June 22, 20187 yr Hey everyone, went on a google image adventure looking at post vises and came across a post vise that didn’t have an actual leg but a bracket at the bottom that was mounted to a bench leg. It had a normal collar mounting system at the top. Anyone have any ideas what this was and where you would have the best luck sourcing one or is it most likely just a modified traditional post vise? Thanks everyone!
June 23, 20187 yr Author Sorry, I should have stated in the original post that I didn’t think to actually save the picture I found. I have been looking for a bit now for it and can’t seem to find it again. Like trying to find a needle in a pile of needles.
June 23, 20187 yr What he said. There were "post vise" that mounted on the tongue of a wagon. Could it be one of those? I have one, unfortunately I'm missing some of the bottom bracket as it was welded to the back of a jeep when I got it.
June 23, 20187 yr Author That bench one is close. The one I saw was a little bigger and was bolted to the bench on top and around bottom of hinge.
June 27, 20187 yr Looks to me this is mounted on a wagon tongue, used by both sides during Civil War, Spanish American war. Gentleman here on IFI wrote and sells a book on Civil War Farriers. Doesn't look like it would mount on a bench with the "Fang" sticking down on the top mount but would keep it from slipping on a wagon tongue.
June 27, 20187 yr Does not look like the wagon tongue vise mounts I have seen. You would NOT want to damage the wagon tongue on your mission critical transportation device. I have seen several like that used for work benches where you would expect to install it and leave it in place. Even nowadays I don't have any problems drilling holes in a workbench top to mount a vise to it. Wagon tongue vises clamp to the tongue and don't drive spurs into it.
July 11, 20187 yr I have a 6" vice built with no leg, I've always known it as a flogging vice. It is mounted by bolting to a shorter post than usual and because it is so low, top tools or heavy sledges are not a problem like they are on a normal height vice. Notice I have spelled it "vice" since it is from an english speaking maker.
