August 10, 20178 yr You want us to guess? Okay. Without knowing anything about it I'd say mild steel, the frame is modern structural shape, channel iron that's been formed in a press. In one pic I see a rivet head and it looks like the main frame rails are spaced maybe 1/2" apart. Nothing strange about that, the little space makes the structure stronger than if the rails were riveted directly together. I'd have to guess it's factory made and mild steel. The wheels don't show me anything to think they're otherwise. That's my guess and reasoning. Frosty The Lucky.
August 10, 20178 yr Ask them if you can spark test it lol. I see what looks to me like a forge welded joint on the wheels "tire" but I can't say if it is wrought or not. Nice little old wagon tho.
August 10, 20178 yr I'm with Frosty on this: better chance that it's MS. It must be nice and old MS though, I like to forge old mild much more than new stock.
August 10, 20178 yr That's a nice farm wagon running gear, have a modern wheele write fit it with rubber tires and pull it with your horse or tractor.
August 11, 20178 yr Hard to tell for sure, but looks like MS to me. Can't see any characteristic wrought texture.
