Jack- Posted March 23, 2017 Share Posted March 23, 2017 recently my katana has been broken while I was away for a while. It was mounted on my wall until a sibling of mine took it off to play with in the backyard. The blade came out of the hilt and will not go back into it fully. I do understand that it is a wall decoration only and it would probably be best to get a new one. It was the first sword I have bought though so it has personal meaning to it. Any comments or suggestions would be helpful in fixing it and I will include pictures of the katana in its current state. Thank you for taking the time to read through this and for any comments or suggestions given. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted March 23, 2017 Share Posted March 23, 2017 JB weld glue is about 5 bucks a pack. Quote Link to comment Share on other sites More sharing options...
Jack- Posted March 23, 2017 Author Share Posted March 23, 2017 How will that help me? Quote Link to comment Share on other sites More sharing options...
Daswulf Posted March 23, 2017 Share Posted March 23, 2017 Hmm. I seem to have heard this warning before about people making "wall hangers". You may know it is one but what about the next guy or your great grandson. Same goes with buying the cheap stuff. Anyway, My guess would be that the pin that held the blade in broke and is bent in the hole keeping the blade from seating in the handle. Just a guess. I have broken or taken some cheaply made blades apart and they are scary dangerously made. Quote Link to comment Share on other sites More sharing options...
turbo7 Posted March 23, 2017 Share Posted March 23, 2017 Failing that, cut off as much of the tang that won't go back in and your good to go. Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 23, 2017 Share Posted March 23, 2017 The glue is to attach your sibling to the floor in the next room, where they can't reach the sword. (JOKE! DON'T GLUE YOUR SIBLINGS!) Quote Link to comment Share on other sites More sharing options...
Jack- Posted March 23, 2017 Author Share Posted March 23, 2017 That is not a bad idea actually Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted March 23, 2017 Share Posted March 23, 2017 The tang didn't just grow longer than it was, so figure out what is blocking it, and get it out of there. If you can't get it out, I second Turbo about just cutting 1/2" off and gluing it in. Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 23, 2017 Share Posted March 23, 2017 Looking at the first picture and the second picture, it seems to me that the distance from the peg hole to the end of the tang is about the same as the distance that the tang is not going into the handle. That tells me that Daswulf's analysis is probably correct, that there's something in the peg hole blocking the tang from going all the way in. If you can push the wrapping out of the way at the back end of the handle to see what's going on with the peg hole, you may be able to push out whatever is still in it, get the tang in place, and put in a new peg. Failing that, as Turbo7 and C-1 ToolSteel say, cut off the tang and glue it in place. That's where the JB Weld comes in. Quote Link to comment Share on other sites More sharing options...
Jack- Posted March 23, 2017 Author Share Posted March 23, 2017 Thank you for the help Quote Link to comment Share on other sites More sharing options...
Chris john Posted April 7, 2017 Share Posted April 7, 2017 Hi Jack i think you have the habaki missing off the blade .about the distance it seem out to me . normaly a piece of copper .look for in your yard . Chris Quote Link to comment Share on other sites More sharing options...
Jack- Posted April 9, 2017 Author Share Posted April 9, 2017 After I found out the sword broke I looked all over the place for any piece that could be missing and couldn't find anything else. Do you know if it is difficult to replace the piece Chris? Now looking at it I believe you are right Chris. Thank you so much for your help. Now I can get a new piece and won't have to cut the tang itself Quote Link to comment Share on other sites More sharing options...
Jack- Posted April 9, 2017 Author Share Posted April 9, 2017 I just ordered one of the appropriate size and length. Once it gets here what can I use to make sure the habaki, gaurd piece, and the tang all stay together, hopefully permanently, in the hilt? Can I use generic super glue or is there a certain way I am suppose to fix it? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 10, 2017 Share Posted April 10, 2017 Traditionally made japanese swords use no glue to fit the components together. The single or double bamboo peg(s) is all that are needed. Seppa are used as "washers" to tighten things up if needed. Quote Link to comment Share on other sites More sharing options...
Jack- Posted April 10, 2017 Author Share Posted April 10, 2017 The sword was loose to begin with and I don't believe it had come with seppa. Is it realistic or a possiblity to purchase them? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 10, 2017 Share Posted April 10, 2017 They are simple to make. They need to be fitted quite exactly to THAT blade. (Starting with the blade you would have a habaki, seppa, tsuba, seppa and then the grip unit). At what point would it be cheaper and esier to replace the sword than fix it? Quote Link to comment Share on other sites More sharing options...
Jack- Posted April 10, 2017 Author Share Posted April 10, 2017 It would most likely be cheaper to replace it. But as I said in my original post it was my first sword and it has a lot of meaning to it. It was always suppose to be a wall hanger. I think I might just use strong glue or heat the tang and mold it to the habaki, tsuba, and hilt. Either way it will find its way back to my wall Quote Link to comment Share on other sites More sharing options...
DRoberts Posted April 13, 2017 Share Posted April 13, 2017 if its just for wall hanging you could glue the handle to the scabbard and put the blade in the closet. Quote Link to comment Share on other sites More sharing options...
