Posted
Was at the Lanesville Indiana Heritage festival yesterday(crazy about old tractors,machinery etc.) when I saw a couple of blacksmiths giving demonstrations. He said he made the pattern out of styrofoam and had it cast. Beautiful and impresive.
Posted
WOW!  862 lbs.  That's a monster.  You don't move that puppy around with a two-wheeled hand dolly (more like a fork lift)!!  Do you know if that's a forge welded face?  Looks like a seam of some sort.
Posted
I agree no need for an attached face on cast steel, just curious. Don't think it's a milling machine mark...that would be a perfectly straight line. Maybe some residual something in the casting mold.
Posted
If you place the anvil, which *should* have a *flat* base prior to milling (if it's done right), on a flat surface (milling machine) and run the milling cutters across the top, then it would be a flat surface; i.e. straight line on the side.
Posted
If the anvil is standing up on the mill, and  you run an end mill along the side, and the side as undulations of even just a few thousands you will get a wavy edge. Being a casting I would not expect the sides to be perfectly flat or smooth.
  • 1 year later...
