broncstomper Posted January 22, 2008 Share Posted January 22, 2008 I've started my permanent forge inside and am in need of ideas for an electric blower. I would love to be able to salvage rather then buy a new electric blower. I want more than a hair dryer. I've also got to find a source for a air gate or whatever they are actually called. I would love to hear some of the things Ya'll have used. Quote Link to comment Share on other sites More sharing options...
matt87 Posted January 22, 2008 Share Posted January 22, 2008 I built mine out of a Quote Link to comment Share on other sites More sharing options...
R Funk Posted January 23, 2008 Share Posted January 23, 2008 One forge blower I have is a combustion air blower from a residential high efficiency gas furnace. I picked one up at a flea market for $0.50 at a flea market. It works fairly well if you are working on small work, less that is than 1" dia or so. Larger work requires more air. For larger work 2 would be required in parrallel. WW Grainger have several blowers that would work for less than $50.00. I don't know their website off hand but a quick search on Google will find them. Quote Link to comment Share on other sites More sharing options...
habu68 Posted January 23, 2008 Share Posted January 23, 2008 The -blower from a defunked (sic) dish washer is what i use on both my small coal forge and as a booster on my gas forge for welding. For a gate I use a lid from a can of beans over the intake using one of the screws on the blower housing. i also use a "dead man" foot switch to save coal. Quote Link to comment Share on other sites More sharing options...
flat creek Posted January 23, 2008 Share Posted January 23, 2008 I have used canister vacuum cleaners with a cheap fan/light rotary dimmer switch wired into the cord with great results. Preston /flatcreek forge Quote Link to comment Share on other sites More sharing options...
Travis Covington Posted January 23, 2008 Share Posted January 23, 2008 You can get a little 100 cfm squirrel cage fan from McMaster carr for about $15. That's what I run on coal and gas. Travis Quote Link to comment Share on other sites More sharing options...
broncstomper Posted January 23, 2008 Author Share Posted January 23, 2008 I read somewhere that you wanted at least 350 cfm, Have you guys found that not to be true? If i can get away with a 100 cfm it shouldn't be to hard to find something. I've been sitting here looking for a pic of a clothes dryer fan but can't find one. I have a source for dryer parts for free. Quote Link to comment Share on other sites More sharing options...
IronPuppet Posted January 23, 2008 Share Posted January 23, 2008 I have an old Electrolux vacuum. No rheostat. Instead I use a tap. adjusts the air flow from none to full with precision. The pic with the hood is how it looks now after the most resent re-vamp. I got the tap at a used Re-Store place for $2. My fire pot might look big to you, but I use wood for my fuel. The wheels are the latest addition. Quote Link to comment Share on other sites More sharing options...
Travis Covington Posted January 23, 2008 Share Posted January 23, 2008 I guess it depends on how large an area you're heating. I have no problem forge welding and I keep my air gate shut down alot. Travis Quote Link to comment Share on other sites More sharing options...
broncstomper Posted January 23, 2008 Author Share Posted January 23, 2008 I am using a brake rotor for the fire pot,I think the pot is 8" diA. Since i am interested in damascus i just want to make sure i can get hot enough to weld. This will be my second forge and i suspect not my last. I am just learning more of what i want and need. Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted January 23, 2008 Share Posted January 23, 2008 broncstomper , another idea is what i use , 1500 w vac motor , hooked to a light dimmer switch , kinda NOISY , but it'll give youse more then enough air ..... Dale Russell Quote Link to comment Share on other sites More sharing options...
Johnnyd5778 Posted April 20, 2019 Share Posted April 20, 2019 I am also wondering about a crop duster as a forge blower but I have no clue the air output Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 21, 2019 Share Posted April 21, 2019 Welcome aboard Johnnyd, glad to have you. If you'll put your general location in the header you might be surprised how many members live within visiting distance. Many questions have a strong regional component, where I live a "crop duster" is an airplane used to spray various chemicals, insecticides, herbicides, etc, etc. on large areas, say a farm. Without knowing where you live and just what you mean we can't give you a meaningful answer. We love to help but . . . ? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Chris Williams Posted April 21, 2019 Share Posted April 21, 2019 On 4/19/2019 at 10:20 PM, Johnnyd5778 said: I am also wondering about a crop duster as a forge blower but I have no clue the air output I have one of what I think you are talking about, but it lacks an arm for the crank. It gave quite a strong blast when I cranked it with a temporary handle. I'll try to rig something up and give it a try. I don't think the one I have would last particularly long in continuous use, though, as it is made of plastic. I'll report back once I have tried it. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 21, 2019 Share Posted April 21, 2019 Johnnyd, I always suggest reading this to get the best out of the forum. READ THIS FIRST Quote Link to comment Share on other sites More sharing options...
Bigsky54 Posted June 2, 2019 Share Posted June 2, 2019 Because I use a ribbon burner, I don’t worry about CFM, I worry about Column Feet of pressure. Because of the expense and my sense of humor, I hooked up a 1hp Bounce House blower. 115v with 7CF of pressure. When I bought mine, it was $149, it is now $199 on EBay. Quote Link to comment Share on other sites More sharing options...
Chris C Posted June 2, 2019 Share Posted June 2, 2019 I bought a Bouncy Castle blower. Little over 1/2hp. Only $71. Sure beats 200 bucks. Way more air than is needed. Quote Link to comment Share on other sites More sharing options...
Bigsky54 Posted June 2, 2019 Share Posted June 2, 2019 This is the blower that I use.... Quote Link to comment Share on other sites More sharing options...
Chris C Posted June 2, 2019 Share Posted June 2, 2019 Same concept............different manufacturer. Designed to work against a resistance, which will allow it to be throttled back with a gate valve. Quote Link to comment Share on other sites More sharing options...
Marc1 Posted June 2, 2019 Share Posted June 2, 2019 Providing we are talking about a solid fuel forge ... you need a centrifugal fan not an axial one. Pressure to push air through the coals is more important than volume. My suggestion, bite the bullet and buy a Dayton blower. Quote Link to comment Share on other sites More sharing options...
