Farmall Posted October 22, 2017 Share Posted October 22, 2017 Just picked up this nice slip roll by Berkroy. Have no idea of capacity or ability of them. Does anyone have any info on them? The rolls are about 12 inches wide. Quote Link to comment Share on other sites More sharing options...
Farmall Posted October 29, 2017 Author Share Posted October 29, 2017 Anyone able to help? Quote Link to comment Share on other sites More sharing options...
Daswulf Posted October 29, 2017 Share Posted October 29, 2017 Never used one but if I had it I'd put a hand crank handle on it and give it a go. Could roll some wire into rings in the notches on the side. Quote Link to comment Share on other sites More sharing options...
Farmall Posted October 29, 2017 Author Share Posted October 29, 2017 Was going to add a handle. Just wondering what the capacity might be. Reckon I'll figure it by testing. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted October 29, 2017 Share Posted October 29, 2017 The easiest way that would get you close is to look at other slip rolls that are close to the dimensions of yours and see what the capacity is on them. Not exact but will get you in the ball park. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 30, 2017 Share Posted October 30, 2017 I'm not a HVAC or sheet metal guy but am familiar with slip rolls at least to a degree. I took a look around online and hand crank rolls from 10" - 50" tend to be good up to 20 ga. You can roll heavier than they're rated for IF you make multiple passes but that's pretty dicy unless you're good. This one doesn't appear to be made for hand cranking and powered rolls are usually rated for thicker stock. This would be a good time to pick up test stock starting at 20 ga. and increasing thickness a gauge at a time. You want to turn the roll in one continuous motion, start and stop on the crank makes for hinky rolling and the thicker the stock the harder it is to keep the motion continuous and smooth. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Kozzy Posted October 30, 2017 Share Posted October 30, 2017 Ratings are pretty meaningless in slip rolls. Claims are made which are so optimized in terms of starting material that any real-world material you choose might not form readily, though of the rated gauge. That's easy to see on the stomp shears---where the ratings are generally for dead soft sheet and the stated rating is for half-width or (sometimes far) less. A little harder on slip rolls where it's more about finesse and tweaking to form the materials. So...skip worrying about it--just give it a shot with some pieces of varying thickness as you can acquire them. Most likely, it's rated for 20 or 22 gauge as Frosty mentioned. And remember, about every 2 gauges you go up roughly doubles the stiffness (that's not an engineering assertion, it's a broad generalization) so what seems like a small numerical change might be a huge formability change. Quote Link to comment Share on other sites More sharing options...
Farmall Posted October 30, 2017 Author Share Posted October 30, 2017 Thank you both. Exactly what I was looking for. A starting point. Now, as Frosty would say - I’m going to roll with it and circle back with findings. I’ll be careful not to slip these Quote Link to comment Share on other sites More sharing options...
JME1149 Posted October 31, 2017 Share Posted October 31, 2017 I found a reference to an add that listed capacity of the 36" model (R-636) as 22 Ga. and the 24" model (R-624) as 20 Ga., so I'd guess you might be able to roll at least 20 Ga steel with it, maybe just a bit heavier. Quote Link to comment Share on other sites More sharing options...
arftist Posted November 24, 2017 Share Posted November 24, 2017 bear in mind that you can roll thicker pieces of narrower stock. For example you may be able to roll 11 gauge 4" wide or 1/4 x1" or 5/ 16" round Heavy bends should be done at the ends of the rolls. Quote Link to comment Share on other sites More sharing options...
