Safely securing anvils
I just bought a 55lb anvil and I want to secure it to a large block of wood. I don't really know what I am doing and was wondering if anyone could give me a few pointers.
Go to the top of the forum page, click on usercp, click on edit your details, enter your location and save.
We would like to know where in the world you are located.
Thermal,
You can use rr spikes, chain , make a varity of hold downs (i made a nail type set for my 110#) Like glenn said look in gallery your find many of ways.
I morticed mine into the top of a block of green spruce and it's been perfectly secure for around 18 years now. Really quieted it down too.
Welcome aboard Thermalfun. You'll like it here, we have a HOT time regularly.
Frosty
Mines done similar but instead of actually mortising it into the stump, I have used some 1" plywood cut to the shape of the stump, cut in half then the anvils base shape cut out of the middle. I then sandwiched the anvil with the plywood and lag bolted the plywood to the stump. the anvil can be removed, but its sturdy doesn't slip off and still easy to move by rolling the stump around.
A short chain, two washers, and two lag bolts will quickly secure an anvil
thanks for all your suggestions I've got a pretty good idea of how to do it now.
I made some real big staples and put it on the four corners of the anvil to hold it on my stump. Next time I am going to nail a piece of sheet steel to the top of my log. Then Iam going to bend some 1"x1/4" flat and weld it onto the sheet steel. That way I can remove my anvil to go to fairs and such.
The kidsmith,
Dave Custer
For my travel anvil I just set it on top of a scrap piece of 2x4 and traced the side curve at the base onto the wood and cut out the "D" and nailed it to the stump---1 per opposite sides. Anvil lifts out easily and with it a bit tight it helps kill the ring.
Putting a flat steel plate for the anvil to bounce around on is not a good idea noise wise...
I really like that idea of using a short chain and eyebolts to tighten. Gonna have to give that one a try on my smaller demo anvil. Thanks!
