Glenn Posted October 24, 2021 Share Posted October 24, 2021 Then cut and install bricks to create a wall in your forge. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 24, 2021 Share Posted October 24, 2021 Only just. The hole in the brick acts as a step flare. The farther a burner nozzle is in a forge the hotter it gets and shorter it's life. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
USANewbie Posted October 24, 2021 Author Share Posted October 24, 2021 Thanks Glenn, Frosty Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted October 25, 2021 Share Posted October 25, 2021 I thought of a few things that haven't been posted yet. #1 It may not seem like it, but it's a lot easier for a beginner to get smoother results by using a hammer that has a crowned face. I don't think I've ever seen a hammer at a hardware shop with a properly crowned face for blacksmithing. Hammers that aren't crowned well, tend to leave corner dings in the work until you're really good at striking flat. That's harder to do when you're forging angles like the bevels in your work. If you know anybody with a decent farrier's rounding hammer, ask them to borrow it. The "round" side will leave dings, but they're generally shallower than what the corner of a "flat" face will give you. #2. Patiently fixing problems when they first appear is often the fastest way to success. Clean the stock, if it won't come clean, cut the scale off before pounding it in further. You can use the flat end of a file to scrape scale off hot metal. #2 If you have a sturdy vice and a coarse file, you can hot rasp the work back to flat very quickly. Thin stock tends to bend away from the rasp unless it's properly supported when hot. Hot rasping is very heat, speed, and pressure sensitive. #3. If you have an angle grinder, look into picking up a backing pad for abrasive discs. The backing pad keeps the cut flat, even when the abrasive is wearing down. The discs are commonly available in low grits that work quickly. They're much cheaper than stone or flap wheels. If you decide to buy a lot of discs, make sure to lay them flat with something heavy on top, otherwise they tend to cup which makes them really difficult to mount. #4. Some people with gas forges put a small section of square or rectangular tube stock in the forge such that the flame hits the tube, not their stock. This helps to minimize scaling on the workpiece. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 25, 2021 Share Posted October 25, 2021 #3 I store my sanding/grinding disks between a couple of old circular saw blades with a piece of all thread running through the middle with washers and nuts on both ends to snug it down tight. Quote Link to comment Share on other sites More sharing options...
USANewbie Posted October 25, 2021 Author Share Posted October 25, 2021 Thanks Rockstar. My cross peen hammer is crowned quite a bit. I think it may just be my aim is off, especially when my arm gets tired. I do plan on buying a rounding hammer though. Thanks for all your info and suggestions. Quote Link to comment Share on other sites More sharing options...
USANewbie Posted October 25, 2021 Author Share Posted October 25, 2021 ThomnasPowers. Are you guys referring to hard grinding discs? How would they cup? Or are you talking about those flexible discs they use for sheet metal work in body shops? Quote Link to comment Share on other sites More sharing options...
Daswulf Posted October 25, 2021 Share Posted October 25, 2021 29 minutes ago, ThomasPowers said: I store my sanding/grinding disks between a couple of old circular saw blades Now thats an interesting idea. I have some larger abrasive discs for a larger hand grinder that need that treatment since they like to curve. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 25, 2021 Share Posted October 25, 2021 USAN: They are talking about Sanding disks, not Grinding disks. They're two different things that work in the same tool. Sanding disks are literally sand "paper" though usually not actual paper backed. You can get different kinds of backing disks I have a stiff rubber one and a hard one and there are others. They give the sanding disk different levels of rigidity depending on what you want from them. For example, FINISH sanding auto bodies needs a more flexible backing so it follows the curves without biting into the finish. Sanding welds or say your knife blades will need a more rigid backer, you want to correct curves NOT follow them. Buying sanding disks in quantity means you'll need to store them and moisture in the air will cause them to warp. So keeping them between saw blades or under something heavy and flat preserves them so they work properly. Make sense? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
USANewbie Posted October 26, 2021 Author Share Posted October 26, 2021 Yes frosty that makes sense. I've used those discs on autobody work. I use to trim the edges with an old pair of metal cutting snips when it got worn down and dull. Quote Link to comment Share on other sites More sharing options...
