Ian Posted April 22, 2008 Share Posted April 22, 2008 Ow do all Theres an anvil for sale at a local auction, its a double bicked type, the measurements are 39" long by 5" wide. The base is 17" wide. There's no height except including the stand at 28 1/2". The Auction list it as aprox 200lb in weight. Thing is that seems low given those measurements. Can anybody give me a better guestimate than that? You can see some damage to the top so this thing has to be heavy enough to warrent my attention, budget has to stretch :) Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted April 22, 2008 Share Posted April 22, 2008 Ian , just buy it , if needed later on you could always sell it Dale Russell Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted April 22, 2008 Share Posted April 22, 2008 I would check that all over with a magnet..Fella I know buys and sells tools including anvils he bouight a painted anvel ,,about 300# He stripped the paint and found a large portion of the top was missing and filled in with car body filler,,,Bondo... Quote Link to comment Share on other sites More sharing options...
Ferrous Beuler Posted April 22, 2008 Share Posted April 22, 2008 Ian, I have an english pattern marked 2-1-17, which works out to 269 lbs. Roughly the same dimensions as this green monster. I believe you are correct that a weight estimation of 200 lbs. is light for this anvil. BUY IT. Then you can post a "name the green monster" contest. Dan:D Quote Link to comment Share on other sites More sharing options...
philip in china Posted April 22, 2008 Share Posted April 22, 2008 My guess is 280 pounds. I have got the detailed specs of all the Vaughans anvils both single and double bick and will send these on to you. (You need to conert to metric however). I don't want to post them here as they might be copyright and that could cause problems for Glenn. Quote Link to comment Share on other sites More sharing options...
habu68 Posted April 22, 2008 Share Posted April 22, 2008 guesstimate: looking at the anvil I would remove the two horns and add them back to the body to create a cubic rectangle that i would estimate to be 13"x 8"x10" or 1,040 cu/in. steel depending on type is about .2904 lbs/cu/in or about 300 lbs. it would be fun to see how much it really weighs. should we start a pool? Quote Link to comment Share on other sites More sharing options...
jayco Posted April 22, 2008 Share Posted April 22, 2008 I never knew John Deere made an anvil. Just kidding. Maybe the previous owner just painted his tractor.....and had some green paint left over? I would, as Rich said,carefully check it out. A guy I know bought a set of plows at an auction. They looked really good.....fresh coat of paint and everything. When he got them home, he gave them a closer inspection and discovered that someone had carefully plastered the moldboards with a 1/2 in. layer of grease and then painted over it. Both moldboards were worn completely through! The new moldboards he had to buy cost $150. Quote Link to comment Share on other sites More sharing options...
steveh Posted April 22, 2008 Share Posted April 22, 2008 it looks like a vaughan to me.my 2cwt vaughan measures 31.5in.long,the base is 11in.sq and the face is 4.5in wide.i would think it is at least a 3cwt. if not 4cwt.one way to find out is to pick up. Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted April 22, 2008 Share Posted April 22, 2008 Steve , don't tell him stuff like that , he'll go & " try " ....... Dale Russell Quote Link to comment Share on other sites More sharing options...
steveh Posted April 22, 2008 Share Posted April 22, 2008 thats too funny Dale! Quote Link to comment Share on other sites More sharing options...
steveh Posted April 22, 2008 Share Posted April 22, 2008 my Mom is from Lancashire and she said dont tell a Yorkshireman that! Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted April 23, 2008 Share Posted April 23, 2008 its got a base for a smaller anvil under it Quote Link to comment Share on other sites More sharing options...
Ferrous Beuler Posted April 23, 2008 Share Posted April 23, 2008 Good eye Irn, I thought the same. Whatever the foundry had lying about I suppose... Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted April 23, 2008 Share Posted April 23, 2008 Looks like maybe 250#. So did you get it? Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 23, 2008 Share Posted April 23, 2008 philip in china Posting part of a list of numbers that apply is not a problem. It is when you copy entire pages that the original author needs to be consulted for their permission. IForgeIron just wants credit to be given where it is due. Folks work hard to compile and assemble the information. They deserve a email or phone call asking them for permission for the use of their work. Most times they are please you even bothered to ask and give permission. Other times they say there is other information available that is not yet published and provide that too. I always add the note "used with permission" and give the fellows name to give him credit for being nice. Quote Link to comment Share on other sites More sharing options...
philip in china Posted April 24, 2008 Share Posted April 24, 2008 How would I post such a document and does anybody actually want to see it? Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 24, 2008 Share Posted April 24, 2008 Choose the numbers for a specific anvil and type them into a post. Quote Link to comment Share on other sites More sharing options...
Ian Posted April 24, 2008 Author Share Posted April 24, 2008 If its 280lb then it's twenty stone. I can lift that. Used to do it every day BTW Dale Try? Do or do not, there is no try :) Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted April 25, 2008 Share Posted April 25, 2008 Fester, for a young man, 280 ain't that bigga deal. When you get a little older, you may see that things of your youth perhaps come back to haunt you. Actually my guess was between 160-175 lbs. glad to see the world still has strong young fellas. I may need a hand someday. :) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 25, 2008 Share Posted April 25, 2008 When I was young I used to lift my weight in anvils and walk them around. Now that I am older than I used to be I try to hold the lifting/walking down to half my weight and even then prefer to have the youngsters move the anvils and stumps while I do the brain work of deciding which tools to take to an offsite demo. Recently I did load my 400# anvil in my pickup by myself; but used levers, rollers and a comealong and so never "lifted" it. Quote Link to comment Share on other sites More sharing options...
