Willman Posted July 24, 2008 Share Posted July 24, 2008 Well first of all, I Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted July 24, 2008 Share Posted July 24, 2008 The yellow stuff was water and oil mixed together. This is normal. A picture would help on the pipe connection issue - can't comment further other than to say they may have had some special purpose for it. Copper is fine - a rubber hose is not correct. Go to Home Depot or Lowes and look at the ones on display - that should help you picture the repair in your mind. Quote Link to comment Share on other sites More sharing options...
Willman Posted July 24, 2008 Author Share Posted July 24, 2008 Ok, thanks for the info, I appreciate it a lot. I’ll try and post a pic.http://www.iforgeiron.com/forum/attachment.php?attachmentid=7359&stc=1&d=1216941191 The orange hose is one of the ones that burst. I don’t wont to ask to many questions, but I have another one. do you think the $250 I paid for it was to much? It’s a devilbiss 6.5Hp, 60gal, 1 stage(at the time of purchase I thought it was 2 stage) thanks again, Mike Willman Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted July 25, 2008 Share Posted July 25, 2008 That line should be hard plumbed. Nothing on the head of a compressor should be soft line. You may just want to buy the factory replacement rather than fool around with trying to make it. I think you got a good deal if you can get it to work. It's probably a $400 or more machine. Quote Link to comment Share on other sites More sharing options...
Willman Posted July 25, 2008 Author Share Posted July 25, 2008 Ok, I'll see if i can get the replacement part. Thanks for helping a kid out with his first compressor.:) Quote Link to comment Share on other sites More sharing options...
hdwarner Posted July 25, 2008 Share Posted July 25, 2008 make sure where it goes into tank there is a check valve , otherwise it will leak out of the compressor head when not running , and some check valves you can buy via grainger industrial if they still carry them have a built in blow off for easy starting or your pressure switch may have a pressure relief what this does is downloads the residual pressure in the compressore head for easier starting i notice the motor is a duel capacitor so it is a single phase unit , i reccomend if possible to wire 220 volts for less amperes means less money out of pocket in electricity now whats your plans to have a pneumatic hammer to forge with? Quote Link to comment Share on other sites More sharing options...
Willman Posted July 25, 2008 Author Share Posted July 25, 2008 Hay thanks for the tip about the check valve. I think the pressure switch might already have the blow off thing, when I turn it off it depresses a valve that releases air from the pump by a pipe. Is that the blow off? I picked up some stuff at lows and I think I got everything I need to wire it in. As for the air hammer I think I Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted July 25, 2008 Share Posted July 25, 2008 Ok, I'll see if i can get the replacement part. Thanks for helping a kid out with his first compressor. I was also a kid once - with his first air compressor. We all have to start somewhere and we should never finish learning and sharing with one another until that day when we lay our heads down for the last time... Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted July 25, 2008 Share Posted July 25, 2008 DeVillbiss is a top of ther line compressor. If you are gonna keep it, do an oil change every 6 months, keep the airfilters clean and pliable.Make it a ritual,every day, to check the oil level and drain the tank before starting. Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted July 25, 2008 Share Posted July 25, 2008 You asked about using copper for the line you need. Not likely to work as with the vibrations from the compressor the copper would work harden and likely fail by cracking in a fairly short time. Quote Link to comment Share on other sites More sharing options...
MRobb Posted July 25, 2008 Share Posted July 25, 2008 Hey Mike. Where in Fla are you? There are others of us in the state. Someone might be close by to lend a hand sometime. I'm in Tampa. Mitch Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted July 25, 2008 Share Posted July 25, 2008 I just checked my Emglo 5hp and the line to the pressure switch is copper as is the line from the head to tank containg the uh... can't remember the name of the valve. Quote Link to comment Share on other sites More sharing options...
Willman Posted July 26, 2008 Author Share Posted July 26, 2008 I'm in sarasota near myakka. Well I Quote Link to comment Share on other sites More sharing options...
vectorboy_99 Posted May 16, 2009 Share Posted May 16, 2009 copper would work fine Quote Link to comment Share on other sites More sharing options...
sawyer04 Posted June 11, 2009 Share Posted June 11, 2009 That is a great buy for a compressor, just needs a little TLC. My first air compressor was off of a refrigerator. Yeah, it was slow but I was poor back in 1967. I have still got it for use on an air brush. Quote Link to comment Share on other sites More sharing options...
Willman Posted June 18, 2009 Author Share Posted June 18, 2009 I used copper and yeah it’s worked fine for nearly a year now. used it to sandblast a 15 passenger van’s roof and then paint it. On a side note the guy ended up giving me $100 back when he found out it didn’t work, so I actually got it for $150 but I spent something like $40 getting it running. Mike W. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted June 18, 2009 Share Posted June 18, 2009 Hate to break it to you, but........... it's not just the pipe from the compressor you're missing. There should be a after-cooler before it goes into the tank. Take another look at the ones in the store. Looks like a finned pipe and sits next to the fan blades on the flywheel. It is a "MUST HAVE"! Quote Link to comment Share on other sites More sharing options...
sloscheider Posted June 19, 2009 Share Posted June 19, 2009 Keep in mind this thread is nearly a year old - as he said, it's been working for nearly a year Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted June 19, 2009 Share Posted June 19, 2009 I just checked my 3 units A very old Quincy a old sears and a recent DeVilbiss 6.5hp 60 gal. All have aluminum pipes. None have cooler fins. I did add a refrigerated dryer to the big one only beacuse I run a CNC plasma table with it. Ken Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted June 20, 2009 Share Posted June 20, 2009 Well I'll be. Yeah my little Huskies just have a zigzag tube from the LP cylinder to the HP cylinder, then right into the tank from the HP cylinder. Single stage compressors have higher temp output though and usually have a more elaborate cooler. You saw that when you burned up that hose. Quote Link to comment Share on other sites More sharing options...
horseshoe182 Posted June 25, 2009 Share Posted June 25, 2009 That the yellow stuff (emulsified oil and water) does,nt come out of my compresser and if it did I would be concerned that the rings where worn out. And if they were, the efficentcy would be bad, the electic motor may get to hot and damage itself because of extended use to get it up to preasure. I don,t know what you use it for, but I wouldn,t load it up to much. Quote Link to comment Share on other sites More sharing options...
Willman Posted June 27, 2009 Author Share Posted June 27, 2009 I’ve never had the yellow stuff come out again. when I drain it now, just water comes out. Quote Link to comment Share on other sites More sharing options...
keithgartner Posted July 9, 2009 Share Posted July 9, 2009 I must disagree, ACR or K type copper tube will work just fine, so if you know an HVAC tech. they will be able to hook you up. Quote Link to comment Share on other sites More sharing options...
