGoodWithUsernames Posted May 5 Author Share Posted May 5 Here is a photo, the pein is currently around the size of a standard pencil. Sounds like best option is indeed grinding the pein to a larger radius. Face will get dressed as well. All the struck tools in the batch badly need the struck ends cleaned up, they are beyond "mushroomed" and actually can see where chips have come off. Reminds me of the video in welding class of the guy with half a cut-off disc in his face... Glad yours didn't end with anything permanent other than a scar and a story. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted May 5 Share Posted May 5 Yep a larger radius will actually make it better. Quote Link to comment Share on other sites More sharing options...
anvil Posted May 6 Share Posted May 6 I recommend a 1\2" to 9\16" peen anyway, so if you grind down to that dimension, most likely that chip will disappear. Quote Link to comment Share on other sites More sharing options...
Nobody Special Posted May 8 Share Posted May 8 Dressing is fantastic. If it's on the face, you can also give up on dressing one smooth again and texture the face to make a hammer you can use to texture surfaces. Be careful how you do so, and in using it. Spalling metal hurts. Quote Link to comment Share on other sites More sharing options...
