December 22, 20169 yr Every time it is a new cognition how conducive straight Asian forms are. Forged Boehler 2513 TWR with Sterling riveted giraffe shin bone. Cheers
December 22, 20169 yr Tight, crisp, and precise: everything it should be and nothing more. Excellent work!
December 22, 20169 yr "Any idiot can make the simple complicated. It takes genius to make the complicated simple." -- Thelonius Monk
December 22, 20169 yr Well that's a new one to me, giraffe shin bone. Should have enough for a whole lot of beautiful knives. as always, thanks for sharing your great work.
December 22, 20169 yr 12 minutes ago, Daswulf said: Well that's a new one to me, giraffe shin bone. Should have enough for a whole lot of beautiful knives. My father-in-law sent my daughter a giraffe-bone box for Christmas last year, and she really doesn't like it. Maybe I can get her to let me repurpose it....
December 23, 20169 yr Man, you are making me rethink this whole "I want to make a nice knife" idea that I used to entertain. I can't tell by the pics, do the scales extend past the tang like many of your knives in the past have?
December 23, 20169 yr Author 13 hours ago, John McPherson said: Tight, crisp, and precise: everything it should be and nothing more. Excellent work! Thanks for Your fine comment, Sir! 12 hours ago, aessinus said: All John's adverbs. Very striking. Did you use checkering files on the handle? Yes, I used a checkering file with about 18-20 lpi, cut 00. Thank You aessinus! 12 hours ago, JHCC said: "Any idiot can make the simple complicated. It takes genius to make the complicated simple." -- Thelonius Monk Thank You JHCC, that goes deep!
December 23, 20169 yr Author 11 hours ago, Daswulf said: Well that's a new one to me, giraffe shin bone. Should have enough for a whole lot of beautiful knives. as always, thanks for sharing your great work. Daswulf, giraffe bone is, besides whale bone the toughest bone I know. Cattle, buffalo and camel bone are IMHO too brittle to make satisfying scales.G-bone has a much bigger fat content. I personally think has to take besides pressure a lot of bending according to the giraffe's long legs, compared to buffalo and cattle which have to take more pressure than bending. Thanks for Your comment, always much appreciated!
December 23, 20169 yr Thank you for the explanation Templehound. I would have thought it was just more exotic. There usually is more reason to the details of the work done by excellent craftsmen.
December 23, 20169 yr Author 2 hours ago, boisdarc said: Man, you are making me rethink this whole "I want to make a nice knife" idea that I used to entertain. I can't tell by the pics, do the scales extend past the tang like many of your knives in the past have? No, the scales don't extend over the tang.I like them extend over the tang, but that would have changed the drive of the design and raised the effort. Thank You boisdarc!
December 25, 20169 yr That is a stunning looking piece! A quick question about the scales, a friend gave me 2 Giraffe femurs (massive chunks of bone) but I have no idea of how to treat them, would you be amenable to giving me advice?
December 26, 20169 yr Author On 12/25/2016 at 7:37 AM, BCROB said: cool piece , nicely done Thanks BCROB!
December 26, 20169 yr Author On 12/25/2016 at 6:56 PM, ianinsa said: That is a stunning looking piece! A quick question about the scales, a friend gave me 2 Giraffe femurs (massive chunks of bone) but I have no idea of how to treat them, would you be amenable to giving me advice? Thank You, ianinsa! The only problem with this material is, it actually cannot be glued ..even strongly chemically degreased After hours(quick bond) or after days( slow bond) the fat wil find its way back, it will loose its bond and smear away. the bleached bones may glue better, but if they are so strongly bleached they become more brittle and loosing the original toughness. so I like them fatty, yellow and strong and that means I always countersink and riveting the pins and only glue to keep the whole thing in place until I set the pins with or without doomed head. And I do not make hidden tang knives out of this material, because of the problem mentioned above...besides You need the bone of a huge bull to get the thickness for a hidden tang knife. If You have a bandsaw You can cut the chunks vertically, than You have 2 major and 2 minor scales. Take sharp belts and low pressure, thats hard bone.If not sharp and too much pressure it will get hot real fast, smear, bake and close up Your grit. so thats it, just start work with it and You will see.....has its own fragrance. cheers
December 28, 20169 yr On 12/26/2016 at 7:40 AM, templehound said: ".....has its own fragrance." Wife will love that. Thanks for the verification on the files. Good to see I'm not the only one to find the awesome that is Brownell's
December 28, 20169 yr worth a second reply , really like this knife , may have to steel a portion of your idea.......
December 29, 20169 yr Author 11 hours ago, aessinus said: Wife will love that. Thanks for the verification on the files. Good to see I'm not the only one to find the awesome that is Brownell's aessinus Thanks, appreciate it!
December 29, 20169 yr Author 9 hours ago, BCROB said: worth a second reply , really like this knife , may have to steel a portion of your idea....... Well,... I am honored, Thanks a lot BCROB! ...some additional input to encourage You I still have an image of the first study, it told me very fast about the angle of the checkering according to the design. Then I tried it on scales, figuring out the difficulty of continuing the evenness in the checkering pattern when the handle tapers too much. My pleasure Cheers
