Sean Wilson Posted February 16, 2018 Share Posted February 16, 2018 Ok, so I have a nice 15*15 horse barn to convert to a small shop, and I'm wondering if these bricks would work for a charcoal forge, and also what kind of medium should I go with,. Mortar,clay? Also want some small chimney of sorts All help appreciated for a beginner blacksmith. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 16, 2018 Share Posted February 16, 2018 Those are cement retaining wall blocks, note the little ridge on the nerrow end? That goes down to hook on the next lower brick, stepping the retaining wall back a bit and resisting being pushed forward my the weight of soil behind them. To use them, I would plan an oval starting some 3’x6’ packing it with dirt and building up to about 2’ high, at this point laying in a tuyere and continue up to 30” or so (depending on your anvil hight. let me refer you to some reference material on charcoal forges Now center the fire at one end of the oval, the other end serves as a stock support, fuel pile and tool rest. You do not bank the fire with charcoal as you do with coal, the whole fuel pile will ignite. Because of this you either use clay or fire bricks to bank fuel against or mounds of dirt ( clay soil or adobe). A lot of other things can be used as well such as old bathtubs, washtubs etc to raise a simple hole in the ground to a confortable hight. In that case a raised planting bed to creat a living front wall might be in order from the retaining wall bricks. Quote Link to comment Share on other sites More sharing options...
Jasent Posted February 16, 2018 Share Posted February 16, 2018 I use those blocks often at work. Making a round is not easy and to get over 2' you will have to cut a lot! Square is your best bet. Knock the lip off and stack them straight up using retaining wall adhesive. Allowing a step back or bat will make it a pain to work at and kill your back Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 16, 2018 Author Share Posted February 16, 2018 Wow thanks guys. That's good information. I've seen you help a lot of people Mr. Stevens and I'm just stoked you commented on my post, Also Jasent thank you for your input too. I will definitely take your guys consideration in building this forge. I will post pics to update Have a great day guys Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 16, 2018 Share Posted February 16, 2018 Leaving aside the forge issue for the moment, make sure you take that plastic off the walls of your shed before you light up. Pretty major fire hazard. Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 16, 2018 Author Share Posted February 16, 2018 Will do, and I will keep a new extinguisher ready just in case. Thanks Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted February 16, 2018 Share Posted February 16, 2018 As someone who has gone to the effort of building a brick forge, I can tell you that they have no real advantages over something you could weld up in a couple of hours. That being said, they are just cooler than any other type of forge, in my opinion. If this is your first forge build, I strongly recommend that you start with something simple like the JABOD, and tweak it to suit your needs, *before* you make one out of brick. You may even decide that the dirt box works fine, and you don't need a brick forge. As for the bricks, different types (even stone) have been used, and I believe you could make them work with a little creativity. As Jasent said, you should probably knock the lip off. As for the chimney, you will want to make it a side-draft, if you will be using bricks for the whole thing. I used standard rectangular bricks for my forge, but I can PM you some progress pics of mine if you are interested. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 16, 2018 Share Posted February 16, 2018 C-1; may I respectfully (and Fridairly) point out that if your forge is cooler than other types---you are doing it WRONG! Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 16, 2018 Author Share Posted February 16, 2018 Yes I'd love to see your progress pics, thanks. Yea thanks for the info That would be cool to. Wow guys everyone has been super helpful, thanks again Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted February 16, 2018 Share Posted February 16, 2018 No prob. I'll be sure to do it when I get a chance. On 2/16/2018 at 1:26 PM, Sean Wilson said: Wow guys everyone has been super helpful, thanks again @ThomasPowers *Most* everyone, that is... Quote Link to comment Share on other sites More sharing options...
Exo313 Posted February 17, 2018 Share Posted February 17, 2018 If you end up building a rectangular/square brick structure out of these, note that they key into each other rather well if you rotate every other one 180 degrees. (Front side out, then back side out, then front again. Repeat.) Of course, that'll depend on whether you're concerned with keeping only the front faces out or not. Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 17, 2018 Author Share Posted February 17, 2018 Yeah I can see that. Thanks for the input on it I'm still deciding and blueprinting lol First things first. Cleaned out Plastic off Light source ( I work until dark every day and here in Stuart Florida that means 6 30 ish....) Thank you everyone Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 17, 2018 Share Posted February 17, 2018 Light over your work benches is is important, but not over the forge, indirect lighting, shade will alow you to judge your steel temp better Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 17, 2018 Author Share Posted February 17, 2018 Alright that's perfect, since it rains alot here I want to keep it a little back from the weather so I can work when it's hurricaning here lol but yes def want it as little light as possible. I will take that into consideration. Man I'm excited!! Also found this at the flea market I know it's not practical for what I need but thought it was cool anyhow Any ideas? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 17, 2018 Share Posted February 17, 2018 Actually if the leather is in good shape, that's all you need for a side blast charcoal forge just attach it to the tuyere pipe. Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 17, 2018 Author Share Posted February 17, 2018 Awesome, i mean I will definitely have a set up between hand bellowing and electric blower I thought I could try it at least. 7 dollars Seemed a steal But can't wait to hear all future suggestions pertaining to my projects Thanks guys Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 17, 2018 Share Posted February 17, 2018 It would take two of those and a thrall to pump them. $10 double acting box bellows, alla air bed inflitor. this a peice if 3/4” black pipe, the wash tub in the foreground dirt and somthing to set the forge on... Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 17, 2018 Author Share Posted February 17, 2018 I have one! Great It was a nice idea though lol Yeah I can't wait to get my hands dirty with this build. Quote Link to comment Share on other sites More sharing options...
Kaleb Posted February 17, 2018 Share Posted February 17, 2018 13 hours ago, Charles R. Stevens said: It would take two of those and a thrall to pump them I would still go with the thrall Quote Link to comment Share on other sites More sharing options...
Ranchmanben Posted February 18, 2018 Share Posted February 18, 2018 A brick forge out of those brick would be really neat looking, lots of character. Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 18, 2018 Author Share Posted February 18, 2018 Yeah I agree I can't wait to get started Tomorrow I will start and will post updates on it Quote Link to comment Share on other sites More sharing options...
Sean Wilson Posted February 18, 2018 Author Share Posted February 18, 2018 Officially started Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted February 18, 2018 Share Posted February 18, 2018 Keep us updated. Quote Link to comment Share on other sites More sharing options...
