Nick Posted June 20, 2018 Share Posted June 20, 2018 Has anyone ever made a super sucker hood without welding? I'll get a welder one of these days, but today isn't that day, and tomorrow isn't looking good either. It would be easy enough to put it together with screws, bolts, or rivets, but I'm wondering about air tightness. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 21, 2018 Share Posted June 21, 2018 Use an overlock seam. ---^ the vee goes over the "L__" on the other piece Quote Link to comment Share on other sites More sharing options...
Daswulf Posted June 21, 2018 Share Posted June 21, 2018 Or angles overlapping with self drilling sheetmetal screws and high temp caulk if needed. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted June 21, 2018 Share Posted June 21, 2018 Greetings Nick. A few small leaks would not be a problem at all . The volume of hot gasses going up creates a vacuum that would suck air in rather than exhaust out.. Another seam for sheet metal is called a drive . Google it.. HAVE FUN AND GOOD LUCK Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 21, 2018 Share Posted June 21, 2018 Not a problem Nick, any of the above methods work just fine. Heck, you can just run the stovepipe in on a horizontal run close to the fire and call it good. Screws, rivets, pop rivets, folded seams, solder, muffler tape, be creative it only has to direct smoke. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 21, 2018 Share Posted June 21, 2018 It is under vacuum not pressure. Make it a close fit and then use a fastener of your choice to keep it together. Quote Link to comment Share on other sites More sharing options...
