April 4, 20188 yr I recently posted a question about cleaning complicated pieces, and I've now finished the project in question so I figured I'd post it: https://imgur.com/a/azARw The top is a 35mm thick slab of oak, the table is 50cm tall in total. The grey on the legs is the sand blasted finish, which I've waxed.
April 4, 20188 yr Outstanding. Someone hit me with a shrink ray so that I may climb around in it. Robert Taylor
April 4, 20188 yr I like it, the sq. tubing twisted well. I like the look twisting sq. tube till the walls collapse gives. I had to look closely to see if there were tendrils or fingers from the swirly twisty elements crawling over the table edges. I really like art that draws the viewer into it. Well done, REALLY well. Frosty The Lucky.
