Harbor Freight Anvil
Hey, I found a harbor freight 55 lbs. anvil , new at the store, for $55. Made by Central Forge. Is it worth buying?
Those are great anvils for reenacting old road-runner cartoons if you happen to have a coyote around showing off his wiles.  That and doorstop are uses for which those are eminently suitable.
you should see this-
        Littleblacksmith
It is certainly worth buying if it's priced at US$5 or less. Any more and you would be better off spending your money at a  scrapyard for a chunk of steel!
Harbor freight stopped making anvils a long time ago. They only make ASOs now.
Yes there used to be a HF cast steel russian anvil; still not properly hardened but an acceptable low grade anvil.  However the cast iron ones from China were cheaper and you can still misrepresent them to the customers as being an anvil....I once bought a cast iron ASO  myself---to make into a propane stove for Quad-State!   (Drilled like butter, there was so much graphite in it I was surprised it held together!)
Thanks guys, I guess I'll stick with my rail road track anvil until I run across a good anvil.
Haha
My first anvil is one of those Russians. It's tempting to find a way to harden it.
1776, I'll give you one of these mining battery stamps for an anvil if you like. 250 pounders.
All you need to do is pay the freight!   :D
Tempting - I wonder what the the freight wound would come out to......
Same here...
A lot!!
Gee Whiz!
I got free shipping on 157#  from South Carolina to California - It's not THAT much further, is it?? :P
