SharpPotato Posted November 6, 2018 Share Posted November 6, 2018 I just bought this anvil today. Ive been procrastinating for years since I do a lot of metal work. I paid $550 for it along with the six hardy hole things. It weighs 145lbs and rings great. Not sure why it has two mouse holes though, and I cant tell who made it. Would love to know some more about it. I bought it in Philadelphia PA. I bought it today from a guy about 70 years old who said it was his grandfathers. Its been in his shop built in 1920 for as long as he knew. Thats all I know. Thanks for any help you can offer. Quote Link to comment Share on other sites More sharing options...
Chelonian Posted November 6, 2018 Share Posted November 6, 2018 I think that diamond shape on the side means it's a Trenton, but I'm no expert. Quote Link to comment Share on other sites More sharing options...
Paragon Posted November 6, 2018 Share Posted November 6, 2018 That's what I thought but the diamond seems small for the letter size. Is there any numbers on the foot under the horn? It would be on the flat just above the ground. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted November 6, 2018 Share Posted November 6, 2018 It is a Trenton anvil. The two "pritchel" holes were common on some ferrier anvils and that one looks to have part of the clip shelf. Trentons are one of the better brands in my opinion. If it has good ring and rebound you should be set. Looks to be in good using condition with nothing needed but to hammer hot steel on it. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 6, 2018 Share Posted November 6, 2018 Trenton, Farrier's pattern; can you use the swages and bending tool? About US$3.50 a pound; not a bad deal and not a great deal. More of a how badly did you need it? We would need you to check for numbers stamped on the front foot and a picture of the bottom to say more. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 6, 2018 Share Posted November 6, 2018 Welcome to IFI... Your Trenton looks to be in good shape. Have you read about not doing any grinding, milling or welding on the hardened face? Another good read is this thread it will help you get the best out of the forum. https://www.iforgeiron.com/topic/53873-read-this-first/ Quote Link to comment Share on other sites More sharing options...
SharpPotato Posted November 6, 2018 Author Share Posted November 6, 2018 Great information. Yes, Ill use the swages, and especially the bending tool. Here is a pic of the corner of the foot I just wired off. The bottom I couldnt tell where something may be, and didnt want to get covered in rust dust at the moment cleaning the entire bottom. So did this have a full clip shelf originally? I looked up others once you guys said what it is. I see if this came with one originally, then something happened to it. If there is anything else I can add let me know. Thanks Quote Link to comment Share on other sites More sharing options...
Paragon Posted November 6, 2018 Share Posted November 6, 2018 Just the foot there. Hard to make out. It should be the serial number iirc. Someone has a reference and could tell you when it was made. Others are much more knowledgeable than I. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 6, 2018 Share Posted November 6, 2018 The shape of the depression in the bottom gives a bit of information on it's age. (not one of the early ones) The front of the foot may have the weight on one side and the serial number on the other. Quote Link to comment Share on other sites More sharing options...
SharpPotato Posted November 6, 2018 Author Share Posted November 6, 2018 33 minutes ago, ThomasPowers said: The shape of the depression in the bottom gives a bit of information on it's age. (not one of the early ones) The front of the foot may have the weight on one side and the serial number on the other. I believe that is 150 right there very faded. My scale said 145, but its an old one. I couldnt see anything on the other side. I think it may have been red at one point. I will hit the other side a little harder with the wire wheel tomorrow. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 6, 2018 Share Posted November 6, 2018 Anvils often seem to be a few pounds light when weighed on a modern scale as compared to their stamped weight---yours would be well within tolerance. Don't be surprised if you don't turn up a serial number though. Quote Link to comment Share on other sites More sharing options...
Black Frog Posted November 6, 2018 Share Posted November 6, 2018 That logo stamp style would be from the 1905-1911 ballpark time frame. Quote Link to comment Share on other sites More sharing options...
SharpPotato Posted November 7, 2018 Author Share Posted November 7, 2018 13 hours ago, Black Frog said: That logo stamp style would be from the 1905-1911 ballpark time frame. Thanks for that. I was curious about the age Quote Link to comment Share on other sites More sharing options...
